Outlook Email Problem
My VG scripts calls for sending an email using MAPI (Outlook is my default client) each time a transaction takes place. However, each time VG attempts to send an email, Outlook 2003 will issue a warning that says "A program is trying to send e-mail on your behalf. Do you want to allow this ? If this is unexpected it may be a virus and should choose "No".
Then it prompts me to allow "Yes" or stop "No"
Is there anyway VG can send email using MAPI unattended ??
When I tried to send directly using SMTP, nothing happens, the emails stay in the EmailQue. I have used Outlook 2003 and Eudora 7 to retrieve and send emails using the same SMTP successfully.
When I tried using Eudora to replace Outlook, I got a message from vgEmailSender that states that it cannot find an entrypoint into the DLL
Any ideas please
Enad
Concentrate on getting the SMTP sending going. You will not be able to get rid of he "A program is trying to send e-mail..." messages.
Have you set the SMTP server settings correctly in VoiceGuide's Send Email module?
If you enable tracing you should get a MMDDes.txt trace file in VG's \log\ subdirectory - that file should tell you what is happening.
