Guest Hasan Andız Report post Posted 12/15/2005 12:23 PM 141501,77 7 tapi callstate start 141501,77 7 tapi callstate OFFERING 65913 0 4 141501,77 7 ring 1 141502,16 0 dial start any summary:|7:hc>0| 141506,21 7 ring 2 141506,21 7 rv clear 141506,21 7 Answer the call at 15.12.2005 14:15:06 141506,21 7 lineAnswer(65913) => 65845 141506,21 7 tapi callstate start 141506,21 7 tapi callstate ACCEPTED 65913 0 0 141506,60 7 tapi Reply (LineEvReply) ok 65845 0 141506,60 7 tapi callstate start 141506,61 7 tapi callstate CONNECTED 65913 0 0 141506,61 7 callstate CONNECTED 65913,0,0 141506,61 7 WorkingModeTAPI@Connected= 141506,61 7 WorkingModeScript@Connected= 141506,61 7 Inband detection not enabled 141506,61 7 StartLoadedVgs at 15.12.2005 14:15:06, script interpretor VgMulti v5.2.5012 0 141506,61 7 rv ns add [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Customer Enquiry\} 141506,61 7 rv ns add [scriptPath]{C:\Program Files\VoiceGuide\Scripts\Customer Enquiry} 141506,61 7 rv lg add [$RV_STARTTIME]{15.12.2005 14:15:06} 141506,61 7 rv lg add [$RV_DEVICEID]{7} 141506,63 7 rv lg add [$RV_CIDNAME]{} 141506,63 7 rv ns add [PathApp]{C:\Program Files\VoiceGuide\} 141506,63 7 rv lg add [$RV_CIDNUMBER]{} 141506,63 7 rv lg add [$RV_DNIS]{} 141506,63 7 rv lg add [DNIS]{} 141506,63 7 timer clear 141506,63 7 state [select Query] Playing 141506,64 7 state [select Query] Playing (DemoScript.wav) 141506,64 7 play set playid=399406 141507,18 7 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Customer Enquiry\DemoScript.wav] 141507,18 7 timer clear 141507,18 7 RunModule PLAY end 141515,85 7 play end current play (playid=399406) 141515,85 7 ScriptEventCode 8001 iLineState=1100 141515,85 7 LsPlayMsg EV_PLAY_FINISHED 141515,85 7 timer set 10 EV_TIMEOUT_HANGUP 141515,86 7 timer set 10 EV_TIMEOUT_HANGUP 141516,68 0 sys cleanup Start 141516,68 0 sys cleanup End 141526,69 7 timer fired EV_TIMEOUT_HANGUP 141526,69 7 ScriptEventCode 9001 iLineState=1101 141526,69 7 LsPlayMsgFinished EV_TIMEOUT_HANGUP 141526,69 7 rv lg add [Hangup Time]{15.12.2005 14:15:26} 141526,69 7 state Hanging up call... 141526,69 7 RecSoundStop ok 141526,69 7 PlaySoundStop err=0 141526,71 7 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 141526,71 7 fnHangupCall end 141527,54 7 tapi callstate start 141527,54 7 tapi callstate DISCONNECTED 65913 1 0 141527,55 7 ScriptEventCode 9250 iLineState=900 141527,55 7 LsAwaitingCalls EV_REMOTEPARTY_DISCONNECT 141527,55 7 rv lg add [Hangup Time]{15.12.2005 14:15:27} 141527,55 7 state Hanging up call... 141527,55 7 RecSoundStop ok 141527,55 7 PlaySoundStop err=0 141527,55 7 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 141527,57 7 fnHangupCall end 141527,57 7 tapi callstate start 141527,57 7 tapi callstate IDLE 65913 0 0 141527,57 7 WorkingMode@Idle= 141527,57 7 timer clear 141527,57 7 timer set 1 EV_TIMEOUT_TIMETOREINITLINE 141527,58 7 tapi Reply (LineEvReply) ok 65794 0 141527,58 7 tapi Reply (LineEvReply) ok 65777 0 141528,57 7 timer fired EV_TIMEOUT_TIMETOREINITLINE 141528,57 7 ScriptEventCode 9008 iLineState=900 141528,57 7 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE 141528,57 7 ReinitTelephony due to IDLE 141528,57 7 tapic lineDeallocateCall(MainCall:65913) 0 141528,69 7 lineOpen(7)=> 141528,69 7 state Waiting for a call... 141528,69 7 LineHandle=65760 141528,69 7 amchk set AMdet=False in Reinit@idle 141528,69 7 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT 141529,18 0 dial start any summary:|7:rdy=0| 141531,97 7 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT 141531,97 7 ScriptEventCode 9013 iLineState=900 141532,18 0 dial start any summary:|7:dok=0| Event log is above. Please help. When VG answers the call I still hear the ringing on the phone make the call. What should I do. Share this post Link to post
SupportTeam Report post Posted 12/15/2005 11:25 PM As you had the same problem here: http://voiceguide.com/forums/index.php?showtopic=3512 then maybe the fault is with the phone line? Can you try using another phone line? Trace shows modem confirmed it has answered the call: 141506,61 7 callstate CONNECTED 65913,0,0 Share this post Link to post
