Delay In Responce
I am using your software, with a dialogic pci/4 and i have about 30sec, of delay when i use it to dial out. pls what am i doing wrong?
Could you please post a copy of VoiceGuide's Debug Printout which captures the outgoing call, this will allow us to see what happened.
When running the script click on VoiceGuide's View menu and select 'Event Trace Log' option - any log information will then appear in this window. You must open the trace window before making the call. You can enable the automatic saving of the logs to files in \log\ directory as well. When posting traces please .ZIP them up and post them as attachments.
