Guest Patrick Hogue Report post Posted 12/17/2005 01:12 AM Hi, When i run a "Play" or "Get Number" object, when i press a key to go to an other object the wave file continue to play for a few second or even to the end and after that the key is detected. It's confusing for the client! I am making a proof of concept and this is the last thing that is stopping me from doing my project! I beleive that at first this probleme was not present but i am not certain. I have 21 object in my .vgs file and i am using a Creative Modem Blaster V.92 pci (don't buy that kind of modem the sound is very bad and low). May be when my file was smaller it was working properly but i am not certain! Is this an issu with Voice Guide or it is due to something else. If i get a Dialogic card will this fix my probleme? I hope to have a feed back sone because i will sea my client soon and i when to know what i can tell him. Thank you very much Patrick P.S. here is a copy of my .vgs file. Just in case... CallCtr.vgs Share this post Link to post
SupportTeam Report post Posted 12/17/2005 05:34 AM the wave file continue to play for a few second or even to the end and after that the key is detected. ... i am using a Creative Modem Blaster V.92 pci Some voice mdoems have such propblems. That is why you should just use a Dialogic card. If i get a Dialogic card will this fix my probleme? Yes. Share this post Link to post
