Meridian Norstar
We are new at this.
But we would like to use Meridian Norstar with voiceguide to create a autodialer.
Please, help with steps of accomplishing this.
Thanks in advance,
Will this be able to do extension transfer i.e. when press 0 to be connected to the operator?
Do I need to purchase a
0x8 Norstar Analog Station Module (ASM) for the meridian?
When you talked about the "analog extension" is that like faxes, modem?
There are two ways to do this:
1. Get a Dialogic D/82JCT card (Meridian Norstar model) and connect it to the PBX's digital extensions which normally just plug into the Nortel digital handsets.
2. Get analog card fro the PBX and use an analog Dialogic board.
Option 1 will let the VoiceGuide system receive CallerID and information display messages from the PBX as well - so it's usually the better choice - especially if you do not have spare analog lines to which an analog Dialogic card can be attached.
