Mulitple Line Support
I'm looking for a Modem and Software to use on my WinXP computer where I can have 1-4 different phone lines coming in. Then the software plays a quick message then proceeds to play a .Wav File depending on what line they called in on. After the .wav file they are disconnected.
My ultimate goal it to allow clients to call in and listen to a high quality voice recording so they can see how good of quality the line is.
The reason I'm doing this is I'm using 4 different types of VoIP hardware to produce the phone lines.
I also need help deciding on what my options are for the modem. Do they make 4-Line Modems? Is there a 4-Port switch I can use to link into a Single Line Modem? I don't necessarily need all 4 lines to work at once.
