Guest researcher Report post Posted 11/10/2005 05:24 PM My modem is softk56 data fax voice speakerphone with good voice quality. I am testing it from single line and picking up the same receiver to enter number. When I enter any single digit then the modem hangs up. But same script is running on the same modem on a diffferent office PC. Both PCs are having windowsXP. Kindly read the log below and help me please. LOG is given below 223429.89 0 sys cleanup Start 223429.91 0 sys cleanup End 223453.89 0 callstate OFFERING 66099 0 4 223453.92 0 Start without answering the call 223453.94 0 StartLoadedVgs at 11/10/2005 10:34:53 PM 223453.94 0 AddRVns [scriptsPath]{D:\VoiceGuide\KuanYinScripts\} 223453.95 0 AddRVns [scriptPath]{D:\VoiceGuide\KuanYinScripts} 223453.95 0 rv add [$RV_STARTTIME]{11/10/2005 10:34:53 PM} 223453.95 0 rv add [$RV_DEVICEID]{0} 223453.95 0 rv add [$RV_CIDNAME]{} 223453.95 0 AddRVns [PathApp]{D:\Program Files\VoiceGuide\} 223453.95 0 rv add [$RV_CIDNUMBER]{} 223453.97 0 ring 1 223453.97 0 timer clear 223453.97 0 [Welcome] Number Input 223453.97 0 lineAnswer(66099) => 66082 223453.98 0 callstate ACCEPTED 66099 0 0 223454.03 0 tapi Reply (LineEvReply) ok 66082 0 223454.05 0 callstate CONNECTED 66099 0 0 223454.05 0 callstate CONNECTED 66099,0,0 223454.05 0 WorkingModeTAPI@Connected= 223454.06 0 WorkingModeScript@Connected=BeforeAnswerRun 223454.06 0 Inband detection not enabled 223454.06 0 timer clear 223454.06 0 [Welcome] Number Input 223454.08 0 [Welcome] Playing (d:\VoiceGuide\AmitabhaSoundFiles\SeekDonateUpdate.wav) 223454.08 0 play set playid=552640 223454.39 0 PlaySoundStart ok [d:\VoiceGuide\AmitabhaSoundFiles\SeekDonateUpdate.wav] 223454.39 0 timer clear 223454.39 0 wa(17747,55264000) 223459.44 0 dtmf 1 (66099,49,2) 223459.44 0 ScriptEventCode 49 iLineState=1300 223459.47 0 LsGetNbrsPlayWelcMsg 1 223500.20 0 PlaySoundStop err=0 223500.20 0 [Welcome] Number Input 1 223500.20 0 rv add [Welcome]{1} 223500.23 0 callstate DISCONNECTED 66099 1 0 223500.23 0 ScriptEventCode 9250 iLineState=5900 223500.23 0 rv add [Hangup Time]{11/10/2005 10:35:00 PM} 223500.23 0 Hanging up call... [LsModuleTransition] 223500.25 0 RecSoundStop ok 223500.25 0 PlaySoundStop err=0 223500.25 0 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 223500.28 0 fnHangupCall end 223500.28 0 ERROR RunModule called while iHangupCalledForThisLine>0 (strWorkingModeScript=) 223500.48 0 callstate IDLE 66099 0 0 223500.48 0 WorkingMode@Idle= 223500.48 0 timer clear 223500.52 0 timer set 1 EV_TIMEOUT_TIMETOREINITLINE 223500.52 0 tapi Reply (LineEvReply) ok 66065 0 223501.56 0 timer fired EV_TIMEOUT_TIMETOREINITLINE 223501.56 0 ScriptEventCode 9008 iLineState=900 223501.56 0 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE 223501.56 0 ReinitTelephony due to IDLE 223501.56 0 tapic lineDeallocateCall(MainCall:66099) 0 223501.81 0 lineOpen(0)=> 223501.81 0 Waiting for a call... 223501.81 0 LineHandle=66048 223501.81 0 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT 223502.28 0 dial start any summary:|0:rdy=0| 223503.28 0 dial start any summary:|0:rdy=0| 223504.28 0 dial start any summary:|0:rdy=0| 223505.25 0 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT 223505.25 0 ScriptEventCode 9013 iLineState=900 224058.84 0 Unloading Main Window 1110tw.txt Share this post Link to post
SupportTeam Report post Posted 11/11/2005 02:40 AM When I enter any single digit then the modem hangs up Trace shows modem has reported hearing the Disconnect tone - and informs VoiceGuide that the call has ended. This is a common problem with 'Soft' and 'Win' modems. The only solution is to try another modem or get a Dialogic card. Share this post Link to post
Guest researcher Report post Posted 11/11/2005 09:58 AM Thanks for the reply. But I wonder why it works on a different PC and the same modem. Does it mean that I require to update OS or modem drivers? Kindly advice. Share this post Link to post
SupportTeam Report post Posted 11/11/2005 10:07 PM But I wonder why it works on a different PC and the same modem. Is the same phone line plugged into the modem when it is used on another PC? Was the call made from the same phone? Does it mean that I require to update OS or modem drivers? Updating the OS would not have any effect on how the modem detects disconnect tones, but updating the modem drivers may have an effect. Share this post Link to post
Guest researcher Report post Posted 11/12/2005 09:58 AM The modem which worked on a different PC was Intex Internal modem. And the telephone line is different. I will test the case under similar conditions and then report. Share this post Link to post
