Voicemessages
Hello support,
We need to record the voicemessage and email that message as
an attachment. This was working earlier but has stopped now
after we changed some settings.
While testing we found that it was giving an error "silence path
not found". so we set the silence path to the next module that
emails the recording. But it still does not continue to the next
module and just disconnects after voice recording. Please check
this log if its of any help.
123023.56 7 [VoiceMessage] Recording
123023.56 7 play set playid=675093
123023.56 7 PlaySoundStart ok [C:\Program Files\VoiceGuide\system\voice\beep1.wav]
123023.56 7 timer clear
123023.56 7 wa(186,67509300)
123023.56 7 callinfo MONITORMODES
123023.80 7 wb(67509300)
123023.84 7 play end current play (playid=675093)
123023.84 7 ScriptEventCode 8001 iLineState=1200
123023.84 7 LsRecPlayBeep EV_PLAY_FINISHED
123023.84 7 rv lg add [VoiceMessage]{C:\vgscript\1208123023_7_.wav}
123023.86 7 RecSoundStart file[C:\vgscript\1208123023_7_.wav] ok
123023.86 7 eng RecSoundStart after beep [C:\vgscript\1208123023_7_.wav]
123023.86 7 timer set 30 EV_TIMEOUT_GOTOMODULE
123036.92 7 callstate DISCONNECTED 66080 0 0
123036.92 7 ScriptEventCode 9250 iLineState=1201
123036.92 7 LsRecRecording EV_REMOTEPARTY_DISCONNECT
123036.97 7 RecSoundStopTruncBytes ok
123036.97 7 rec length RV: VoiceMessage_RecLen100ms = 131
123036.98 7 rv lg add [VoiceMessage_RecLen100ms]{131}
123036.98 7 rv lg add [VoiceMessage_EndRecCause]{disconnect}
123036.98 7 rv lg add [Hangup Time]{08/12/2005 12:30:36}
123036.98 7 Hanging up call... [During LsRecRecording]
123036.98 7 RecSoundStop ok
123036.98 7 PlaySoundStop err=0
123036.98 7 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
123036.98 7 fnHangupCall end
123036.98 7 ScriptEventCode 8003 iLineState=900
123036.98 7 LsAwaitingCalls EV_REC_FINISHED
123037.02 7 linedevstate 2048 0 0
123037.02 7 callstate IDLE 66080 0 0
123037.02 7 WorkingMode@Idle=
123037.02 7 timer clear
123037.20 7 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
123037.20 7 tapi Reply (LineEvReply) ok 66305 0
123038.19 7 timer fired EV_TIMEOUT_TIMETOREINITLINE
123038.19 7 ScriptEventCode 9008 iLineState=900
123038.19 7 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
123038.19 7 ReinitTelephony due to IDLE
123038.19 7 tapic lineDeallocateCall(MainCall:66080) 0
123038.34 7 lineOpen(7)=>
123038.34 7 Waiting for a call...
123038.34 7 LineHandle=65776
123038.34 7 amchk set AMdet=False in Reinit@idle
123038.34 7 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
123038.34 0 dial start any summary:|6:idx=0|7:rdy=0|8:idx=0|9:idx=0|
123041.63 7 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
123041.63 7 ScriptEventCode 9013 iLineState=900
123042.36 0 dial start any summary:|6:idx=0|7:idx=0|8:idx=0|9:idx=0|
As per the link you have suggested, it is possible to run scripts
after hangup. So I can write a separate script to email the
voicemessage if the caller hangs up abruptly. The only problem
is the reference of voicemessage attachment name. Currently
suppose the name of the module is voice1, I can directly use
the name $RV[voice1] in the attachment property of the
emailvoicemessage. But if this is an external script, how
can I refer to the module name. kindly advise.
You need to know in what RV the filename of the recorded message will be stored...
So you need to know the actual RV name, or have the various recording scripts set a specific RV to hold that information.
