Script Help
Hello again.
I have a Run VB Script Module that is acting strange.
This is the code:
sResult = "verify_passed"
vg.Run_ResultReturn $RV_LINEID, sResult
set vg = nothing
The paths are:
on {success} goto [CLI Check]
on {fail} goto [No Service Appology]
From the code I would expect the script to always go to [CLI Check], but it goes to [No Service Appology]. I've even changed 'sResult = "verify_passed"' to 'sResult = "verify_failed"' and to see if maybe the logic is weird, but no. No matter what, it goes to [No Service Appology]
The only thing that happens before the Run VB Script Module runs is that the path to my voice files is set (This works) and a welcome message is played (this also works).
What am I doing wrong here?
Are you running this in a "Run VBScript" module or a "Get Numbers"?
"verify_passed" and "verify_failed" are only relevant when doing number verification in a Get Numbers module.
If you running this in a "Run VBScript" module then please see here for more relevant examples: http://www.voiceguide.com/vghelp/html/modVbs.htm
Ok cool, I think I'm starting to get the hang of this.
PS: Iv'e said it before and I'll say it again, Voiceguide Support Forum rocks!
