Dialer_makecall
I am attempting to use the Dialer_MakeCall to make an internal call and then transfer this to an outside number.
I would like the internal operator to be able to pickup the call and be greeted by the sound of the outbound call ringing and awaiting an answer.
I am using the sample you provided in the help files,
vg.Dialer_MakeCall "XXX", "dxxxB2C3", "", "c:\progra......vgs"
set vg = Nothing
I am using both a D/4PCI and a D/4PCI-U card, 4 lines each, which I understand cannot be bridged.
So I assumed could:
1)Use vg.Dialer_MakeCall to call an internal extension & receive back the lineid the internal call was made on
2)Use this line ID to make a Result return variable containing the outbound number
for the script nominated in Dialer_MakeCall to transfer to.
This works fine when i put my mobile number directly into the transfer module.
However when i try and use a VG Variable (result returned in the 2nd step above to lineID 5 which was as the line the internal call was being made on), voiceguide states that it is ignoring the returned information as the line id is probrably incorrect?
What Am I doing wrong?
It must be in the result return even though I am result returning to the line ID that i was returned by VG?
131804.97 0 cl Dialer_MakeCall 310, dxxxB1C1, , C:\Program Files\VoiceGuide\Scripts\VGAutoDialTest.vgs
131804.97 0 Search for free lines in range [5-12]
131804.98 5 Calling 310
131804.98 5 TimeoutSet 3600 EV_TIMEOUT_HANGUP
131805.16 5 cl Run_ResultReturn >>[ToCall]{XXXXXXXXXX}<<
131805.16 5 cl Run_ResultReturn hCall=0 - ignoring returned information (Note: iLineId is probably incorrect, please check this in calling code.)
131805.53 5 tapi Reply (LineEvReply) ok 66426 0
131805.53 5 linedevstate 2048 0 0
131805.53 5 callstate DIALTONE 66185 0 0
131805.53 5 callstate DIALING 66185 0 0
131805.53 5 callstate PROCEEDING 66185 0 0
131805.53 5 callinfo CALLEDID
131805.53 5 callinfo REASON
131805.53 5 Lev_CallerID [0000,]
131805.53 5 callinfo ORIGIN
131812.45 5 callstate CONNECTED 66185,1,0
131812.45 5 WorkingModeTAPI@Connected=
131812.45 5 WorkingModeScript@Connected=
131812.50 5 rv add [$RV_STARTTIME]{8/11/2005 1:18:12 PM}
131812.53 5 rv add [$RV_DEVICEID]{5}
131812.55 5 rv add [$RV_CIDNAME]{}
131812.58 5 AddRVns [PathApp]{C:\Program Files\VoiceGuide\}
131812.59 5 rv add [$RV_CALLEDNUMBER]{310}
131812.63 5 AddRVns [OutDial_Result]{Contacted_Human}
131812.64 5 Live person answered, starting C:\Program Files\VoiceGuide\Scripts\VGAutoDialTest.vgs
131812.67 2 tr NewVgsVgm_Goto C:\Program Files\VoiceGuide\Scripts\VGAutoDialTest.vgs,,,,,0
131812.69 5 rv add [scriptEnd_Time]{8/11/2005 1:18:12 PM}
131812.72 5 rv add [scriptEnd_Goto_Script]{C:\Program Files\VoiceGuide\Scripts\VGAutoDialTest.vgs}
131812.75 5 rv add [scriptEnd_Goto_Module]{}
131812.77 5 rv add [scriptStart_Time]{8/11/2005 1:18:12 PM}
131812.80 0 LoadedVgs_Find C:\Program Files\VoiceGuide\Scripts\VGAutoDialTest.vgs at idx=4
131812.81 5 AddRVns [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\}
131812.84 5 cl NewVgsVgm_RunModule module not found:
131812.86 2 tr NewVgsVgm_Goto 1
131812.89 2 tr NewVgsVgm_Goto 2
131812.92 5 TimeoutClear
131812.94 5 TimeoutSet 0.4 EV_TIMEOUT_READYTOBEGINTRANSFER
131812.97 2 tr NewVgsVgm_Goto end
131813.36 5 Timer fired EV_TIMEOUT_READYTOBEGINTRANSFER
131813.38 5 ScriptEventCode 9012 iLineState=1900
131813.41 5 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER
131813.42 5 TimeoutSet 30 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
131813.45 5 RVreplace start: [$RV[ToCall]]
131813.47 5 RVns [OutDial_Result]{Contacted_Human}[scriptEnd_Time]{8/11/2005 1:18:12 PM}[scriptEnd_Goto_Script]{C:\Program Files\VoiceGuide\Scripts\VGAutoDialTest.vgs}[scriptEnd_Goto_Module]{}[scriptStart_Time]{8/11/2005 1:18:12 PM}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\}
131813.50 5 RVreplace end: []
131813.52 5 [TransBen] Blind Transfer to (Generate)
131813.56 5 tapic lineGenerateDigits(66185,!,0) => 0
131813.94 5 generate LINEGENERATETERM_DONE
131813.97 5 TimeoutSet 1 EV_TAPI_GENERATE
131815.00 5 Timer fired EV_TAPI_GENERATE
131815.02 5 ScriptEventCode 9602 iLineState=1900
131815.05 5 LsXferStart EV_TAPI_GENERATE
131815.06 5 TimeoutSet 1 EV_HOOKFLASHFINISHED
131816.19 5 Timer fired EV_HOOKFLASHFINISHED
131816.20 5 ScriptEventCode 9200 iLineState=1905
131816.23 5 LsXferPlayVts EV_HOOKFLASHFINISHED
131816.25 5 ScriptEventCode 9602 iLineState=1905
131816.28 5 LsXferPlayVts EV_TAPI_GENERATE
131816.30 5 TimeoutSet 3 EV_TIMEOUT_HANGUP
131819.61 5 Timer fired EV_TIMEOUT_HANGUP
131819.63 5 ScriptEventCode 9001 iLineState=1905
131819.66 5 LsXferPlayVts EV_TIMEOUT_HANGUP
131819.67 5 rv add [Hangup Time]{8/11/2005 1:18:19 PM}
131819.70 5 Hanging up call...
131819.72 5 RecSoundStop ok
131819.75 5 PlaySoundStop err=0
131819.78 5 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
131819.80 5 fnHangupCall end
131819.84 5 linedevstate 2048 0 0
131819.88 5 callstate IDLE 66185 0 0
131819.89 5 WorkingMode@Idle=
131819.92 5 TimeoutClear
131819.94 5 TimeoutSet 1 EV_TIMEOUT_TIMETOREINITLINE
131819.97 5 tapi Reply (LineEvReply) ok 66028 0
131820.97 5 Timer fired EV_TIMEOUT_TIMETOREINITLINE
131820.98 5 ScriptEventCode 9008 iLineState=900
131821.02 5 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
131821.03 5 ReinitTelephony due to IDLE
131821.06 5 tapic lineDeallocateCall(MainCall:66185) 0
131821.23 5 lineOpen(5)=>
131821.25 5 Waiting for a call...
131821.28 5 LineHandle=65706
131821.30 5 TimeoutSet 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
131824.61 5 Timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
131824.63 5 ScriptEventCode 9013 iLineState=900
131825.55 5 linedevstate 2048 0 0
131825.56 5 callstate OFFERING 65815 0 4
131825.59 5 Answer the call at 8/11/2005 1:18:25 PM
131825.63 5 lineAnswer(65815) => 66341
131825.64 5 callinfo CALLEDID
131825.67 5 callinfo ORIGIN
131825.69 5 ring 0
131826.17 5 callstate CONNECTED 65815,1,0
131826.19 5 WorkingModeTAPI@Connected=
131826.22 5 WorkingModeScript@Connected=
131826.23 5 Inband detection start (7 patterns loaded)
131826.27 5 TimeoutSet 5 EV_TIMEOUT_INBANDSIGNAL_INTERDIGIT
131826.28 5 tapi Reply (LineEvReply) ok 66341 0
131826.31 5 callinfo MONITORMODES
131826.34 5 dtmf * (65815,42,2)
131826.36 5 ScriptEventCode 42 iLineState=4100
131826.39 5 LsIndialSignalCapture *
131826.41 5 TimeoutSet 0.5 EV_TIMEOUT_INBANDSIGNAL_INTERDIGIT
131826.47 5 dtmf * (65815,42,2)
131826.50 5 ScriptEventCode 42 iLineState=4100
131826.52 5 LsIndialSignalCapture * *
131826.55 5 TimeoutSet 0.5 EV_TIMEOUT_INBANDSIGNAL_INTERDIGIT
131826.64 5 dtmf 9 (65815,57,2)
131826.67 5 ScriptEventCode 57 iLineState=4100
131826.70 5 LsIndialSignalCapture 9 **
131826.72 5 TimeoutSet 0.5 EV_TIMEOUT_INBANDSIGNAL_INTERDIGIT
131826.86 5 dtmf * (65815,42,2)
131826.88 5 ScriptEventCode 42 iLineState=4100
131826.91 5 LsIndialSignalCapture * **9
131826.92 5 TimeoutSet 0.5 EV_TIMEOUT_INBANDSIGNAL_INTERDIGIT
131827.05 5 dtmf * (65815,42,2)
131827.06 5 ScriptEventCode 42 iLineState=4100
131827.09 5 LsIndialSignalCapture * **9*
131827.13 5 TimeoutSet 0.5 EV_TIMEOUT_INBANDSIGNAL_INTERDIGIT
131827.22 5 dtmf 3 (65815,51,2)
131827.25 5 ScriptEventCode 51 iLineState=4100
131827.28 5 LsIndialSignalCapture 3 **9**
131827.30 5 TimeoutSet 0.5 EV_TIMEOUT_INBANDSIGNAL_INTERDIGIT
131827.41 5 dtmf 1 (65815,49,2)
131827.42 5 ScriptEventCode 49 iLineState=4100
131827.45 5 LsIndialSignalCapture 1 **9**3
131827.48 5 TimeoutSet 0.5 EV_TIMEOUT_INBANDSIGNAL_INTERDIGIT
131827.61 5 dtmf 0 (65815,48,2)
131827.63 5 ScriptEventCode 48 iLineState=4100
131827.66 5 LsIndialSignalCapture 0 **9**31
131827.69 5 TimeoutSet 0.5 EV_TIMEOUT_INBANDSIGNAL_INTERDIGIT
131827.80 5 dtmf * (65815,42,2)
131827.83 5 ScriptEventCode 42 iLineState=4100
131827.84 5 LsIndialSignalCapture * **9**310
131827.88 5 TimeoutSet 0.5 EV_TIMEOUT_INBANDSIGNAL_INTERDIGIT
131827.98 5 dtmf 1 (65815,49,2)
131828.00 5 ScriptEventCode 49 iLineState=4100
131828.03 5 LsIndialSignalCapture 1 **9**310*
131828.05 5 TimeoutSet 0.5 EV_TIMEOUT_INBANDSIGNAL_INTERDIGIT
131828.52 5 Timer fired EV_TIMEOUT_INBANDSIGNAL_INTERDIGIT
131828.53 5 ScriptEventCode 9011 iLineState=4100
131828.56 5 LsIndialSignalCapture EV_TIMEOUT_INBANDSIGNAL_INTERDIGIT
Bla Bla Bla,
I Just noticed in the trace that I am attempting to supply the result variable back to VG before it has recognised that there is a call on this line.
So I have tried to use the
vg.Line_state in a loop to wait and see when the line is no longer idle, But it seems that the linestate is not supported by the version I am using? Can I use Line_State from a vbscript in BG 5.2.1011
Try using $RV_CALLSTATE - if that does not work in v5.2.1011 then update the installed VG to latest v5.x version.
If you require more assistance with your script(s) please post the actual script(s) which you are using.
Sorry,
I should have elaborated, I am actually trying to query the line state from vb on an .asp page.
Can I not use some form of command like
linestate = vg.Line_State(5)
Line_State COM function should work.
The trace provided before did not show this function being called though...
Have you tried calling this COM function from a VBScript instead of from an ASP page?
