Caller Id Callerid Not Appearing D4pciu Dialogic
Hello, we have 4 lines where the caller id shows in a regular caller id device but is not coming across to VG, we use 5.2 and worked fine in a regular modem/fax using version 5.2. We are in USA in Iowa using analog lines. What can I do to help determine why caller id is not being detected.
Do you know in what format the CallerID information is sent by the phone company?
You may want to try using VG for Dialogic and see if you get better results - that versions also has better debug tracing letting you better see what information is actually sent by the phone company.
I am not sure the format it is in. What is VG for Dialogic, I tried looking under downloads but did not find it, only some patch for it. After you tell me where it is, since I have VG 5.2 installed and working ok for months, how do I install the VG for dialogic in that PC properly from 5.2 to the new version you are suggesting.
Thank You
Download the "VG for Dialogic" patch.
This will convert an existing v5.2 install into "VG for Dialogic".
After unzipping the patch read the Readme.txt file.
