Full Path Of Sound File
I have a number of VG scripts that I run at differant times through out the year. I have the scripts located like this: C:\Phone Scripts\Script1\xxx.vgs ; C:\Phone Scripts\Script2\xxx.vgs ; C:\Phone Scripts\Script3\xxx.vgs etc... I had all my sound files in C:\Phone Scripts\Sound Files\xxx.wav. Then I put a sound folder in each Scriptx folder and placed all the .wavs for that script in the sound folder. Now when I open a Play module in a xxx.vgs and use the select to find the .wav file, the path text box does not have a full path in it. The path box should have : C:\Phone Scripts\Scriptx\Sound Files\xxx.wav, but what I get is Sound Files\xxx.wav and if I try to use the sound file it fails. If I move the Sound Files folder outside of the Scriptx folder then I get the full path. Why is this?
If the sounds files are located in the same directory or sub-directory of the script then a relative path will be used.
The playing of the sound file should still work... when are you seeing the file not playing?
I have noticed this also and the problem is also that if you want to check the file while in the script editor, it does not play the sound file. I always had to change each path and put in the full path, then everything would work
Attached Script Designer should fix this bug.
This Script Designer is to be used on v5.x systems only. The "VG for Dialogic" Script Designer will follow.
VgGsd_5.2.5001.zip
I downloaded the new Script Designer and that fixed the problem.
Thanks for your help.
