How Many Usb Modem Support?
Hi
How many external usb modem can we install on one system?
Does VG Support them?
It really depends on the modem’s driver.
VoiceGuide itself does not place any limits on how many devices it will support. You will most likely run into problems on the modem driver’s side through.
For multi-line systems you should just forget about modems and use a Dialogic card.
1- Can you suggest the best model of dialogic boards for
4 , 8 , 12 , 16 , 24 , 30 , 60 , 120 Port?
Went through the links and found one link was bad (fixed now). If you find any more please let us know.
