The Script Starts Running But Phone Still Rings
141501,77 7 tapi callstate start
141501,77 7 tapi callstate OFFERING 65913 0 4
141501,77 7 ring 1
141502,16 0 dial start any summary:|7:hc>0|
141506,21 7 ring 2
141506,21 7 rv clear
141506,21 7 Answer the call at 15.12.2005 14:15:06
141506,21 7 lineAnswer(65913) => 65845
141506,21 7 tapi callstate start
141506,21 7 tapi callstate ACCEPTED 65913 0 0
141506,60 7 tapi Reply (LineEvReply) ok 65845 0
141506,60 7 tapi callstate start
141506,61 7 tapi callstate CONNECTED 65913 0 0
141506,61 7 callstate CONNECTED 65913,0,0
141506,61 7 WorkingModeTAPI@Connected=
141506,61 7 WorkingModeScript@Connected=
141506,61 7 Inband detection not enabled
141506,61 7 StartLoadedVgs at 15.12.2005 14:15:06, script interpretor VgMulti v5.2.5012 0
141506,61 7 rv ns add [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Customer Enquiry\}
141506,61 7 rv ns add [scriptPath]{C:\Program Files\VoiceGuide\Scripts\Customer Enquiry}
141506,61 7 rv lg add [$RV_STARTTIME]{15.12.2005 14:15:06}
141506,61 7 rv lg add [$RV_DEVICEID]{7}
141506,63 7 rv lg add [$RV_CIDNAME]{}
141506,63 7 rv ns add [PathApp]{C:\Program Files\VoiceGuide\}
141506,63 7 rv lg add [$RV_CIDNUMBER]{}
141506,63 7 rv lg add [$RV_DNIS]{}
141506,63 7 rv lg add [DNIS]{}
141506,63 7 timer clear
141506,63 7 state [select Query] Playing
141506,64 7 state [select Query] Playing (DemoScript.wav)
141506,64 7 play set playid=399406
141507,18 7 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Customer Enquiry\DemoScript.wav]
141507,18 7 timer clear
141507,18 7 RunModule PLAY end
141515,85 7 play end current play (playid=399406)
141515,85 7 ScriptEventCode 8001 iLineState=1100
141515,85 7 LsPlayMsg EV_PLAY_FINISHED
141515,85 7 timer set 10 EV_TIMEOUT_HANGUP
141515,86 7 timer set 10 EV_TIMEOUT_HANGUP
141516,68 0 sys cleanup Start
141516,68 0 sys cleanup End
141526,69 7 timer fired EV_TIMEOUT_HANGUP
141526,69 7 ScriptEventCode 9001 iLineState=1101
141526,69 7 LsPlayMsgFinished EV_TIMEOUT_HANGUP
141526,69 7 rv lg add [Hangup Time]{15.12.2005 14:15:26}
141526,69 7 state Hanging up call...
141526,69 7 RecSoundStop ok
141526,69 7 PlaySoundStop err=0
141526,71 7 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
141526,71 7 fnHangupCall end
141527,54 7 tapi callstate start
141527,54 7 tapi callstate DISCONNECTED 65913 1 0
141527,55 7 ScriptEventCode 9250 iLineState=900
141527,55 7 LsAwaitingCalls EV_REMOTEPARTY_DISCONNECT
141527,55 7 rv lg add [Hangup Time]{15.12.2005 14:15:27}
141527,55 7 state Hanging up call...
141527,55 7 RecSoundStop ok
141527,55 7 PlaySoundStop err=0
141527,55 7 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
141527,57 7 fnHangupCall end
141527,57 7 tapi callstate start
141527,57 7 tapi callstate IDLE 65913 0 0
141527,57 7 WorkingMode@Idle=
141527,57 7 timer clear
141527,57 7 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
141527,58 7 tapi Reply (LineEvReply) ok 65794 0
141527,58 7 tapi Reply (LineEvReply) ok 65777 0
141528,57 7 timer fired EV_TIMEOUT_TIMETOREINITLINE
141528,57 7 ScriptEventCode 9008 iLineState=900
141528,57 7 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
141528,57 7 ReinitTelephony due to IDLE
141528,57 7 tapic lineDeallocateCall(MainCall:65913) 0
141528,69 7 lineOpen(7)=>
141528,69 7 state Waiting for a call...
141528,69 7 LineHandle=65760
141528,69 7 amchk set AMdet=False in Reinit@idle
141528,69 7 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
141529,18 0 dial start any summary:|7:rdy=0|
141531,97 7 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
141531,97 7 ScriptEventCode 9013 iLineState=900
141532,18 0 dial start any summary:|7:dok=0|
Event log is above. Please help. When VG answers the call I still hear the ringing on the phone make the call. What should I do.
