The Counter
Hello,
I have found out the counter doesn’t reset to 0 with new call. It will add the provous Result Verible in prevous call to the next call however the result verible is set to 0 for new call.
Please see log file attached for two calls I made. in The first call, the counter's result verible is end with 34, and the second call start the result verible from 34.
I have labeled the log file for you quick review.
thanks for your help.
log.zip
What module should we be looking at and what is counter's name?
Please post a script which we can use to demonstrate/test the behavior you describe.
For some reason it is working now. I can't understand why the script behaved like this.
Thank for you quick response.
