Run Time Error 429
Good Morning, Looks like I have messed up something. I did an un-install and re-install, of dialogic as well as voice guide trying to solve a problem and now I cannot get past this error. I'm trying to run the dialogic version 6.0.2292. I did the un-install because when voice guide ended, I got a memory access error. I've been working with voice guide for about 3 weeks.
Thanks for any suggestions.
Eugene
Looks like one of the OCXs is no installed correctly.
Best to just uninstall and try the entire install again.
Also, if using SR5.1.1 drivers make sure to install SP1 as well - you may get errors on exit unless you install SP1 for SR5.1.1
