Silencedetectlvl
As per recording details in the help file ive created an Evaluate Expression to disable silence detection and set it as the startup module. Evaluate is running, but Silence Detection is still occuring on my record file.
Script below:
Version=5.0
DefaultModuleDisplayHeight=
StartModule=Disable Silence
RunAtHangup=
StartWithoutAnswer=0
CtmAsiName=
[Record]
Type=Record
DispSize=69
Txt=Record a sound file, and go down different paths depending on what digit was pressed to terminate recording...
RecFile=recordings\$RV[uID].wav
PlayTone=ON
Position=417,615
[ChairPin]
Type=Get Numbers
DispSize=69
Txt=Play a prompt asking the caller to enter a sequence of numbers, speak the sequence back to the caller and ask them to confirm it. Go down different paths depending on the numbers entered...
PlayFile1=none
Replay=1,25
GetNbrLen_Min=0
GetNbrLen_Max=0
Confirm=OFF
VbScript=
VbsHoldPlay=
on {success} goto [Check#1]
Position=328,184
[uID]
Type=Get Numbers
DispSize=69
PlayFile1=none
Replay=1,25
GetNbrLen_Min=0
GetNbrLen_Max=0
Confirm=OFF
VbScript=
VbsHoldPlay=
on {success} goto [Record]
Position=325,492
[GetNumbers]
Type=Get Numbers
DispSize=69
PlayFile1=none
Replay=1,25
GetNbrLen_Min=0
GetNbrLen_Max=0
Confirm=OFF
VbScript=
VbsHoldPlay=
on {success} goto [ChairPin]
Position=146,63
[Check#1]
Type=Get Numbers
DispSize=69
Replay=2,5
GetNbrLen_Min=0
GetNbrLen_Max=0
Confirm=OFF
VbScript=
VbsHoldPlay=
on {fail} goto [uID]
Position=656,281
[Disable Silence]
Type=Evaluate
DispSize=69
Txt=Evaluate the Result Variable specified, and select the path which matches the current value of the Result Variable
Expression=0
ExprNewRV=SilenceDetectLvl
ExprStoreRV=0
ExprStoreInGlobalRV=1
on {0} goto [GetNumbers]
Position=53,231
Please update your system with attached OCX - placing it in Windows' System32 directory (replacing current file there).
If you still experience problems please post the log file MMDDtw.txt capturing the call (as an attachment, not quoted within the post text).
ktTelControl_051101b.zip
Worked a treat. Thanks very much for the exceptional support given.
Regards
David
