deanm Report post Posted 11/29/2005 04:55 AM Hi , I have done the following to set up the voicemail system and it doesnt appear to be working. 1. Opened voicemail manager and setup voicemail box 0001. I simply entered a pin number and a name (I cant record files as the server is at a remote location and assumed you would be able to do that by dialling in) I also entered the details of the smtp server so it emails all messages. 2. Change our main inbound dialling script so that when you push 6 the path is [Voicemail box menu] 3. when dialling into the system and pushing 6 i am prompted to enter a mailbox number, i enter 0001 it then says please record your message and then hangs up. What Am I doing wrong, I want to dial into the voicemail system to record a greeting for the mailbox 0001 and then want to use that same voicemail box throughout our other scripts Trace is pasted below 151826.14 2 event callstate OFFERING 2 2,0,0 151826.14 2 script interpretor: VgMulti v6.0.2322 151826.14 2 fired OFFERING event to listeners 151826.14 2 set LineState().hCall = 2 in LINECALLSTATE_OFFERING 151826.14 2 cid CallerID vars set (in 'offering' event) [,,] 151826.14 2 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING 151826.14 2 rings=0, min rings before answer=2 (iCallerIdHasArrived=0) 151826.14 2 tw ring 1 151826.14 2 ring time since last ring event (sec): 0.00 151826.14 2 rings=1, min rings before answer=2 (iCallerIdHasArrived=0) 151826.14 2 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 151826.14 2 event ScriptEventCode TDX_CST, code=134, state=900 151826.14 2 LsAwaitingCalls EV_UNKNOWN_134 151828.89 2 tw lev_CallerID [0293318320,,], strWorkingModeScript=[] 151828.89 2 cid LastCidMessage values [0293318320,,] 151828.89 2 cid CallerID vars set (in levCallerId) 151828.89 2 rings=1, min rings before answer=2 (iCallerIdHasArrived=1) 151828.89 2 tw ring 2 151828.91 2 ring time since last ring event (sec): 2.77 151828.91 2 rings=2, min rings before answer=2 (iCallerIdHasArrived=1) 151828.91 2 answer as number of rings reached 151828.91 2 rv clear all 151828.91 2 init LineState ResetAtStartOfNewCall. 151828.91 2 answer the call 151828.91 2 timer clear 151828.91 2 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 151828.91 2 event ScriptEventCode TDX_CST, code=134, state=6001 151829.52 2 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND, 151829.52 2 event ScriptEventCode TDX_SETHOOK, code=135, state=6001 151829.52 2 event callstate CONNECTED 2 256,0,0 151829.52 2 LineEvCallState_Connected hDevice=2 params=256,0,0 151829.52 2 WorkingModes tapi= script= LineState().iState=6001 151829.52 2 Inband detection not enabled 151829.53 2 StartLoadedVgs at 29/11/2005 3:18:29 PM [VgMulti v6.0.2322] 151829.53 2 set LineState().iVgsIdx=1 151829.53 2 set sScriptToRunOnHangup=[] in StartLoadedVgs 151829.53 2 init StartLoadedVgs_InitLineState start 151829.53 2 rv add [$RV_STARTTIME]{29/11/2005 3:18:29 PM} 151829.53 2 rv add [$RV_DEVICEID]{2} 151829.53 2 rv add [$RV_CIDNAME]{} 151829.53 2 rvns add [PathApp]{C:\Program Files\VoiceGuide\} 151829.53 2 rvns add [scriptsPath]{C:\BookingAngel\} 151829.53 2 rv add [$RV_CIDNUMBER]{0293318320} 151829.53 2 fn RunModule start 151829.53 2 tw DialogicEvent 134,TDX_CST,19873,0,0,DE_LCON,, 151829.53 2 event ScriptEventCode TDX_CST, code=134, state=6001 151829.53 2 timer clear 151829.53 2 Play Module start 151829.53 2 state [intro Message] Playing 151829.55 2 tts generate start[Hi, You have reached the offices of booking angel. To hear a demonstration of the booking angel service press 1, for sales press 2, If you are a restaurant ringing about a booking or cancellation press 3, For all other inquiries press 4] 151829.55 2 tts generate wait 151829.73 2 tts generate finish 151829.73 2 state [intro Message] Playing (C:\Program Files\VoiceGuide\data\tts2.wav) 151829.73 2 tw ConvertWav2Vox C:\Program Files\VoiceGuide\data\tts2.wav 151829.73 2 timer clear 151829.80 2 tw wav->vox convert end 382453,C:\Program Files\VoiceGuide\data\tts2.vox,1,0,, 151829.81 2 play start ok, lPlayId=382515 151833.86 2 tw dtmf 6 (2,54,54) 151833.86 2 event ScriptEventCode 6, code=54, state=1100 151833.86 2 LsPlayMsg 6,6 151833.88 2 play PlaySoundStop ok 151833.88 2 rv add [intro Message]{6} 151833.88 2 fn RunModule start 151833.88 2 tw DialogicEvent 134,TDX_CST,54,0,0,DE_DIGITS,, 151833.88 2 event ScriptEventCode TDX_CST, code=134, state=6001 151833.88 2 tw PlayEnd 2 382515 151833.88 2 play end id=382515, (current ID) 151833.88 2 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=6001 151833.88 2 tw DialogicEvent 129,TDX_PLAY,382515,0,0,,, 151833.88 2 event ScriptEventCode TDX_PLAY, code=129, state=6001 151833.88 2 timer clear 151833.88 2 RunVmModule called when running Scripted VM 151833.89 2 timer clear 151833.89 2 voicemail used: Scripted 151833.89 2 tr NewVgsVgm_Goto C:\Program Files\VoiceGuide\system\vm\VmLm.vgs,VmMenuStart,,,,0 151833.89 2 rv add [scriptEnd_Time]{29/11/2005 3:18:33 PM} 151833.89 2 rv add [scriptEnd_Goto_Script]{C:\Program Files\VoiceGuide\system\vm\VmLm.vgs} 151833.89 2 rv add [scriptEnd_Goto_Module]{VmMenuStart} 151833.89 2 rv add [scriptStart_Time]{29/11/2005 3:18:33 PM} 151833.89 2 rv add [scriptStart_CalledFrom_Script]{C:\BookingAngel\inbound.vgs} 151833.91 2 rv add [scriptStart_CalledFrom_Module]{Intro Message} 151833.91 2 FindFullPathToScript_VgsOrVgp start [C:\Program Files\VoiceGuide\system\vm\VmLm.vgs] 151833.91 2 FindFullPathToScript_VgsOrVgp 1 151833.91 0 LoadedVgs_Find C:\Program Files\VoiceGuide\system\vm\VmLm.vgs at idx=2 151833.91 2 rvns add [scriptsPath]{C:\Program Files\VoiceGuide\system\vm\} 151833.91 2 tr NewVgsVgm_Goto 1 151833.91 2 tr NewVgsVgm_Goto 2 151833.91 2 fn RunModule start 151833.91 2 timer clear 151833.91 2 state [VmMenuStart] Number Input 151833.91 2 rv replace start: [$RV[PathSysVoice]VmbAccessGetVmbId.wav] 151833.91 2 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{29/11/2005 3:18:29 PM}[$RV_DEVICEID]{2}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[scriptsPath]{C:\BookingAngel\}[$RV_CIDNUMBER]{0293318320}[intro Message]{6}[scriptEnd_Time]{29/11/2005 3:18:33 PM}[scriptEnd_Goto_Script]{C:\Program Files\VoiceGuide\system\vm\VmLm.vgs}[scriptEnd_Goto_Module]{VmMenuStart}[scriptStart_Time]{29/11/2005 3:18:33 PM}[scriptStart_CalledFrom_Script]{C:\BookingAngel\inbound.vgs}[scriptStart_CalledFrom_Module]{Intro Message}[scriptsPath]{C:\Program Files\VoiceGuide\system\vm\} 151833.91 2 rv replace end: [C:\Program Files\VoiceGuide\system\voice\VmbAccessGetVmbId.wav] 151833.91 2 state [VmMenuStart] Playing (C:\Program Files\VoiceGuide\system\voice\VmbAccessGetVmbId.wav) 151833.92 2 tw ConvertWav2Vox C:\Program Files\VoiceGuide\system\voice\VmbAccessGetVmbId.wav 151833.92 2 timer clear 151833.92 2 tr NewVgsVgm_Goto end 151833.92 2 tw wav->vox convert end 386640,C:\Program Files\VoiceGuide\system\voice\VmbAccessGetVmbId.vox,1,0,, 151833.94 2 play start ok, lPlayId=386640 151835.75 2 tw dtmf 0 (2,48,48) 151835.75 2 event ScriptEventCode 0, code=48, state=1300 151835.75 2 LsGetNbrsPlayWelcMsg 0,0 151835.75 2 play PlaySoundStop ok 151835.77 2 state [VmMenuStart] Number Input 0 151835.77 2 path {0} not found 151835.77 2 timer set 6 EV_TIMEOUT_ENTERDATA 151835.77 2 tw DialogicEvent 134,TDX_CST,48,0,0,DE_DIGITS,, 151835.77 2 event ScriptEventCode TDX_CST, code=134, state=1301 151835.77 2 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST 151835.77 2 path {TDX_CST} not found 151835.77 2 tw PlayEnd 2 386640 151835.77 2 play end id=386640, (current ID) 151835.77 2 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1301 151835.77 2 LsGetNbrsRxDigits EV_PLAY_FINISHED,EV_PLAY_FINISHED 151835.77 2 path {EV_PLAY_FINISHED} not found 151835.77 2 tw DialogicEvent 129,TDX_PLAY,386640,0,0,,, 151835.78 2 event ScriptEventCode TDX_PLAY, code=129, state=1301 151835.78 2 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY 151835.78 2 path {TDX_PLAY} not found 151835.94 2 tw dtmf 0 (2,48,48) 151835.94 2 event ScriptEventCode 0, code=48, state=1301 151835.94 2 LsGetNbrsRxDigits 0,0 151835.94 2 state [VmMenuStart] Number Input 00 151835.94 2 path {00} not found 151835.94 2 timer set 6 EV_TIMEOUT_ENTERDATA 151835.94 2 tw DialogicEvent 134,TDX_CST,48,0,0,DE_DIGITS,, 151835.94 2 event ScriptEventCode TDX_CST, code=134, state=1301 151835.94 2 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST 151835.94 2 path {TDX_CST} not found 151836.23 2 tw dtmf 0 (2,48,48) 151836.23 2 event ScriptEventCode 0, code=48, state=1301 151836.23 2 LsGetNbrsRxDigits 0,0 151836.23 2 state [VmMenuStart] Number Input 000 151836.23 2 path {000} not found 151836.23 2 timer set 6 EV_TIMEOUT_ENTERDATA 151836.23 2 tw DialogicEvent 134,TDX_CST,48,0,0,DE_DIGITS,, 151836.23 2 event ScriptEventCode TDX_CST, code=134, state=1301 151836.25 2 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST 151836.25 2 path {TDX_CST} not found 151836.78 2 tw dtmf 1 (2,49,49) 151836.78 2 event ScriptEventCode 1, code=49, state=1301 151836.78 2 LsGetNbrsRxDigits 1,1 151836.80 2 state [VmMenuStart] Number Input 0001 151836.80 2 path {0001} not found 151836.80 2 timer set 6 EV_TIMEOUT_ENTERDATA 151836.80 2 tw DialogicEvent 134,TDX_CST,49,0,0,DE_DIGITS,, 151836.80 2 event ScriptEventCode TDX_CST, code=134, state=1301 151836.80 2 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST 151836.80 2 path {TDX_CST} not found 151837.38 2 tw dtmf # (2,35,35) 151837.38 2 event ScriptEventCode #, code=35, state=1301 151837.38 2 LsGetNbrsRxDigits #,# 151837.38 2 timer clear 151837.38 2 rv add [VmMenuStart]{0001} 151837.38 2 path {0001} not found 151837.38 2 rvns add [VmMenuStart_PathTaken]{success} 151837.38 2 fn RunModule start 151837.38 2 tw DialogicEvent 134,TDX_CST,35,0,0,DE_DIGITS,, 151837.39 2 event ScriptEventCode TDX_CST, code=134, state=6001 151837.39 2 timer clear 151837.39 2 state [VmMenuCheckEnteredVmb] Running vb script:[VmLmHangup.vgs] 151842.64 2 FindFullPathToScript_VgsOrVgp start [C:\Program Files\VoiceGuide\system\vm\VmLmHangup.vgs] 151842.64 2 FindFullPathToScript_VgsOrVgp 1 151842.64 0 LoadedVgs_Find C:\Program Files\VoiceGuide\system\vm\VmLmHangup.vgs at idx=3 151842.64 2 fn RunModule start 151842.64 2 timer clear 151842.64 2 state [VmLmHangup_ForwardLastMsg] Running VB Script... 151842.66 2 rv replace start (strlen>500) 151842.66 2 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{29/11/2005 3:18:29 PM}[$RV_DEVICEID]{2}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[scriptsPath]{C:\BookingAngel\}[$RV_CIDNUMBER]{0293318320}[intro Message]{6}[scriptEnd_Time]{29/11/2005 3:18:33 PM}[scriptEnd_Goto_Script]{C:\Program Files\VoiceGuide\system\vm\VmLm.vgs}[scriptEnd_Goto_Module]{VmMenuStart}[scriptStart_Time]{29/11/2005 3:18:33 PM}[scriptStart_CalledFrom_Script]{C:\BookingAngel\inbound.vgs}[scriptStart_CalledFrom_Module]{Intro Message}[scriptsPath]{C:\Program Files\VoiceGuide\system\vm\}[VmMenuStart]{0001}[VmMenuStart_PathTaken]{success}[VmbId]{0001}[Key_VmLmS opRecAndPlay]{1}[Key_VmLmDelRecRecAgain]{2}[Key_VmLmSaveAndPlayGreeting]{3}[Key_ mLmDeleteGoGroupPrevious]{4}[Key_VmLmDeleteAndPlayGreeting]{5}[Key_VmLmDeleteGoG oupNext]{6}[Key_VmLmSaveGoVmLogin]{8}[Key_VmLmSaveVmExit]{0}[Key_VmLmSaveGoLmRec sgMenu]{#}[RecMessage]{}[VmbWelcMsg]{C:\Program Files\VoiceGuide\system\voice\VmbWelcomeMsgDefault.wav}[VmLmRecFilename]{0001_1129151841_1_2_0293318320_. av}[MsgLenMax]{30}[Hangup Time]{29/11/2005 3:18:42 PM}[CallEndTime]{29/11/2005 3:18:42 PM} 151842.66 2 vbs ran [vbs_2_4.vbs], cmd [wscript "C:\Program Files\VoiceGuide\data\vbs_2_4.vbs" //I //T:60] 151842.67 2 Run Script waiting. iRunWait=1 (shellid=620, process=3300) 151842.67 2 timer set 1 EV_TIMEOUT_CHECKONSTATE 151843.69 2 timer fired EV_TIMEOUT_CHECKONSTATE 151843.69 2 event ScriptEventCode EV_TIMEOUT_CHECKONSTATE, code=9007, state=1501 151843.69 2 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE 151843.69 2 task completed (shellid=620, process=3300) vgm=21, iRunWait=1, iRunWait_ExeResult_NextVgm=0 151843.69 2 no result file returned from program (VGRUNRESULT_2.TXT or SHLRESLT.TXT) 151843.69 2 already IDLE. HangupCall ignored. 151843.69 2 init atidle reinit : start 151843.69 2 init atidle reinit iConferenceOtherLegLid=-1 151843.69 2 init atidle reinit : reset all LineState variables 151843.69 2 timer set 0.3 EV_TIMEOUT_ATERIDLE_ALLOWOUT 151843.69 2 state Waiting for a call... 151844.03 2 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT 151844.03 2 event ScriptEventCode EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=900 Share this post Link to post
SupportTeam Report post Posted 11/29/2005 08:21 AM I think you have edited the Voicemail system's vmLm.vgs file... In trace we see: 151841.59 2 Run Script waiting. iRunWait=2 (shellid=1652, process=3320) which means that in module VmLmRecInit the setting 'Wait till VBScript completes' was changed to 'Wait till VBScript and Sound File completes', and as that module does not start any playing of sound files then VoiceGuide hangs up because of this error. We should maybe add more debugging to mark cause of hangup more specific, but what you should maybe do now is to re-install VG on that machine, (unless you know what other changes were made to the voicemail scripts and can reverse them all). Share this post Link to post
deanm Report post Posted 11/29/2005 11:05 PM The VM scripts have definitely not been edited at all Im not even sure what script that module you refer to is in... Im dubious about re-installing the whole of voice guide (we have finally ironed out all the bugs with answering machines). Do I have to unregister files from the registry etc. Should I just re-install just the voice mail part of it... is it just copying over the system / vg folder. If I do a full re-install, do I need to save my current config file or any other files? Also since installing voiceguide for dialogic all of the sound files sound rrreeeaallly slow. I know this is related to the sample rate of the files is there a quicker way to fix all the files than re-recording / editing the individual files. Will this be fixed with a re-install. Share this post Link to post
SupportTeam Report post Posted 11/30/2005 08:26 AM Best thing to do is probably to install VoiceGuide on another machine (select the "TAPI" option when doing this) and then copy over the entire \system\ subdirectory tree. VG for Dialogic uses 8kHz sound files. There are instructions mentioning this in the Readme.txt file in VG for Dialogic patch download. Share this post Link to post
