Guest Nguyen Viet Hung Report post Posted 12/12/2005 11:30 AM Hello, I have a VFX/40ESC Plus card, and caller id facility available on Channel inserted lines. But still i am not able to get caller number. I had tested this function by the Dialogic Example for Caller Id: SAMPLES\VOICE\SAMPLE.EXE (using the Dialogic API) It gives me message as - Call Received, No Caller Id The CallerID had recieved ok (beetween the first & the second ring) by a software with a normal modem. The line is connect from ULC-AN (Access Network) device, it is configured "FSK", but I'm not sure that is "FSK Bellcore 1200 standard". I don't know what have to do to get the caller id by the card, Please help me. Share this post Link to post
SupportTeam Report post Posted 12/12/2005 08:38 PM You should contact your local Dialogic reseller to find out what cards will receive the CallerID correctly in your area. Share this post Link to post
