Capturing Keypresses
Hi There!
Im trying to capture a string of digits that may include the #.
We have an conference bridge, that sends a string as follows 1#250606#90555#3048# but I just cant seem to grab the command using get Numbers.
Is there a way to make VG ignore the # key, rather than using it as a terminator?
1. Can you try using a sequence of Get Numbers modules? Each of them would capture the dtmf string up to the next # and then go on to the next Get Numbers module (using Success path) which would then capture the next substring etc.
This is probably the best way as you'll have the last module stop capturing immediately when the last # arrives - otherwise what way will you use to determine if the sent dtmf string has finished? I assume that the overall string can be variable length...
2. Can you set the bridge to use the * key instead of the # key?
We can change the Get Numbers module to accept the # key but this would be a custom modification - please send and email to sales@voiceguide.com if you'd like to enquire about pursuing that option further.
Thats exactly what i tried.
However, my first get numbers waits for 1 followed by #
it runs on sucsess to my next Get Numbers (ChairPIN)
but the first digit reported by GetNumbers is # which fires an immediate fail ( # in getnumbers ) and then drops the call.
Any help much appreciated.
See log below:
141031.78 95 tw dtmf 1 (95,49,49)
141031.78 95 event ScriptEventCode 1, code=49, state=1301
141031.78 95 LsGetNbrsRxDigits 1,1
141031.78 95 state [Check For Contex] Number Input 1
141031.78 95 path {1} not found
141031.78 95 timer set 0 EV_TIMEOUT_ENTERDATA
141031.78 95 event ScriptEventCode EV_TIMEOUT_ENTERDATA, code=9006, state=1301
141031.78 95 LsGetNbrsRxDigits EV_TIMEOUT_ENTERDATA,EV_TIMEOUT_ENTERDATA
141031.78 95 path {EV_TIMEOUT_ENTERDATA} not found
141031.78 95 timer clear
141031.78 95 rv add [Check For Contex]{1}
141031.78 95 rvns add [Check For Contex_PathTaken]{success}
141031.78 95 fn RunModule start
141031.78 95 tw DialogicEvent 134,TDX_CST,49,0,0,DE_DIGITS,,
141031.80 95 event ScriptEventCode TDX_CST, code=134, state=6001
141031.80 95 timer clear
141031.80 95 state [ChairPin] Number Input
141031.80 95 state [ChairPin] Playing ()
141031.80 95 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1300
141031.80 95 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
141031.80 95 path {EV_PLAY_FINISHED} not found
141031.80 95 timer set 25 EV_TIMEOUT_REPLAYMSG
141031.89 95 tw dtmf # (95,35,35)
141031.89 95 event ScriptEventCode #, code=35, state=1301
141031.91 95 LsGetNbrsRxDigits #,#
141031.91 95 timer clear
141031.91 95 rv add [ChairPin]{}
141031.91 95 rvns add [ChairPin_PathTaken]{fail}
141031.91 95 rv add [Hangup Time]{27/10/2005 14:10:31}
141031.91 95 state Hanging up call... [*# in GetNbrsRxDigit]
141031.91 95 HangupCall_Common hCall=95
141031.91 95 rec RecSoundStop ok
141031.91 95 play PlaySoundStop ok
141031.92 95 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
141031.92 95 fnHangupCall end
141031.92 95 tw DialogicEvent 134,TDX_CST,35,0,0,DE_DIGITS,,
141031.92 95 event ScriptEventCode TDX_CST, code=134, state=900
141031.92 95 LsAwaitingCalls EV_UNKNOWN_134
141032.00 95 tw dtmf 2 (95,50,50)
141032.00 95 event ScriptEventCode 2, code=50, state=900
141032.02 95 LsAwaitingCalls 2
141032.02 95 tw DialogicEvent 134,TDX_CST,50,0,0,DE_DIGITS,,
141032.02 95 event ScriptEventCode TDX_CST, code=134, state=900
141032.02 95 LsAwaitingCalls EV_UNKNOWN_134
141032.13 95 tw dtmf 5 (95,53,53)
141032.13 95 event ScriptEventCode 5, code=53, state=900
141032.13 95 LsAwaitingCalls 5
141032.13 95 tw DialogicEvent 134,TDX_CST,53,0,0,DE_DIGITS,,
141032.13 95 event ScriptEventCode TDX_CST, code=134, state=900
141032.13 95 LsAwaitingCalls EV_UNKNOWN_134
141032.25 95 tw dtmf 0 (95,48,48)
141032.27 95 event ScriptEventCode 0, code=48, state=900
141032.27 95 LsAwaitingCalls 0
141032.27 95 tw DialogicEvent 134,TDX_CST,48,0,0,DE_DIGITS,,
141032.27 95 event ScriptEventCode TDX_CST, code=134, state=900
141032.27 95 LsAwaitingCalls EV_UNKNOWN_134
141032.36 95 tw dtmf 6 (95,54,54)
141032.36 95 event ScriptEventCode 6, code=54, state=900
141032.38 95 LsAwaitingCalls 6
141032.38 95 tw DialogicEvent 134,TDX_CST,54,0,0,DE_DIGITS,,
141032.38 95 event ScriptEventCode TDX_CST, code=134, state=900
141032.38 95 LsAwaitingCalls EV_UNKNOWN_134
141032.48 95 tw dtmf 3 (95,51,51)
141032.48 95 event ScriptEventCode 3, code=51, state=900
141032.48 95 LsAwaitingCalls 3
141032.48 95 tw DialogicEvent 134,TDX_CST,51,0,0,DE_DIGITS,,
141032.48 95 event ScriptEventCode TDX_CST, code=134, state=900
141032.50 95 LsAwaitingCalls EV_UNKNOWN_134
141032.61 95 tw dtmf 6 (95,54,54)
141032.61 95 event ScriptEventCode 6, code=54, state=900
141032.61 95 LsAwaitingCalls 6
141032.61 95 tw DialogicEvent 134,TDX_CST,54,0,0,DE_DIGITS,,
141032.61 95 event ScriptEventCode TDX_CST, code=134, state=900
141032.61 95 LsAwaitingCalls EV_UNKNOWN_134
141032.73 95 tw dtmf # (95,35,35)
141032.73 95 event ScriptEventCode #, code=35, state=900
141032.73 95 LsAwaitingCalls #
141032.73 95 tw DialogicEvent 134,TDX_CST,35,0,0,DE_DIGITS,,
141032.75 95 event ScriptEventCode TDX_CST, code=134, state=900
141032.75 95 LsAwaitingCalls EV_UNKNOWN_134
141033.75 95 tw dtmf # (95,35,35)
141033.75 95 event ScriptEventCode #, code=35, state=900
141033.75 95 LsAwaitingCalls #
141033.75 95 tw DialogicEvent 134,TDX_CST,35,0,0,DE_DIGITS,,
141033.75 95 event ScriptEventCode TDX_CST, code=134, state=900
141033.75 95 LsAwaitingCalls EV_UNKNOWN_134
141034.06 95 timer fired EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
141034.06 95 event ScriptEventCode EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP, code=9101, state=900
141034.06 95 state Hanging up call...(2)
141034.06 95 HangupCall_Common hCall=95
141034.06 95 rec RecSoundStop ok
141034.06 95 play PlaySoundStop ok
141034.06 95 fnHangupCall end
141034.06 95 LsAwaitingCalls EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
141035.80 95 tw dtmf 3 (95,51,51)
141035.80 95 event ScriptEventCode 3, code=51, state=900
141035.80 95 LsAwaitingCalls 3
141035.80 95 tw DialogicEvent 134,TDX_CST,51,0,0,DE_DIGITS,,
141035.80 95 event ScriptEventCode TDX_CST, code=134, state=900
141035.81 95 LsAwaitingCalls EV_UNKNOWN_134
141035.92 95 tw dtmf 4 (95,52,52)
141035.94 95 event ScriptEventCode 4, code=52, state=900
141035.94 95 LsAwaitingCalls 4
141035.94 95 tw DialogicEvent 134,TDX_CST,52,0,0,DE_DIGITS,,
141035.94 95 event ScriptEventCode TDX_CST, code=134, state=900
141035.94 95 LsAwaitingCalls EV_UNKNOWN_134
141036.05 95 tw dtmf 8 (95,56,56)
141036.05 95 event ScriptEventCode 8, code=56, state=900
141036.05 95 LsAwaitingCalls 8
141036.05 95 tw DialogicEvent 134,TDX_CST,56,0,0,DE_DIGITS,,
141036.06 95 event ScriptEventCode TDX_CST, code=134, state=900
141036.06 95 LsAwaitingCalls EV_UNKNOWN_134
141036.19 95 tw dtmf 0 (95,48,48)
141036.19 95 event ScriptEventCode 0, code=48, state=900
141036.19 95 LsAwaitingCalls 0
141036.19 95 tw DialogicEvent 134,TDX_CST,48,0,0,DE_DIGITS,,
141036.19 95 event ScriptEventCode TDX_CST, code=134, state=900
141036.19 95 LsAwaitingCalls EV_UNKNOWN_134
141036.30 95 tw dtmf # (95,35,35)
141036.30 95 event ScriptEventCode #, code=35, state=900
141036.30 95 LsAwaitingCalls #
141036.31 95 tw DialogicEvent 134,TDX_CST,35,0,0,DE_DIGITS,,
141036.31 95 event ScriptEventCode TDX_CST, code=134, state=900
141036.31 95 LsAwaitingCalls EV_UNKNOWN_134
141045.41 95 tw DialogicEvent 2137,GCEV_RELEASECALL,2137,0,0,,,
141045.41 95 event ScriptEventCode GCEV_RELEASECALL, code=2137, state=900
141045.41 95 LsAwaitingCalls EV_UNKNOWN_2137
141045.42 95 event callstate IDLE 95 1,0,0
141045.42 95 WorkingMode@Idle=
141045.42 95 timer clear
141045.42 95 rec RecSoundStop ok
141045.42 95 play PlaySoundStop ok
141045.42 95 rv add [CallEndTime]{27/10/2005 14:10:45}
141045.42 95 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
141046.42 95 timer fired EV_TIMEOUT_TIMETOREINITLINE
141046.42 95 event ScriptEventCode EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=900
141046.42 95 init atidle reinit : start
141046.42 95 init atidle reinit iConferenceOtherLegLid=-1
141046.42 95 init atidle reinit : reset all LineState variables
141046.42 95 timer set 0.3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
141046.42 95 state Waiting for a call...
141046.75 95 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
141046.75 95 event ScriptEventCode EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=900
It looks like you've used a "timeout 0" path in module [Check For Contex].
Do not use that path - use a "Success" path.
If you use a "timeout 0" path then immediately after receiving first DTMF the timeout path will be taken, and then the "#" is received by the next module...
if you use Success Path then when # is received the Success path will be taken (is some DTMFs arrived before the #)
I just have "on {success} goto" with no timeout options at all.
Ive just dialled into the recorder service though and can confirm that VG isnt waiting for me to press # before moving onto the next command.
this is strange, as other modules are wiating for me to press # before moving on.
Ah.
It seems to be the delay in waiting for the keys.
If i leave a second or so in between presses it takes that as the end of input and moves onto the next prompt.
More info:
Only timouts used are those in VG.INI - set to 6 seconds.
VG is timing out on all keypresses though within 1 second, regardless of the settings in VG.INI. Ive created new scripts, and exactly the same thing is happening. I notice that this was a bug that was fixed in 5.13 - is it possible its re-introduced in version 6.0.2275?
regards
David
Please post the script you are using along with the trace of a call. We can then see what is actually happening on your system.
Thanks Guys.
Ive created a new script which ive pasted below. I entered (quickly) 25# at the GetNumbers stage, VG processed the 2 and moved onto the Success Path.
All help much appreciated.
Script:
Version=5.0
DefaultModuleDisplayHeight=
StartModule=PromptUser
RunAtHangup=
StartWithoutAnswer=0
CtmAsiName=
[PromptUser]
Type=Get Numbers
DispSize=69
Txt=Play a prompt asking the caller to enter a sequence of numbers, speak the sequence back to the caller and ask them to confirm it. Go down different paths depending on the numbers entered...
Replay=2,5
GetNbrLen_Min=0
GetNbrLen_Max=0
Confirm=OFF
VbScript=
VbsHoldPlay=
on {success} goto [Worked]
on {fail} goto [Failed]
Position=247,214
[Worked]
Type=Play
DispSize=69
Txt=Play a sound file, then await a response...
Replay=2,5
strTtsText=
Position=190,420
[Failed]
Type=Play
DispSize=69
Replay=2,5
strTtsText=
Position=463,441
Debug:
085243.44 95 tw DialogicEvent 2084,GCEV_OFFERED,2084,0,0,,,
085243.44 95 event ScriptEventCode GCEV_OFFERED, code=2084, state=900
085243.44 95 LsAwaitingCalls EV_UNKNOWN_2084
085243.44 95 event callstate OFFERING 95 2,0,0
085243.44 95 script interpretor: VgMulti v6.0.2275
085243.44 95 fired OFFERING event to listeners
085243.44 95 set LineState().hCall = 95 in LINECALLSTATE_OFFERING
085243.44 95 iIvrDev=31
085243.44 95 set linestate CID vars
085243.44 95 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING
085243.44 95 rings=0, min rings before answer=0 (iCallerIdHasArrived=1)
085243.44 95 rv clear all
085243.44 95 init LineState ResetAtStartOfNewCall.
085243.44 95 answer the call
085243.44 95 timer clear
085243.44 95 tw lev_CallerID [,,5920]
085243.45 95 rv clear all
085243.45 95 init LineState ResetAtStartOfNewCall.
085243.45 95 answer the call
085243.45 95 timer clear
085243.56 95 tw DialogicEvent 2050,GCEV_ANSWERED,2050,0,0,,,
085243.56 95 event ScriptEventCode GCEV_ANSWERED, code=2050, state=6001
085243.58 95 event callstate CONNECTED 95 256,0,0
085243.58 95 LineEvCallState_Connected hDevice=95 params=256,0,0
085243.58 95 WorkingModes tapi= script= LineState().iState=6001
085243.58 95 Inband detection not enabled
085243.58 95 StartLoadedVgs at 31/10/2005 08:52:43 [VgMulti v6.0.2275]
085243.58 95 set LineState().iVgsIdx=4
085243.58 95 set sScriptToRunOnHangup=[endcall.vgs] in StartLoadedVgs
085243.58 95 init StartLoadedVgs_InitLineState start
085243.58 95 rv add [$RV_STARTTIME]{31/10/2005 08:52:43}
085243.58 95 rv add [$RV_DEVICEID]{95}
085243.59 95 rv add [$RV_CIDNAME]{}
085243.59 95 rv add [$RV_DNIS]{5920}
085243.59 95 rv add [DNIS]{5920}
085243.59 95 rvns add [PathApp]{C:\Program Files\VoiceGuide\}
085243.59 95 rvns add [scriptsPath]{d:\scripts\}
085243.59 95 rv add [$RV_CIDNUMBER]{}
085243.59 95 fn RunModule start
085243.59 95 timer clear
085243.59 95 state [DNIS] Evaluate [$RV_DNIS]
085243.61 95 rv replace start: [$RV_DNIS]
085243.61 95 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{31/10/2005 08:52:43}[$RV_DEVICEID]{95}[$RV_CIDNAME]{}[$RV_DNIS]{5920}[DNIS]{5920}[PathApp]{C:\Program Files\VoiceGuide\}[scriptsPath]{d:\scripts\}[$RV_CIDNUMBER]{}
085243.61 95 rv replace end: [5920]
085243.61 95 eval[5920]
085243.61 95 rvns add [DNIS_Input]{5920}
085243.61 95 rvns add [DNIS]{5920}
085243.61 95 Eval Expr result:[5920]
085243.61 95 rv add [scriptEnd_Time]{31/10/2005 08:52:43}
085243.61 95 rv add [scriptEnd_Goto_Script]{d:\scripts\test\test.vgs}
085243.61 95 rv add [scriptEnd_Goto_Module]{}
085243.63 95 rv add [scriptStart_Time]{31/10/2005 08:52:43}
085243.63 95 rv add [scriptStart_CalledFrom_Script]{d:\scripts\startup.vgs}
085243.63 95 rv add [scriptStart_CalledFrom_Module]{DNIS}
085243.63 95 FindFullPathToScript_VgsOrVgp start [d:\scripts\test\test.vgs]
085243.64 95 FindFullPathToScript_VgsOrVgp 1
085243.64 0 LoadedVgs_Find d:\scripts\test\test.vgs at idx=5
085243.64 95 rvns add [scriptsPath]{d:\scripts\test\}
085243.66 95 StartModuleDefault=[PromptUser]
085243.66 95 fn RunModule start
085243.66 95 timer clear
085243.66 95 state [PromptUser] Number Input
085243.66 95 state [PromptUser] Playing ()
085243.66 95 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1300
085243.66 95 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
085243.66 95 path {EV_PLAY_FINISHED} not found
085243.66 95 timer set 5 EV_TIMEOUT_REPLAYMSG
085245.27 95 tw dtmf 2 (95,50,50)
085245.27 95 event ScriptEventCode 2, code=50, state=1301
085245.27 95 LsGetNbrsRxDigits 2,2
085245.27 95 state [PromptUser] Number Input 2
085245.27 95 path {2} not found
085245.28 95 timer set 0 EV_TIMEOUT_ENTERDATA
085245.28 95 event ScriptEventCode EV_TIMEOUT_ENTERDATA, code=9006, state=1301
085245.28 95 LsGetNbrsRxDigits EV_TIMEOUT_ENTERDATA,EV_TIMEOUT_ENTERDATA
085245.28 95 path {EV_TIMEOUT_ENTERDATA} not found
085245.28 95 timer clear
085245.28 95 rv add [PromptUser]{2}
085245.28 95 path {2} not found
085245.28 95 rvns add [PromptUser_PathTaken]{success}
085245.28 95 fn RunModule start
085245.28 95 tw DialogicEvent 134,TDX_CST,50,0,0,DE_DIGITS,,
085245.30 95 event ScriptEventCode TDX_CST, code=134, state=6001
085245.30 95 timer clear
085245.30 95 Play Module start
085245.30 95 state [Worked] Playing
085245.30 95 state [Worked] Playing ()
085245.30 95 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1100
085245.30 95 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
085245.30 95 path {EV_PLAY_FINISHED} not found
085245.31 95 timer set 5 EV_TIMEOUT_REPLAYMSG
085245.81 95 tw dtmf 5 (95,53,53)
085245.81 95 event ScriptEventCode 5, code=53, state=1101
085245.81 95 LsPlayMsgFinished 5,5
085245.81 95 path {5} not found
085245.81 95 tw DialogicEvent 134,TDX_CST,53,0,0,DE_DIGITS,,
085245.81 95 event ScriptEventCode TDX_CST, code=134, state=1101
085245.81 95 LsPlayMsgFinished EV_UNKNOWN_134,TDX_CST
085245.81 95 path {TDX_CST} not found
085246.48 95 tw dtmf # (95,35,35)
085246.48 95 event ScriptEventCode #, code=35, state=1101
085246.48 95 LsPlayMsgFinished #,#
085246.48 95 path {#} not found
085246.48 95 tw DialogicEvent 134,TDX_CST,35,0,0,DE_DIGITS,,
085246.48 95 event ScriptEventCode TDX_CST, code=134, state=1101
085246.48 95 LsPlayMsgFinished EV_UNKNOWN_134,TDX_CST
085246.48 95 path {TDX_CST} not found
085250.77 95 timer fired EV_TIMEOUT_REPLAYMSG
085250.77 95 event ScriptEventCode EV_TIMEOUT_REPLAYMSG, code=9005, state=1101
085250.77 95 LsPlayMsgFinished EV_TIMEOUT_REPLAYMSG,EV_TIMEOUT_REPLAYMSG
085250.77 95 path {EV_TIMEOUT_REPLAYMSG} not found
085250.77 95 state [Worked] Playing ()
085250.77 95 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1100
085250.77 95 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
085250.77 95 path {EV_PLAY_FINISHED} not found
085250.77 95 timer set 5 EV_TIMEOUT_REPLAYMSG
085256.25 95 timer fired EV_TIMEOUT_REPLAYMSG
085256.25 95 event ScriptEventCode EV_TIMEOUT_REPLAYMSG, code=9005, state=1101
085256.25 95 LsPlayMsgFinished EV_TIMEOUT_REPLAYMSG,EV_TIMEOUT_REPLAYMSG
085256.25 95 path {EV_TIMEOUT_REPLAYMSG} not found
085256.25 95 state [Worked] Playing ()
085256.25 95 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1100
085256.25 95 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
085256.25 95 path {EV_PLAY_FINISHED} not found
085256.25 95 timer set 10 EV_TIMEOUT_HANGUP
085256.27 95 rv add [Hangup Time]{31/10/2005 08:52:56}
085256.27 95 state Hanging up call... [no paths leaving play module [Worked]]
085256.27 95 HangupCall_Common hCall=95
085256.27 95 rec RecSoundStop ok
085256.27 95 play PlaySoundStop ok
085256.27 95 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
085256.27 95 fnHangupCall end
085258.45 95 timer fired EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
085258.45 95 event ScriptEventCode EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP, code=9101, state=900
085258.45 95 state Hanging up call...(2)
085258.45 95 HangupCall_Common hCall=95
085258.45 95 rec RecSoundStop ok
085258.45 95 play PlaySoundStop ok
085258.45 95 fnHangupCall end
085258.45 95 LsAwaitingCalls EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
085326.25 95 tw DialogicEvent 2137,GCEV_RELEASECALL,2137,0,0,,,
085326.25 95 event ScriptEventCode GCEV_RELEASECALL, code=2137, state=900
085326.27 95 LsAwaitingCalls EV_UNKNOWN_2137
085326.27 95 event callstate IDLE 95 1,0,0
085326.27 95 WorkingMode@Idle=
085326.27 95 timer clear
085326.27 95 rec RecSoundStop ok
085326.27 95 play PlaySoundStop ok
085326.27 95 rv add [CallEndTime]{31/10/2005 08:53:26}
085326.27 95 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
085327.34 95 timer fired EV_TIMEOUT_TIMETOREINITLINE
085327.34 95 event ScriptEventCode EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=900
085327.34 95 init atidle reinit : start
085327.34 95 init atidle reinit iConferenceOtherLegLid=-1
085327.34 95 init atidle reinit : reset all LineState variables
085327.34 95 timer set 0.3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
085327.34 95 state Waiting for a call...
085327.67 95 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
085327.67 95 event ScriptEventCode EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=900
Did you change the VG.INI file at all?
Please post your VG.INI file (as an attachment).
Also can you please try running the Credit Card Payment demo script. If you are getting similar jumps to next module after entering just one digit in each module in that script then it looks like the VG.INI was modified - and in this situation it's probably be just quickest if you just uninstall everything and re-install VG again from scratch.
Credit Card program did exactly the same.
I did change the VG.INI, but only on Friday to increase the interdigit timout etc.
Attached is the vg.ini file
Can i just copy the VG.INI file from the installation archive?
vg.ini
