Guest abdullah Report post Posted 10/13/2005 11:31 AM Hello I have 4 phone lines (800) with Panasonic PBX central . I have big clients database in SQL server .. I want to build a telephony system for vaild clients only. This the digram of my system. - caller hear voice message to enter there ID number - system check client ID and ask for password. - if its valid clients and have not expir account transfare him to non-busy help support team. - if not valid clients play voice and close line. both user ID and password are sotred with SQL server. I hope above digram is clear and you have a soultion for me. Abdullah abd@a2z.com.sa Share this post Link to post
SupportTeam Report post Posted 10/13/2005 03:24 PM VoiceGuide can do what you describe, and is used in a number of similar applications already. Please see our WWW from where you can download the fully working evaluation version of the software. The demonstrations supplied will get you running in a matter of minutes. Can you transfer calls using hookflash transfer on this PBX/extensions or would you like to use CTI to do call transfers? How many lines would you like to have on this system? Share this post Link to post
