Guest RobG Report post Posted 12/20/2005 08:59 PM Running VoiceGuide 6.0.2275. In my startup folder, I execute a .bat that uses the "sleep" command to delay the execution of VgMulti.exe. The delay works well, but the command line option is ignored. I am trying to do a VgMulti.exe -icon but it just starts up VgMulti with the main window showing. I tried the other 2 command line options and they are ignored as well. This worked fine for me back at my 5.??.?? version. Any suggestions? TIA Rob G. Share this post Link to post
SupportTeam Report post Posted 12/20/2005 09:42 PM -icon option (and others similar to it) are not implemented in for v6 as yet. Share this post Link to post
SupportTeam Report post Posted 01/19/2006 06:15 AM This version of VG for Dialogic now supports the -icon and -hide command line options. VgMulti_6.0.2384.zip Share this post Link to post
Harry L. Roberts Report post Posted 01/21/2006 05:03 PM I execute a .bat that uses the "sleep" command to delay the execution of VgMulti.exe. Is there anyway to avoid using a time delay such as the sleep command? It just seems "better" to actually verify that the dialogic board is ready. Is there someway to check and act upon the board actually being ready? I know, why make somthing more difficult than it needs to be. If it ain't broke don't fix it. Well I'm always looking to improve. Anyone know how to determine if the dialogic board is ready? Share this post Link to post
SupportTeam Report post Posted 01/21/2006 09:43 PM You would need to be able to check he status of the Dialogic's Service. Once it shows up as 'Started' then that should indicate Dialogic is ready to be used. Share this post Link to post
