Guest inforona Report post Posted 12/19/2005 03:17 PM Hello, I would like to have licensing information about the following configuration. We have one server with windows 2003. The server will have two dialogic cards four ports on each card. The first card will be use for the production application. And the second card for test and development. Each card will run two applications, is it possible to run two different applications on the same card? Should I buy 2 four ports or 1 eight ports licenses will be Ok?. Thank you. I’m using the forum since the email support@voiceguide.com doesn’t work. Share this post Link to post
SupportTeam Report post Posted 12/19/2005 08:36 PM Yes. You can run different script on different lines at the same time. If both cards are in the same machine then you should buy an 8 line license. We would recommend however that your development system should be in a different server to the production system... and in that case you would need to buy two 4-line licenses. Support questions like this should be posted on the forum. Share this post Link to post
