Guest Edmundo Report post Posted 11/07/2005 05:11 PM I'm Thinking I can set up a nice equipment for what I need, with 120 lines; so the specific cuestions I have are: 1.- Can the "Voice Guide (Katarina Technologies) (http://www.voiceguide.com) handle 120 lines as a software? 2.- Does the board: DM/V1200A-4E1 (Intel) Works for 120 lines and if it works whit no problem whit the "VoiceGuide" Software ? 3.- What else wold I need to integrate these software(VoiceGuide) and Hardware (DM/V1200A-4E1) (obviously ather than the computer and telefone lines). 4.- do I need a server? what is a CT Bus? do I ned one of does or does the board comes whit it? THANKS GUY! Share this post Link to post
SupportTeam Report post Posted 11/07/2005 07:55 PM 1.- Can the "Voice Guide handle 120 lines as a software? Yes. 2.- Does the board: DM/V1200A-4E1 (Intel) Works for 120 lines and if it works whit no problem whit the "VoiceGuide" Software Yes, that board is fine. 3.- What else wold I need to integrate these software(VoiceGuide) and Hardware (DM/V1200A-4E1) (obviously ather than the computer and telefone lines). Nothing else apart from what you mention above. 4.- do I need a server? what is a CT Bus? do I ned one of does or does the board comes whit it? You can run the system on any computer - whether you choose to use a basic PC (eg DELL SC430) or a Server class PC is up to you. A CT bus is used to interconnect various cards together. The DMV1200 cards have it - but looks like you would not be using it as it does not sound like you'll have other cards in the system. Share this post Link to post
