Guest Ron Derk Report post Posted 12/06/2005 03:49 PM Is this a bug? And if so how can I get around it? The Play module(NewWaveFile) uses $RV[NewWaveFile] for the sound file name It will play any sound file untill it hits one with perhaps "[" in the name or is it the ";". This is a little of trace log. I can work around it by using a different character in name. But I had rather not. :-) state [PlayNewWaveFile] Playing (C:\Program Files\VoiceGuide WatchDog\11[19[2005 11;56;22 PM.Wav) File not found [C:\Program Files\VoiceGuide WatchDog\11[19[2005 11] File not found [56] File not found [22 PM.Wav] play set playid=358687 PlaySoundStart ok [C:\Program Files\VoiceGuide\system\voice\SoundFileNotFound.wav, Share this post Link to post
Guest Guest Report post Posted 12/06/2005 04:05 PM Can't use a "," in the file name eather. Changed the ";" to "]" in the wave file name and now they play fine. Changing the script was not that big of deal. Don't worry about fixing it for me :-) Share this post Link to post
SupportTeam Report post Posted 12/06/2005 10:23 PM Please post a script demonstration the problem and a trace capturing the entire call. Share this post Link to post
Guest Guest Report post Posted 12/10/2005 02:39 PM I have posted the sections of log that are relivant. The File C:\Program Files\VoiceGuide WatchDog\11[19[2005 11;56;22 PM.Wav does exist. But even if it didn't exist, I woud not get the "File not found [56]" nor the "File not found [22 PM.Wav]" as in script log I reposted below. Just put a evaluiate module with the path and file name that contains , or ; in it. and a play module referancing that wave file variable. And you will duplicate the error. Like I said I just replaced the ; with [ in the file name and script works fine. And am happy now. I was just letting you know because you help me so much , thank you! state [PlayNewWaveFile] Playing (C:\Program Files\VoiceGuide WatchDog\11[19[2005 11;56;22 PM.Wav) File not found [C:\Program Files\VoiceGuide WatchDog\11[19[2005 11] File not found [56] File not found [22 PM.Wav] play set playid=358687 PlaySoundStart ok [C:\Program Files\VoiceGuide\system\voice\SoundFileNotFound.wav, Share this post Link to post
SupportTeam Report post Posted 12/11/2005 03:19 AM Commas and semicolons are not allowed as part of filenames. They are used as separators for successive filenames - which is what VG is interpreting them as. Share this post Link to post
