Guest David Report post Posted 11/07/2005 09:52 PM Hi There. Anyone know of a way to pass inbound calls off to a fax server? And if so, does anyone know of any fax software that we could run with our Dialogic D600JCT's? regards David Share this post Link to post
Guest David Report post Posted 11/07/2005 10:00 PM Didnt make that quite clear. we use a startup.vgs script which diverts to different scripts based upon the DNIS. I have tendered for a service which needs to answer the line and treat the call as a fax call ( ie, whistle and beep down the line) regardless of whether its a fax or voice call. I assume I just pass off to a VB module to handle the inbound fax, but what software can I use? my Dialogic cards support fax, but i dont think theres any way to get VG to use it ? Thanks David Share this post Link to post
SupportTeam Report post Posted 11/07/2005 11:02 PM The usual way is to have the calls transferred to a fax machine - but if you need to be able to receive many faxes simultaneously then the Dialogic card with fax software would be the way to go. Can't recommend any fax software - best to just Google around for that one. VoiceGuide can be setup to use just some of the ports on the Dialogic card - leaving other for use by fax software - but then routing of calls to fax channels would need to be made by the Phone company or your PBX... And if you have a PBX then you may want to just route calls to another separate fax-only system. In theory you could start a fax application to take over a Dialogic port when fax call is detected, but we have not heard of any fax software that can do this. Share this post Link to post
