Extension Transfer
Hello, we are just starting with katalina software.
I am currently setting up a script and need a little help.
scenario....
a caller calls in....
prompt plays "dial the extension of person, press * for voice mail, press # for spell by name"
I got the * for voice mail done.
I got the # for spell by name done.
But I do not understand how any extension can be hit there and the call will be transferred to the appropriate extension. extensions go from 400 to 540.
All help is greatly appreciated.
thank you,
victor santoro
dirad technologies
Please post the script you are using and indicate at which stage you'd like to give the caller the option of entering the extension number. We can then better comment on in what ways this can be done.
(Post as attachment, please don't quote the script in the post itself)
hi, thanks , i got it to work.
one more problem.
i want to use # to send caller to spell by name, is this possible.
when i use the
on {#} goto [spellbyname] path the # does not work, if i change it to * it works fine.
ok, found the answer for that also. couple more issues.
1st. using spell by name feature, numbers are not accepted very good, sometimes it takes 2 or 3 numbers , sometimes it takes 1 or 4 unless you go really slow.
2nd. is there a voicemail administration box ?
3rd. how do i use broadcast messages.
thanks,
vic
and another thing, how can I make it so if a caller calls , they hit a mailbox number, and they get transferred directly to that mailbox, i will have 150 users/mailboxes, do not want to create 150 seperate entrys on the script.
this system is for a large client, can someone please respond to this, this may lead to alot more sales for voiceguide.
come on support ! pick it up a notch!
The 'Spell By Name' function asks to enter the first 4 characters of the name before looking for a match, (see aaFindUser.vgs in VG's \system\vm\ subdirectory)so I'm not sure what you're referring to when you say that sometimes you enter 1,2 or 3 numbers. Please describe in mode detail what the actual problem is, and provide a Debug Trace capturing the problem.
There is a voicemail manger application. See this entry of the Help file: http://www.voiceguide.com/vghelp/html/vmSy...stemManager.htm
At which point are you experiencing difficulties?
Use a single path like this from the Get Numbers module:
on [success] goto [$RV[Module's name Goes Here]]
More info on RVs can be found here: http://www.voiceguide.com/vghelp/html/Resu...ltVariables.htm
Replies to questions in forum are made on a 24 hour turnaround basis (quite often they are answered sooner then that)
Thank you for the response.
I know about the voicemail manager application, ive created 150 vm boxes using it, is there an admin box that can be logged into via the phone to administer other boxes?
I am still fuzzy on the RV thing, when i was transferring to extensions I used $RV TranstoExt and it worked fine.
what would I use to transfer to vm instead of extensions.
thanks,
victor santoro
ok, i got everything working except one thing.
the SpellName .
currently a call comes in, they press # to use spellname, they input last name of person, it checks list , matches up name with extention, now from here it has to send the caller to the appropriate VoiceMail (not extension) Box.
Can you please tell me how to do this.
thanks.
You'll need to modify the aaFindUser.vgs script. (in VG's \system\vm\ subdirectory)
Have a look at module FindVmByName and how it works.
We can create a modified version for you - send an email to sales@voiceguide.com for a quote.
another couple questions....
Is it possible to send an email to a person, but NOT attach the .wav file to the email? Instead, we could just send an email with something like, ‘You have a new voice mail’ in the subject line.
Does the spell by name code look for the user’s first name? Jeevan thought it did. Is this a definite? If so, can it be changed to look at last name?
I have sent an email requesting quote for script change. please let me know as soon as possible.
thanks,
victor santoro
In VG.INI file, section [Voicemail], set:
ForwardVmEmail_IncludeWavFile=0
The spell will match starting characters of whatever is entered in the 'Name' field. If you'd like to match by surname then just enter the surname before the 'first name' in the Name field.
thank you very much for all the help..
one more thing,
can you tell me where the findvmbyname module is?
thanks,
victor
also....
for the spell name feature, what kind of handling is there for duplicate entries ?
i have a few duplicate voicemail boxes, we are using the spell name feature to send callers directly to voicemail.
See aaFindUser.vgs in VG's \system\vm\ subdirectory
The entries matched will be listed, with caller asked to press 1, 2 or 3 etc... sounds like you have not tried testing it yourself yet(?)
"The entries matched will be listed, with caller asked to press 1, 2 or 3 etc... sounds like you have not tried testing it yourself yet(?) "
yes, we did test it, when i posted that we had not got that far yet, we now got it to work.
how do i send broadcast messages to voicemails ?
Have you had a look at 'Distribution Lists' ? Sending a message to a 'List' will broadcast/send the message to all the mailboxes in the list.
