Jesse Report post Posted 10/24/2005 09:10 PM set vg = CreateObject("VoiceGuide.CommandLink") vg.Dialer_OutDialQueAdd "somenumber", 0, 0, 0, "", "", 1, "", "somescript.vgs", "", "", 0, 2, 5, "" The script contains a module called Hello, where the user is prompted to press 1,2 or 3 and then the script hangs up. How do I wait until the script ends before getting the value of HELLO? Currently I have to add WSCRIPT.SLEEP 60000 and guess how long it will take. How do I get the value of the HELLO variable directly? Currently I can use: sReturnValue = vg.RvGet_All(1) and parse the value (split all variables and values). Attempts to parse directly have failed: sReturnValue = vg.RvGet(1, "${HELLO}") OR sReturnValue = vg.RvGet(1, "$HELLO") OR sReturnValue = vg.RvGet(1, "HELLO") Thanks Share this post Link to post
SupportTeam Report post Posted 10/24/2005 10:43 PM Quote How do I wait until the script ends before getting the value of HELLO? A better approach would be to do your processing which requires the value entered in module "Hello" from within the VoiceGuide script itself - in a Run VBScript type module. If you canot find a way to do it like that then you should setup a loop which periodically tests if $RV[HELLO] is set (This of course relies that recipient of call will press something instead of just hanging up - so if you must use the 'external script' approach then you'll need to also check $RV_CALLSTATE) Quote How do I get the value of the HELLO variable directly? From a totally external VBScript either of these should work: sReturnValue = vg.RvGet(1, "RV[HELLO]") or sReturnValue = vg.RvGet(1, "$RV[HELLO]") From within a Run VBScript module: sReturnValue = "$RV[HELLO]" or sReturnValue = vg.RvGet(1, "RV[HELLO]") Share this post Link to post
