Guest Guest_Peter Report post Posted 11/14/2005 10:27 PM We are new at this. But we would like to use Meridian Norstar with voiceguide to create a autodialer. Please, help with steps of accomplishing this. Thanks in advance, Share this post Link to post
SupportTeam Report post Posted 11/14/2005 10:58 PM Just attach analog extensions from the PBX to the ports on the Dialogic card which is controlled by VoiceGuide. See here for a list of Dialogic cards: http://www.voiceguide.com/suppRecomHardware.htm Share this post Link to post
Guest Guest_Peter Report post Posted 11/15/2005 12:20 AM Will this be able to do extension transfer i.e. when press 0 to be connected to the operator? Share this post Link to post
SupportTeam Report post Posted 11/15/2005 12:38 AM Should be no problem. Pretty much all PBXs support hookflash transfers. And if it does not then you can always use a "Dial and Conference" type transfer... See: http://www.voiceguide.com/vghelp/html/modXfer.htm Share this post Link to post
peterphan Report post Posted 11/15/2005 12:57 AM Do I need to purchase a 0x8 Norstar Analog Station Module (ASM) for the meridian? When you talked about the "analog extension" is that like faxes, modem? Share this post Link to post
SupportTeam Report post Posted 11/15/2005 01:35 AM There are two ways to do this: 1. Get a Dialogic D/82JCT card (Meridian Norstar model) and connect it to the PBX's digital extensions which normally just plug into the Nortel digital handsets. 2. Get analog card fro the PBX and use an analog Dialogic board. Option 1 will let the VoiceGuide system receive CallerID and information display messages from the PBX as well - so it's usually the better choice - especially if you do not have spare analog lines to which an analog Dialogic card can be attached. Share this post Link to post
