Run Module & Evaluate Module
I run a program that returns a file called SHLRESLT.TXT . It writes $RV[successVal]{10} to that file.
I then use a evaluate module to decide which path to take. I think this is where I am going wrong, althoug I have tried everything I can think of.
Here is that portion of script. How do I get my variable's value into $RV[successVal] and branch accordingly.
[Run Program 1]
Type=Run Program
DispSize=69
Txt=Run the program, and read in the results file created. The results supplied can then be used in other parts of the script (see Result Variables).
ProgramToRun=C:\Program Files\WatchDog\VGWDVal.exe
RunHoldPlay=
RunMode=1
RunWait=1
on {success} goto [Evaluate1]
on {fail} goto [Evaluate1]
Position=267,42
[Evaluate1]
Type=Evaluate
DispSize=69
Txt=Evaluate the Result Variable specified, and select the path which matches the current value of the Result Variable
Expression=$RV[successVal]
ExprNewRV=
ExprStoreRV=0
ExprStoreInGlobalRV=0
on {11} goto [successit]
on {10} goto [FailedIt]
This is the relevent part of the trace
223954.30 6 Found result file: C:\Program Files\WatchDog\SHLRESLT.TXT
223954.30 6 rv lg add [Run Program 1]{}
223954.30 6 Run Result [$RV[successVal]{10}, ]
223954.30 6 task completed LsRunWaitChooseNext iNextVgm=7
223954.30 6 timer clear
223954.30 6 state [Evaluate1] Evaluate [$RV[successVal]]
223954.30 6 rv replace start: [$RV[successVal]]
223954.30 6 rv ns [PathSysVoice]{}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[DNIS]{0000}[scriptsPath]{C:\Program Files\WatchDog\}[scriptPath]{C:\Program Files\WatchDog}[$RV_STARTTIME]{11/7/2005 10:39:42 PM}[$RV_DEVICEID]{6}[$RV_CIDNAME]{VIKING ELECTRON}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{7153868861}[$RV_DNIS]{0000}[DNIS]{0000}[Run Program 1]{}
223954.30 6 rv replace end: []
223954.31 6 .Eval()
223954.31 6 rv ns add [Evaluate1_Input]{}
223954.31 6 rv ns add [Evaluate1]{}
223954.31 6 Eval Expr result:[]
223954.31 6 path {} not found
The answer for those who want to know is that the Result File should contain:
[successVal]{10}
and not:
$RV[successVal]{10}
