Hookflash And Hang Up
vg is a great software, but i have a Problem
we use voicemodem and pbx, my pbx can set hookfash time 0.3 0.4 ..... 1 second, i can hearing the hold music ,The first Play module contain the hookflash, and the next module contain the DTMF string. i use a Timeout path to link the two modules together but vg do not play next play dtmf module, it hang up the call.
why, i think the dtmf play ,this call can be transfer.
190002.09 0 state [Play 1] Playing
190002.09 0 state [Play 1] Playing (C:\Program Files\VoiceGuide\system\voice\15.wav)
190002.09 0 play set playid=197312
190002.55 0 PlaySoundStart ok [C:\Program Files\VoiceGuide\system\voice\15.wav]
190002.55 0 timer clear
190002.55 0 RunModule PLAY end
190003.27 0 play end current play (playid=197312)
190003.28 0 ScriptEventCode 8001 iLineState=1100
190003.28 0 LsPlayMsg EV_PLAY_FINISHED
190003.28 0 timer set 10 EV_TIMEOUT_HANGUP
190003.28 0 timer set 1 EV_TIMEOUT_GOTOMODULE
190004.27 0 timer fired EV_TIMEOUT_GOTOMODULE
190004.27 0 ScriptEventCode 9002 iLineState=1101
190004.27 0 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
190004.27 0 rv lg add [Play 1]{timeout}
190004.27 0 timer clear
190004.27 0 state [Play2] Playing
190004.27 0 tapic lineGenerateDigits(66213 [!] 100) => ok
190004.28 0 RunModule PLAY end
190004.78 0 generate LINEGENERATETERM_DONE
190004.78 0 timer set 1 EV_TAPI_GENERATE
190005.81 0 timer fired EV_TAPI_GENERATE
190005.81 0 ScriptEventCode 9602 iLineState=1100
190005.81 0 LsPlayMsg EV_TAPI_GENERATE
190005.81 0 timer set 10 EV_TIMEOUT_HANGUP
190005.81 0 timer set 5 EV_TIMEOUT_GOTOMODULE
190005.81 0 tapi callstate start
190005.83 0 tapi callstate DISCONNECTED 66213 1 0
190005.83 0 ScriptEventCode 9250 iLineState=1101
190005.83 0 LsPlayMsgFinished EV_REMOTEPARTY_DISCONNECT
190005.83 0 rv lg add [Hangup Time]{2005-11-21 19:00:05}
190005.83 0 state Hanging up call...
190005.83 0 RecSoundStop ok
190005.84 0 PlaySoundStop err=0
190005.84 0 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
190005.84 0 fnHangupCall end
190006.78 0 tapi callstate start
190006.78 0 tapi callstate IDLE 66213 0 0
190006.78 0 WorkingMode@Idle=
190006.80 0 timer clear
190006.84 0 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
190006.86 0 tapi Reply (LineEvReply) ok 66127 0
190007.84 0 timer fired EV_TIMEOUT_TIMETOREINITLINE
190007.84 0 ScriptEventCode 9008 iLineState=900
190007.84 0 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
190007.84 0 ReinitTelephony due to IDLE
190007.84 0 tapic lineDeallocateCall(MainCall:66213) 0
190008.13 0 lineOpen(0)=>
190008.13 0 state Waiting for a call...
190008.13 0 LineHandle=66248
190008.13 0 amchk set AMdet=False in Reinit@idle
190008.13 0 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
190008.55 0 dial start any summary:|0:rdy=0|
190011.41 0 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
190011.41 0 ScriptEventCode 9013 iLineState=900
190011.56 0 dial start any summary:|0:idx=0|
Regards,
About a second after playing the hookflash the modem informs VoiceGuide that the call has been disconnected:
You'd need to speak with the modem manufactuer to find out why the modem behaves like that...
Your best bet is to try another modem (or a Dialogic card).
Thank you for the response
i think we Can use the at command realization through a vb module? How realize hookflash by at command,If can provide a vb test code, I will feel grateful very
Not sure it's possible to send AT command from VBScript while some other app is using the modem...
thanks
i can do
at d! at d123
(123 is phone number) with HyperTerminal
call Transfers succeed
now we like us vbs,
anybody can tell me how vbs use mscomm32.ocx
See this setting in VG.INI file:
TransferControl_Modem=Generate
The recommended setting is Generate, but you can try setting it to other values as well...
Discover an important problem
The COM PORT can't be openned by two process in the meantime .
VG Hang the telephone possibility because of my pbx stiring sound IS 450HZ or not
we find this in vg.ini ,how use it
;*** "AT" is selected for Transfer Control
ModemTransferInit1=AT#VBT=1
ModemTransferHookflash=AT#VTS=!
;ModemTransferDialNumber: this command is suffixed with the destination number separated by commas
ModemTransferDialNumber=AT#VTS=
ModemTransferComplete=AT#VTS=!
;Commands issued to the modem duting a 3-way conference setup
Modem3WayInit1=AT#VBT=1
Modem3WayHookflash=AT#VTS=!
;pause time after sending hookflash to allow PBX enough
;Modem3WayDialNumber : this command is suffixed with the destination number separated by commas
Modem3WayDialNumber=AT#VTS=
Modem3WayComplete=AT#VTS=!
i Design a process with delphi and mscomm ,find a Strange problem
my process is very Simple
1, open comport
2, at h1 (pick up call)
3, at d! (hookflash)
4, at d123 (transfer number)
5, close comport
first call,and open comport ,the call transder suceess
then first open comport,and telephone call in,do hookflash ,it Hang Up as vg.
so i think transfer Problem with voicemodem is not hookfash length, we Should can find wrong source
