casazza Report post Posted 12/09/2005 09:49 PM I am evaluating VG and so far things are looking good. We are using a Dialogic D4/PCI card. The one thing I need to test is distinctive ring. I read through the forum and found how it can be done by modifying the ConfigLine.xml For VoiceGuide to detect the different rings, the cadences of the rings need to be specified in a ConfigLine.xml file, which is loaded by VoiceGuide at startup. Here is the relevant section of that file with one ring tone defined. Where does this file exist - do I have to create it, and if so where should it reside. Thanks, Jim Share this post Link to post
SupportTeam Report post Posted 12/09/2005 09:53 PM You need to download and install the "VoiceGuide for Dialogic" patch. See the Downloads page. Share this post Link to post
