Guest Eduardo Valdez Report post Posted 11/17/2005 06:37 PM I have VG 5.2.5012 installed on my system, I whant to controll the number of rings when transfering a call. I read the help file and it says that I have to alter the ConfigLine and Config xml files. (is that correct?) Then I notice that I do not have those files so I tried to intall the update of VoiceGuide to the "for Dialogic" version, while doing so I followed all the steps on the readme file but when I try to register the ktTelControl.ocx a window pops up saying (LoadLibrary("ktTelControl.ocx") failed - the specified module could not be found.) Share this post Link to post
Guest Guest Report post Posted 11/17/2005 09:55 PM Eduardo, Do you have a dialogic T1 board in your system ? (24 channel t1) ? Share this post Link to post
SupportTeam Report post Posted 11/17/2005 11:01 PM I want to controll the number of rings when transfering a call. The rings cannot be counted but you can set the maximum time for which the call transfer will be attempted. Just use a Timeout path in the call transfer module. Share this post Link to post
