Return To Calling Module
Is there a way to jump to play module and then return to original module?
I have a sound file named "You Took To Long.wav". I use it over and over in my script. I would really like to jump to the same play module and then back to calling module from several places in script.
Kind of like a gosub routine in other programing lang.
You forgot to mention that this will cost each of my customers an extra ~$50 dollars, So the programing will be easer for me to write. At no extra beneft to them.
I am an old man, and perhaps I am just being closed minded :-)
Are there any bennifits my customers would reap, if they purchase the Enterprise version verses the Pro version?
I justify their purchase of the pro version because they get the use of data bases, which is important to them.
I know the enterprise version would be easer for me to program. And I also realize by using cut and paste, I could write with enterprise version. Then convert script to Pro version. But I have't found that nessary yet.
