Setting Up System
Dominique wrote:
I would like to implement a system with 1 to 4 lines and in the near future 8 or 12 lines.
Should I buy D/4PCIUF card or D/41JCT-LS card ?
- which be able to receive calls, automatically call standard and mobile
telephone lines, automatically deliver messages to people,.
Which kind of VoiceGuide licenses should I buy ? Professional or Enterprise ?
Do I need to buy a dialer ?
If I buy a one line license, can I easily upgrade it to 4/8/12 lines?
And how much would this cost me ? Is it more expensive to do this rather
than to directly buy 4 or more line-license ?
- I want to go through Voip. I understand I should buy a Voip gateway.
With 4 lines, are there gateways recommended by Voiceguide ?
If I buy a VoIp router-modem, do I need to buy a VoIp gateway ?
Would this be easy to implement ?
Do you think it is better to have a tel box that Voip telephone companies
supply ?
Are there any Voip tel company that supply their services without their tel
boxes ? For info, I am located in France.
D/41JCT would only be needed if you will be doing "Dial and Conference", or would need to bridge (cross-connect) callers together on the system.
be able to receive calls, automatically call standard and mobile telephone lines, automatically deliver messages to people.
All that's fine.
Which kind of Voiceguide licenses should I Buy ? Professional or Enterprise ?
Up to you. See: http://www.voiceguide.com/vgFeatures.htm
Yes - as it looks like you will be making outbound calls.
Yes. Just buy additional licenses as needed.
And how much would this cost me ? Is it more expensive to do this rather than to directly buy 4 or more line-license ?
If you upgrade within the month you can upgrade for the difference in price. After that you can upgrade by just buying additional licenses as needed or see bottom of: https://secure.voiceguide.com/order_vg.htm
No, pretty much anything will work.
If I buy a VoIp router-modem, do I need to buy a VoIP gateway ?
Not usually - best to speak with your phone company though.
Are there any Voip tel company that supply their services without their tel boxes ? For info, I am located in France.
You will need to speak with your local phone companies.
Thanks for your swift answer. That's a pleasure.
I understand the Professional license would be fine for what I want to do.
With a view to better understanding, could you just let me know what the options "subscripts" and "ActiveX server" mean in the Enterprise license.
Thank you again
Dominique
"Subscripts" means that you can jump from one script to another midway though call.
"ActiveX server" means that VoiceGuide's COM interface functions can be called from other programs (or from within VoiceGuide's VBScripts)
