Sms
I have dialogic board. (D120JCT)
I installed the voiceguide trial software so I want to know some things:
1) Can I use voiceguide to send sms ?
If Voiceguide does:
2) Do I have the right board ?
3) If I doesn't have the right board, which one can I use ?
4) What are the things that I need to setup a sms system with Voiceguide ?
Thank you for your help.
Leonard
VoiceGuide itself does not send out SMS.
You can from within VG's Run Program or Run VBScript modules call any of the many programs that do the actual sending of SMSs.
VoiceGuide will work fine with D120JCT.
Thank you for your support.
I am new in this stof (telephony with computer).
If I want to buy the VoiceGuide software but I don't see a 12 lines license software when I went to: https://secure.voiceguide.com/order_vg.htm.
I don't see 12 lines licence. I saw 1, 4, 8, 16, 24, 30, 48 and 60 lines licences.
So I replaced the D120JCT with a D/160SC-LS card.
I want to setup a IVR system with:
1) Voicemailboxes
2) Auto Attendant
3) Out Dial
4) Fax back
5) SMS
I don't know if I am correct. Can you tell me exactly if I am on the right way ?
1) I must buy a VoiceGuide Enterprise+dialer 16 line ($2399) License
(yes/no)
or
2) I must buy a Dialer 16 line (Already have 16 line VG Pro/Ent License) ($1499)
(yes/no)
and
3) I must buy a SMS software to run with the VoiceGuide software.
(yes/no)
4) Can you tell me wat the difference is between:
a) VoiceGuide Enterprise+dialer 16 line ($2399) License
B) Dialer 16 line (Already have 16 line VG Pro/Ent License
Thank you.
Leonard
The 12 port license is just the price of an 8 port license plus the price of a 4 port license.
If you do not already have a Professional or Enterprise license then you cannot buy just the
Dialer. You should be looking at the license type what you mentioned in point 1).
Dialer is and 'add-on' to VoiceGuide (Professional or Enterprise).
(yes/no)
Yes.
