Guest David Report post Posted 10/17/2005 09:42 AM Hi Guys Sorry to be a pain, but i cant seem to get DNIS routing working correctly. I have my lines running start.vgs which is supposed to work as follows: Expression to Eveluate: $RV_DNIS Paths: On {5901} goto [d:\scripts\mulititalk\vgs] they system is recieving the DNIS ok, but VG is reporting 'no path {true} to next module' any help much appreciated. David Share this post Link to post
Guest David Report post Posted 10/17/2005 09:43 AM Error above - correct path is d:\scripts\mulititalk\multitalk.vgs Share this post Link to post
SupportTeam Report post Posted 10/17/2005 10:30 AM Could you please post a copy of VoiceGuide's Debug Printout which captures the problem, this will allow us to see what happened. When running the script click on VoiceGuide's View menu and select 'Event Trace Log' option - any log information will then appear in this window. You must open the trace window before making the call. You can enable the automatic saving of the logs to files in \log\ directory as well. Please also post the script which you are using. Share this post Link to post
Guest David Report post Posted 10/17/2005 10:43 AM Attached below is the script, followed by the log file. regards David Version=5.0 DefaultModuleDisplayHeight= StartModule=DNIS RunAtHangup= StartWithoutAnswer=0 CtmAsiName= [DNIS] Type=Evaluate DispSize=69 Txt=Evaluate the Result Variable specified, and select the path which matches the current value of the Result Variable Expression=$RV_DNIS ExprNewRV= ExprStoreRV=0 ExprStoreInGlobalRV=0 on {5901} goto [D:\SCRIPTS\MultiTalk\multitalk.vgs] Position=171,207 ***************************************************************************** 114030.66 4 tw DialogicEvent 2084,GCEV_OFFERED,2084,0,0,,, 114030.66 4 event ScriptEventCode GCEV_OFFERED, code=2084, state=1501 114030.66 4 LsRunWaitTillFinished EV_UNKNOWN_2084 114030.66 4 event callstate OFFERING 4 2,0,0 114030.66 4 script interpretor: VgMulti v6.0.2275 114030.66 4 fired OFFERING event to listeners 114030.66 4 set LineState().hCall = 4 in LINECALLSTATE_OFFERING 114030.66 4 iIvrDev=1 114030.66 4 set linestate CID vars 114030.66 4 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING 114030.66 4 rings=0, min rings before answer=0 (iCallerIdHasArrived=1) 114030.66 4 rv clear all 114030.67 4 init LineState ResetAtStartOfNewCall. 114030.67 4 No old processes from last call (could not obtain handle) 2580, 1608 114030.67 4 answer the call 114030.67 4 timer clear 114030.67 4 tw lev_CallerID [,,5901] 114030.67 4 rings=0, min rings before answer=0 (iCallerIdHasArrived=1) 114030.67 4 rv clear all 114030.67 4 init LineState ResetAtStartOfNewCall. 114030.67 4 answer the call 114030.69 4 timer clear 114030.80 4 tw DialogicEvent 2050,GCEV_ANSWERED,2050,0,0,,, 114030.80 4 event ScriptEventCode GCEV_ANSWERED, code=2050, state=6001 114030.80 4 event callstate CONNECTED 4 256,0,0 114030.80 4 LineEvCallState_Connected hDevice=4 params=256,0,0 114030.80 4 WorkingModes tapi= script= LineState().iState=6001 114030.81 4 Inband detection not enabled 114030.81 4 StartLoadedVgs at 17/10/2005 11:40:30 [VgMulti v6.0.2275] 114030.81 4 set LineState().iVgsIdx=2 114030.81 4 set sScriptToRunOnHangup=[] in StartLoadedVgs 114030.81 4 init StartLoadedVgs_InitLineState start 114030.81 4 rv add [$RV_STARTTIME]{17/10/2005 11:40:30} 114030.81 4 rv add [$RV_DEVICEID]{4} 114030.81 4 rv add [$RV_CIDNAME]{} 114030.81 4 rv add [$RV_DNIS]{5901} 114030.81 4 rv add [DNIS]{5901} 114030.81 4 rvns add [PathApp]{C:\Program Files\VoiceGuide\} 114030.83 4 rvns add [scriptsPath]{D:\SCRIPTS\} 114030.83 4 rv add [$RV_CIDNUMBER]{} 114030.83 4 fn RunModule start 114030.83 4 timer clear 114030.83 4 state [DNIS] Evaluate [$RV_DNIS] 114030.88 4 rv replace start: [$RV_DNIS] 114030.88 4 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{17/10/2005 11:40:30}[$RV_DEVICEID]{4}[$RV_CIDNAME]{}[$RV_DNIS]{5901}[DNIS]{5901}[PathApp]{C:\Program Files\VoiceGuide\}[scriptsPath]{D:\SCRIPTS\}[$RV_CIDNUMBER]{} 114030.88 4 rv replace end: [5901] 114030.88 4 eval[5901] 114030.88 4 rvns add [DNIS_Input]{5901} 114030.88 4 rvns add [DNIS]{5901} 114030.88 4 Eval Expr result:[5901] 114030.89 4 rv add [Hangup Time]{17/10/2005 11:40:30} 114030.89 4 state Hanging up call... [No path (True) to next module defined.] 114030.89 4 HangupCall_Common hCall=4 114030.89 4 rec RecSoundStop ok 114030.89 4 play PlaySoundStop ok 114030.89 4 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 114030.89 4 fnHangupCall end 114032.98 4 timer fired EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 114032.98 4 event ScriptEventCode EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP, code=9101, state=900 114032.98 4 state Hanging up call...(2) 114032.98 4 HangupCall_Common hCall=4 114032.98 4 rec RecSoundStop ok 114032.98 4 play PlaySoundStop ok 114032.98 4 fnHangupCall end 114032.98 4 LsAwaitingCalls EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP Share this post Link to post
SupportTeam Report post Posted 10/17/2005 11:08 AM Please try using quotes around $RV_DNIS in the Evaluate Expression module, like this: "$RV_DNIS" and see if this makes any difference. Share this post Link to post
SupportTeam Report post Posted 10/17/2005 11:12 AM Actually... you should do this: change on {5901} goto [D:\SCRIPTS\MultiTalk\multitalk.vgs] to: on {5901} goto [D:\SCRIPTS\MultiTalk\multitalk.vgs|] notice the "|" near the end! After the "|" you can specify the starting module's name as well, or leave it as it is to use the script's default start module. Share this post Link to post
Guest David Report post Posted 10/17/2005 11:29 AM Wahay! Works a treat, thanks! Share this post Link to post
