Convert Dtmf To String
Thanks for the reply but I should have made myself little more clear. Suppose the number entered is 656667 then its ASCII is A, B & C. Can I store ABC in a result variable? How? I want to do that. Please guide.
If you want to run a conversion routine to convert entered 2-char DTMF codes into letters of the alphabet using ASCII-encoding conversion then you'll need to do this in a VBScript module.
We could create this VBScript for you. Send an email to sales@vocieguide.com if you'd like to get a quote on this work.
