Guest jjfama Report post Posted 11/02/2005 08:06 PM Every now and then I get this runtime error causing the Voice Guide Script Designer to close. I often ignore it because I need to finish the script just the same. But sometimes it's just annoying when I'm in a hurry and need to get some things done. This happens when I edit the script. The Voiceguide Script Desginer version I'm using is version 5.2.5000 and the Runtime is version 5.2.5003. Thanks. VgGsd Run-time error '91': Object variable or With block variable not set Share this post Link to post
SupportTeam Report post Posted 11/02/2005 09:42 PM Do you know how to reproduce the error? Share this post Link to post
Guest jjfama Report post Posted 11/04/2005 05:01 PM No. The problem is that it often happens when I edit the script even simply moving modules triggers it at times. I can't pinpoint the actions that lead to it. I just start over on my most recent saved version. I'll check on it though. Share this post Link to post
