Guest Kevin Sheng Report post Posted 12/22/2005 08:46 PM Using handset when I receive a call, I press "flash" button, and it prompts me to press 1 to transfer to an extension, I press extension 1234. How am I supposed to do this thing in Voice Guide. Do I need to put 1 before the extension? Thanks in advance. I still have no clue how to make it work. Share this post Link to post
Guest Kevin Sheng Report post Posted 12/22/2005 09:20 PM Here is the trace window =================== thanks for help. 161253.94 1 event callstate OFFERING 1 2,0,0 161253.96 1 script interpretor: VgMulti v6.0.2322 161253.96 1 fired OFFERING event to listeners 161253.96 1 set LineState().hCall = 1 in LINECALLSTATE_OFFERING 161253.98 1 cid CallerID vars set (in 'offering' event) [,,] 161253.98 1 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING 161253.00 1 rings=0, min rings before answer=0 (iCallerIdHasArrived=0) 161254.01 1 tw ring 1 161254.02 1 ring time since last ring event (sec): 0.00 161254.03 1 rings=1, min rings before answer=0 (iCallerIdHasArrived=0) 161254.04 1 answer as number of rings reached 161254.05 1 rv clear all 161254.05 1 init LineState ResetAtStartOfNewCall. 161254.07 1 answer the call 161254.09 1 timer clear 161254.14 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 161254.14 1 event ScriptEventCode TDX_CST, code=134, state=6001 161254.81 1 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND, 161254.82 1 event ScriptEventCode TDX_SETHOOK, code=135, state=6001 161254.84 1 event callstate CONNECTED 1 256,0,0 161254.86 1 LineEvCallState_Connected hDevice=1 params=256,0,0 161254.87 1 WorkingModes tapi= script= LineState().iState=6001 161255.97 1 Inband detection not enabled 161255.00 1 StartLoadedVgs at 12/22/2005 4:12:55 PM [VgMulti v6.0.2322] 161256.02 1 set LineState().iVgsIdx=5 161256.04 1 set sScriptToRunOnHangup=[] in StartLoadedVgs 161256.06 1 init StartLoadedVgs_InitLineState start 161256.08 1 rv add [$RV_STARTTIME]{12/22/2005 4:12:55 PM} 161256.10 1 rv add [$RV_DEVICEID]{1} 161256.12 1 rv add [$RV_CIDNAME]{} 161256.14 1 rvns add [PathApp]{C:\Program Files\VoiceGuide\} 161256.16 1 rvns add [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Efmark IVR\} 161256.19 1 rv add [$RV_CIDNUMBER]{} 161256.21 1 fn RunModule start 161256.23 1 tw DialogicEvent 134,TDX_CST,13013,0,0,DE_LCON,, 161256.26 1 event ScriptEventCode TDX_CST, code=134, state=6001 161256.42 1 timer clear 161256.44 1 state [Get IVR Code] Number Input 161256.47 1 state [Get IVR Code] Playing (Welcome.wav, EnterUserID.wav) 161256.50 1 tw ConvertWav2Vox C:\Program Files\VoiceGuide\Scripts\Efmark IVR\Welcome.wav,C:\Program Files\VoiceGuide\Scripts\Efmark IVR\EnterUserID.wav 161256.53 1 timer clear 161256.59 1 tw wav->vox convert end 580095,C:\Program Files\VoiceGuide\Scripts\Efmark IVR\Welcome.vox,C:\Program Files\VoiceGuide\Scripts\Efmark IVR\EnterUserID.vox,1,0,, 161256.64 1 play start ok, lPlayId=580215 161304.10 1 tw dtmf 0 (1,48,48) 161304.13 1 event ScriptEventCode 0, code=48, state=1300 161304.16 1 LsGetNbrsPlayWelcMsg 0,0 161304.28 1 play PlaySoundStop ok 161304.35 1 state [Get IVR Code] Number Input 0 161304.42 1 rv add [Get IVR Code]{0} 161304.48 1 rvns add [Get IVR Code_PathTaken]{0} 161304.55 1 fn RunModule start 161304.62 1 tw DialogicEvent 134,TDX_CST,48,0,0,DE_DIGITS,, 161304.69 1 event ScriptEventCode TDX_CST, code=134, state=6001 161304.76 1 tw PlayEnd 1 580215 161304.83 1 play end id=580215, (current ID) 161304.90 1 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=6001 161304.97 1 tw DialogicEvent 129,TDX_PLAY,580215,0,0,,, 161305.04 1 event ScriptEventCode TDX_PLAY, code=129, state=6001 161305.27 1 timer clear 161305.35 1 timer set 0.4 EV_TIMEOUT_READYTOBEGINTRANSFER 161305.72 1 timer fired EV_TIMEOUT_READYTOBEGINTRANSFER 161305.79 1 event ScriptEventCode EV_TIMEOUT_READYTOBEGINTRANSFER, code=9012, state=1901 161305.86 1 LsXfer_1_Start : 9012(EV_TIMEOUT_READYTOBEGINTRANSFER),EV_TIMEOUT_READYTOBEGINTRANSFER,0,0,0,,, 161305.93 1 path {EV_TIMEOUT_READYTOBEGINTRANSFER} not found 161306.01 1 timeout on transfer attempt set by VG.INI [PBX] AnnouncedTransfersMaxWaitTime (30 sec) 161306.08 1 timer set 30 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG 161306.16 1 state [Operator] Blind Hookflash Transfer to 356 161306.49 1 tw PlayEnd 1 0 161306.57 1 play end id=0, (current ID) 161306.64 1 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1902 161306.72 1 LsXfer_2_OnEndHook1PlayDestNbr 8001,EV_PLAY_FINISHED,0,0,0,,, 161306.80 1 tw DialogicEvent 132,TDX_DIAL,0,0,0,,, 161306.88 1 event ScriptEventCode TDX_DIAL, code=132, state=1902 161306.95 1 LsXfer_2_OnEndHook1PlayDestNbr 132,TDX_DIAL,0,0,0,,, 161307.04 1 VG.INI [PBX] Transfer_Prefix_PauseAfter = 2 sec 161307.11 1 timer set 2 EV_TIMEOUT_Transfer_Prefix_PauseAfter 161309.13 1 timer fired EV_TIMEOUT_Transfer_Prefix_PauseAfter 161309.20 1 event ScriptEventCode EV_TIMEOUT_Transfer_Prefix_PauseAfter, code=9030, state=1902 161309.28 1 LsXfer_2_OnEndHook1PlayDestNbr 9030,EV_TIMEOUT_Transfer_Prefix_PauseAfter,0,0,0,,, 161309.35 1 Dial(356cp off) call 161309.54 1 Dial(356) ok 161309.62 1 timer set 30 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG 161309.96 1 tw PlayEnd 1 0 161310.03 1 play end id=0, (current ID) 161310.11 1 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1903 161310.19 1 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 8001,EV_PLAY_FINISHED,0,0,0,,, 161310.27 1 tw DialogicEvent 132,TDX_DIAL,0,0,0,,, 161310.35 1 event ScriptEventCode TDX_DIAL, code=132, state=1903 161310.43 1 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 132,TDX_DIAL,0,0,0,,, 161310.50 1 LsXfer_3 TDX_DIAL on a XT_HOOK_BLIND 161310.58 1 rv add [Hangup Time]{12/22/2005 4:13:10 PM} 161310.66 1 state Hanging up call... [LsXfer_3] 161310.74 1 HangupCall_Common hCall=1 161310.83 1 rec RecSoundStop ok 161310.91 1 play PlaySoundStop ok 161310.99 1 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 161311.07 1 fnHangupCall end 161311.21 1 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,, 161311.29 1 event ScriptEventCode TDX_SETHOOK, code=135, state=900 161311.37 1 LsAwaitingCalls EV_UNKNOWN_135 161311.45 1 event callstate IDLE 1 1,0,0 161311.54 1 WorkingMode@Idle= 161311.62 1 timer clear 161311.70 1 rec RecSoundStop ok 161311.79 1 play PlaySoundStop ok 161311.87 1 rv add [CallEndTime]{12/22/2005 4:13:11 PM} 161311.96 1 timer set 1 EV_TIMEOUT_TIMETOREINITLINE 161312.95 1 timer fired EV_TIMEOUT_TIMETOREINITLINE 161313.03 1 event ScriptEventCode EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=900 161313.11 1 init atidle reinit : start 161313.19 1 init atidle reinit iConferenceOtherLegLid=-1 161313.28 1 init atidle reinit : reset all LineState variables 161313.36 1 timer set 0.3 EV_TIMEOUT_ATERIDLE_ALLOWOUT 161313.45 1 state Waiting for a call... 161313.86 1 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT 161313.93 1 event ScriptEventCode EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=900 161603.65 0 load start [C:\Program Files\VoiceGuide\Scripts\Efmark IVR\Efivr.vgs] 161603.67 0 MemStructVgs_ClearVgs [1] 161608.91 0 load end 161608.98 0 loaded Script Id 1: C:\Program Files\VoiceGuide\Scripts\Efmark IVR\Efivr.vgs 161609.54 0 Erasing Script (new loaded) Id 5 161609.64 0 VgsScriptFree [5] 161609.74 0 MemStructVgs_ClearVgs [5] 161617.37 1 event callstate OFFERING 1 2,0,0 161617.47 1 script interpretor: VgMulti v6.0.2322 161617.56 1 fired OFFERING event to listeners 161617.65 1 set LineState().hCall = 1 in LINECALLSTATE_OFFERING 161617.75 1 cid CallerID vars set (in 'offering' event) [,,] 161617.84 1 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING 161617.93 1 rings=0, min rings before answer=0 (iCallerIdHasArrived=0) 161618.03 1 tw ring 1 161618.12 1 ring time since last ring event (sec): 0.00 161618.22 1 rings=1, min rings before answer=0 (iCallerIdHasArrived=0) 161618.31 1 answer as number of rings reached 161618.41 1 rv clear all 161618.50 1 init LineState ResetAtStartOfNewCall. 161618.59 1 answer the call 161618.69 1 timer clear 161618.80 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 161618.90 1 event ScriptEventCode TDX_CST, code=134, state=6001 161619.49 1 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND, 161619.58 1 event ScriptEventCode TDX_SETHOOK, code=135, state=6001 161619.68 1 event callstate CONNECTED 1 256,0,0 161619.77 1 LineEvCallState_Connected hDevice=1 params=256,0,0 161619.87 1 WorkingModes tapi= script= LineState().iState=6001 161621.04 1 Inband detection not enabled 161621.14 1 StartLoadedVgs at 12/22/2005 4:16:21 PM [VgMulti v6.0.2322] 161621.24 1 set LineState().iVgsIdx=1 161621.34 1 set sScriptToRunOnHangup=[] in StartLoadedVgs 161621.43 1 init StartLoadedVgs_InitLineState start 161621.54 1 rv add [$RV_STARTTIME]{12/22/2005 4:16:21 PM} 161621.63 1 rv add [$RV_DEVICEID]{1} 161621.72 1 rv add [$RV_CIDNAME]{} 161621.82 1 rvns add [PathApp]{C:\Program Files\VoiceGuide\} 161621.93 1 rvns add [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Efmark IVR\} 161622.02 1 rv add [$RV_CIDNUMBER]{} 161622.11 1 fn RunModule start 161622.21 1 tw DialogicEvent 134,TDX_CST,18824,0,0,DE_LCON,, 161622.32 1 event ScriptEventCode TDX_CST, code=134, state=6001 161622.57 1 timer clear 161622.68 1 state [Get IVR Code] Number Input 161622.77 1 state [Get IVR Code] Playing (Welcome.wav, EnterUserID.wav) 161622.87 1 tw ConvertWav2Vox C:\Program Files\VoiceGuide\Scripts\Efmark IVR\Welcome.wav,C:\Program Files\VoiceGuide\Scripts\Efmark IVR\EnterUserID.wav 161622.96 1 timer clear 161623.11 1 tw wav->vox convert end 786461,C:\Program Files\VoiceGuide\Scripts\Efmark IVR\Welcome.vox,C:\Program Files\VoiceGuide\Scripts\Efmark IVR\EnterUserID.vox,1,0,, 161623.24 1 play start ok, lPlayId=786802 161632.51 1 tw dtmf 0 (1,48,48) 161632.61 1 event ScriptEventCode 0, code=48, state=1300 161632.71 1 LsGetNbrsPlayWelcMsg 0,0 161632.83 1 play PlaySoundStop ok 161632.93 1 state [Get IVR Code] Number Input 0 161633.02 1 rv add [Get IVR Code]{0} 161633.12 1 rvns add [Get IVR Code_PathTaken]{0} 161633.23 1 fn RunModule start 161633.33 1 tw DialogicEvent 134,TDX_CST,48,0,0,DE_DIGITS,, 161633.43 1 event ScriptEventCode TDX_CST, code=134, state=6001 161633.52 1 tw PlayEnd 1 786802 161633.62 1 play end id=786802, (current ID) 161633.72 1 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=6001 161633.82 1 tw DialogicEvent 129,TDX_PLAY,786802,0,0,,, 161633.92 1 event ScriptEventCode TDX_PLAY, code=129, state=6001 161634.19 1 timer clear 161634.29 1 timer set 0.4 EV_TIMEOUT_READYTOBEGINTRANSFER 161634.69 1 timer fired EV_TIMEOUT_READYTOBEGINTRANSFER 161634.79 1 event ScriptEventCode EV_TIMEOUT_READYTOBEGINTRANSFER, code=9012, state=1901 161634.89 1 LsXfer_1_Start : 9012(EV_TIMEOUT_READYTOBEGINTRANSFER),EV_TIMEOUT_READYTOBEGINTRANSFER,0,0,0,,, 161634.99 1 path {EV_TIMEOUT_READYTOBEGINTRANSFER} not found 161635.09 1 timeout on transfer attempt set by VG.INI [PBX] AnnouncedTransfersMaxWaitTime (30 sec) 161635.20 1 timer set 30 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG 161635.29 1 state [Operator] Announced Hookflash Transfer to 356 161635.80 1 tw PlayEnd 1 0 161635.91 1 play end id=0, (current ID) 161635.00 1 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1902 161636.11 1 LsXfer_2_OnEndHook1PlayDestNbr 8001,EV_PLAY_FINISHED,0,0,0,,, 161636.20 1 tw DialogicEvent 132,TDX_DIAL,0,0,0,,, 161636.30 1 event ScriptEventCode TDX_DIAL, code=132, state=1902 161636.41 1 LsXfer_2_OnEndHook1PlayDestNbr 132,TDX_DIAL,0,0,0,,, 161636.52 1 VG.INI [PBX] Transfer_Prefix_PauseAfter = 2 sec 161636.62 1 timer set 2 EV_TIMEOUT_Transfer_Prefix_PauseAfter 161638.67 1 timer fired EV_TIMEOUT_Transfer_Prefix_PauseAfter 161638.77 1 event ScriptEventCode EV_TIMEOUT_Transfer_Prefix_PauseAfter, code=9030, state=1902 161638.87 1 LsXfer_2_OnEndHook1PlayDestNbr 9030,EV_TIMEOUT_Transfer_Prefix_PauseAfter,0,0,0,,, 161638.97 1 Dial(356, cp on) call 161639.20 1 Dial(356) ok 161639.30 1 timer set 30 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG 161710.22 1 timer fired EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG 161710.32 1 event ScriptEventCode EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG, code=9021, state=1903 161710.43 1 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 9021,EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG,0,0,0,,, 161710.54 1 Transfer timed out 161710.64 1 xfer dial ! 161711.02 1 tw PlayEnd 1 0 161711.11 1 play end id=0, (current ID) 161711.23 1 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1906 161711.34 1 LsXfer_5B : 8001(EV_PLAY_FINISHED),EV_PLAY_FINISHED,0,0,0,,, 161711.44 1 tw DialogicEvent 132,TDX_DIAL,0,0,0,,, 161711.54 1 event ScriptEventCode TDX_DIAL, code=132, state=1906 161711.64 1 LsXfer_5B : 132(EV_UNKNOWN_132),TDX_DIAL,0,0,0,,, 161711.76 1 sXferDialResult_SuccOrFail= 161711.86 1 XferGoDownSpecifiedPath iXferModule_PathsToTake_Max=3 (1)=timeout (2)= (3)= 161711.96 1 path 'timeout' not found 161712.07 1 XferGoDownSpecifiedPath: going down False path (iXferType=13) 161712.17 1 fn RunModule start 161712.44 1 timer clear 161712.54 1 state [Get IVR Code] Number Input 161712.64 1 state [Get IVR Code] Playing (Welcome.wav, EnterUserID.wav) 161712.75 1 tw ConvertWav2Vox C:\Program Files\VoiceGuide\Scripts\Efmark IVR\Welcome.wav,C:\Program Files\VoiceGuide\Scripts\Efmark IVR\EnterUserID.wav 161712.86 1 timer clear 161712.00 1 tw wav->vox convert end 836343,C:\Program Files\VoiceGuide\Scripts\Efmark IVR\Welcome.vox,C:\Program Files\VoiceGuide\Scripts\Efmark IVR\EnterUserID.vox,1,0,, 161713.13 1 play start ok, lPlayId=836694 161723.97 1 tw dtmf 0 (1,48,48) 161724.07 1 event ScriptEventCode 0, code=48, state=1300 161724.18 1 LsGetNbrsPlayWelcMsg 0,0 161724.30 1 play PlaySoundStop ok 161724.41 1 state [Get IVR Code] Number Input 0 161724.52 1 rv add [Get IVR Code]{0} 161724.63 1 rvns add [Get IVR Code_PathTaken]{0} 161724.73 1 fn RunModule start 161724.84 1 tw DialogicEvent 134,TDX_CST,48,0,0,DE_DIGITS,, 161724.95 1 event ScriptEventCode TDX_CST, code=134, state=6001 161725.05 1 tw PlayEnd 1 836694 161725.16 1 play end id=836694, (current ID) 161725.26 1 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=6001 161725.37 1 tw DialogicEvent 129,TDX_PLAY,836694,0,0,,, 161725.48 1 event ScriptEventCode TDX_PLAY, code=129, state=6001 161725.73 1 timer clear 161725.85 1 timer set 0.4 EV_TIMEOUT_READYTOBEGINTRANSFER 161726.25 1 timer fired EV_TIMEOUT_READYTOBEGINTRANSFER 161726.35 1 event ScriptEventCode EV_TIMEOUT_READYTOBEGINTRANSFER, code=9012, state=1901 161726.45 1 LsXfer_1_Start : 9012(EV_TIMEOUT_READYTOBEGINTRANSFER),EV_TIMEOUT_READYTOBEGINTRANSFER,0,0,0,,, 161726.56 1 path {EV_TIMEOUT_READYTOBEGINTRANSFER} not found 161726.66 1 timeout on transfer attempt set by VG.INI [PBX] AnnouncedTransfersMaxWaitTime (30 sec) 161726.77 1 timer set 30 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG 161726.87 1 state [Operator] Announced Hookflash Transfer to 356 161727.38 1 tw PlayEnd 1 0 161727.48 1 play end id=0, (current ID) 161727.59 1 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1902 161727.70 1 LsXfer_2_OnEndHook1PlayDestNbr 8001,EV_PLAY_FINISHED,0,0,0,,, 161727.81 1 tw DialogicEvent 132,TDX_DIAL,0,0,0,,, 161727.91 1 event ScriptEventCode TDX_DIAL, code=132, state=1902 161728.02 1 LsXfer_2_OnEndHook1PlayDestNbr 132,TDX_DIAL,0,0,0,,, 161728.13 1 VG.INI [PBX] Transfer_Prefix_PauseAfter = 2 sec 161728.24 1 timer set 2 EV_TIMEOUT_Transfer_Prefix_PauseAfter 161730.29 1 timer fired EV_TIMEOUT_Transfer_Prefix_PauseAfter 161730.40 1 event ScriptEventCode EV_TIMEOUT_Transfer_Prefix_PauseAfter, code=9030, state=1902 161730.51 1 LsXfer_2_OnEndHook1PlayDestNbr 9030,EV_TIMEOUT_Transfer_Prefix_PauseAfter,0,0,0,,, 161730.62 1 Dial(356, cp on) call 161730.86 1 Dial(356) ok 161730.96 1 timer set 30 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG 161802.15 1 timer fired EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG 161802.26 1 event ScriptEventCode EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG, code=9021, state=1903 161802.36 1 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 9021,EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG,0,0,0,,, 161802.47 1 Transfer timed out 161802.58 1 xfer dial ! 161803.03 1 tw PlayEnd 1 0 161803.14 1 play end id=0, (current ID) 161803.25 1 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1906 161803.36 1 LsXfer_5B : 8001(EV_PLAY_FINISHED),EV_PLAY_FINISHED,0,0,0,,, 161803.51 1 tw DialogicEvent 132,TDX_DIAL,0,0,0,,, 161803.61 1 event ScriptEventCode TDX_DIAL, code=132, state=1906 161803.73 1 LsXfer_5B : 132(EV_UNKNOWN_132),TDX_DIAL,0,0,0,,, 161803.84 1 sXferDialResult_SuccOrFail= 161803.95 1 XferGoDownSpecifiedPath iXferModule_PathsToTake_Max=3 (1)=timeout (2)= (3)= 161804.06 1 path 'timeout' not found 161804.17 1 XferGoDownSpecifiedPath: going down False path (iXferType=13) 161804.28 1 fn RunModule start 161804.48 1 timer clear 161804.59 1 state [Get IVR Code] Number Input 161804.70 1 state [Get IVR Code] Playing (Welcome.wav, EnterUserID.wav) 161804.82 1 tw ConvertWav2Vox C:\Program Files\VoiceGuide\Scripts\Efmark IVR\Welcome.wav,C:\Program Files\VoiceGuide\Scripts\Efmark IVR\EnterUserID.wav 161804.93 1 timer clear 161805.17 1 tw wav->vox convert end 888418,C:\Program Files\VoiceGuide\Scripts\Efmark IVR\Welcome.vox,C:\Program Files\VoiceGuide\Scripts\Efmark IVR\EnterUserID.vox,1,0,, 161805.45 1 play start ok, lPlayId=889009 161817.26 1 tw PlayEnd 1 889009 161817.39 1 play end id=889009, (current ID) 161817.51 1 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1300 161817.63 1 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED 161817.74 1 path {EV_PLAY_FINISHED} not found 161817.85 1 timer set 10 EV_TIMEOUT_HANGUP 161817.96 1 timer set 6 EV_TIMEOUT_ENTERDATA 161818.07 1 tw DialogicEvent 129,TDX_PLAY,889009,0,0,,, 161818.18 1 event ScriptEventCode TDX_PLAY, code=129, state=1301 161818.29 1 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY 161818.40 1 path {TDX_PLAY} not found 161819.81 1 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,DISCONNECT_TAPI1, 161819.93 1 event ScriptEventCode DISCONNECT_TAPI1, code=134, state=1301 161820.04 1 LsGetNbrsRxDigits EV_UNKNOWN_134,DISCONNECT_TAPI1 161820.14 1 path {DISCONNECT_TAPI1} not found 161820.25 1 rv add [Hangup Time]{12/22/2005 4:18:20 PM} 161820.36 1 state Hanging up call... [Default Handler 20: DISCONNECT_TAPI1] 161820.48 1 HangupCall_Common hCall=1 161820.59 1 rec RecSoundStop ok 161820.70 1 play PlaySoundStop ok 161820.82 1 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 161820.93 1 fnHangupCall end 161821.05 1 event ScriptEventCode TDX_CST, code=134, state=900 161821.16 1 LsAwaitingCalls EV_UNKNOWN_134 161821.27 1 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,, 161821.39 1 event ScriptEventCode TDX_SETHOOK, code=135, state=900 161821.52 1 LsAwaitingCalls EV_UNKNOWN_135 161821.65 1 event callstate IDLE 1 1,0,0 161821.78 1 WorkingMode@Idle= 161821.90 1 timer clear 161822.03 1 rec RecSoundStop ok 161822.16 1 play PlaySoundStop ok 161822.28 1 rv add [CallEndTime]{12/22/2005 4:18:22 PM} 161822.40 1 timer set 1 EV_TIMEOUT_TIMETOREINITLINE 161823.43 1 timer fired EV_TIMEOUT_TIMETOREINITLINE 161823.53 1 event ScriptEventCode EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=900 161823.65 1 init atidle reinit : start 161823.76 1 init atidle reinit iConferenceOtherLegLid=-1 161823.88 1 init atidle reinit : reset all LineState variables 161824.01 1 timer set 0.3 EV_TIMEOUT_ATERIDLE_ALLOWOUT 161824.12 1 state Waiting for a call... 161824.53 1 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT 161824.63 1 event ScriptEventCode EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=900 161857.09 0 load start [C:\Program Files\VoiceGuide\Scripts\Efmark IVR\Efivr.vgs] 161857.12 0 MemStructVgs_ClearVgs [5] 161901.05 0 load end 161901.09 0 loaded Script Id 5: C:\Program Files\VoiceGuide\Scripts\Efmark IVR\Efivr.vgs 161901.31 0 Erasing Script (new loaded) Id 1 161901.34 0 VgsScriptFree [1] 161901.36 0 MemStructVgs_ClearVgs [1] Share this post Link to post
Guest Kevin Sheng Report post Posted 12/22/2005 09:26 PM I changed to use PBX hookflash Blind, transfer is done, but it is not transfered. When i use handset I need press 1 before enter extension, where do I tell "1" is the key before extension is pressed. ???? thanks. 164041.88 1 timer set 2 EV_TIMEOUT_Transfer_Prefix_PauseAfter 164043.94 1 timer fired EV_TIMEOUT_Transfer_Prefix_PauseAfter 164044.05 1 event ScriptEventCode EV_TIMEOUT_Transfer_Prefix_PauseAfter, code=9030, state=1902 164044.16 1 LsXfer_2_OnEndHook1PlayDestNbr 9030,EV_TIMEOUT_Transfer_Prefix_PauseAfter,0,0,0,,, 164044.27 1 Dial(356cp off) call 164044.39 1 Dial(356) ok 164044.50 1 timer set 30 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG 164044.79 1 tw PlayEnd 1 0 164044.90 1 play end id=0, (current ID) 164045.02 1 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1903 164045.13 1 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 8001,EV_PLAY_FINISHED,0,0,0,,, 164045.25 1 tw DialogicEvent 132,TDX_DIAL,0,0,0,,, 164045.36 1 event ScriptEventCode TDX_DIAL, code=132, state=1903 164045.48 1 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 132,TDX_DIAL,0,0,0,,, 164045.59 1 LsXfer_3 TDX_DIAL on a XT_HOOK_BLIND 164045.71 1 rv add [Hangup Time]{12/22/2005 4:40:45 PM} 164045.82 1 state Hanging up call... [LsXfer_3] Share this post Link to post
SupportTeam Report post Posted 12/22/2005 11:01 PM Quote Using handset when I receive a call, I press "flash" button, and it prompts me to press 1 to transfer to an extension, I press extension 1234. How am I supposed to do this thing in Voice Guide. Sounds like you should be specifying 1 as the first digit, followed by the extension. You may want to use pause between the 1 and the extension, eg: 1,356 Share this post Link to post
Guest Kevin Sheng Report post Posted 12/23/2005 02:26 PM I tried 1,356 and it beeps 1, quickly followed by 356, then LsXfer_3 shows in VG line state, and it hangs up. I tried monitored hookflash, no luck. Is there any configuration anywhere I need to change anything to make this work? It now works only in handset. Thanks. Kevin Share this post Link to post
Guest More Info Report post Posted 12/23/2005 08:02 PM I am using windows 2003 server Dialogic card 4PCIU I tried the following options to no avail. ,1,356,, 1,,356 what else can be done to make this work? The project is overdue and the customer is waiting......and this is holiday season, no one is working ...? Share this post Link to post
Guest More log file Report post Posted 12/23/2005 08:29 PM 154130.73 1 timer clear 154130.82 1 tw wav->vox convert end 94280,C:\Program Files\VoiceGuide\Scripts\Efmark IVR\Welcome.vox,C:\Program Files\VoiceGuide\Scripts\Efmark IVR\EnterUserID.vox,1,0,, 154130.00 1 play start ok, lPlayId=94450 154137.54 1 tw dtmf 0 (1,48,48) 154137.57 1 event ScriptEventCode 0, code=48, state=1300 154137.59 1 LsGetNbrsPlayWelcMsg 0,0 154137.63 1 play PlaySoundStop ok 154137.66 1 state [Get IVR Code] Number Input 0 154137.68 1 rv add [Get IVR Code]{0} 154137.70 1 rvns add [Get IVR Code_PathTaken]{0} 154137.70 1 fn RunModule start 154137.75 1 tw DialogicEvent 134,TDX_CST,48,0,0,DE_DIGITS,, 154137.79 1 event ScriptEventCode TDX_CST, code=134, state=6001 154137.80 1 tw PlayEnd 1 94450 154137.82 1 play end id=94450, (current ID) 154137.84 1 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=6001 154137.86 1 tw DialogicEvent 129,TDX_PLAY,94450,0,0,,, 154137.89 1 event ScriptEventCode TDX_PLAY, code=129, state=6001 154138.05 1 timer clear 154138.09 1 timer set 0.4 EV_TIMEOUT_READYTOBEGINTRANSFER 154138.46 1 timer fired EV_TIMEOUT_READYTOBEGINTRANSFER 154138.48 1 event ScriptEventCode EV_TIMEOUT_READYTOBEGINTRANSFER, code=9012, state=1901 154138.51 1 LsXfer_1_Start : 9012(EV_TIMEOUT_READYTOBEGINTRANSFER),EV_TIMEOUT_READYTOBEGINTRANSFER,0,0,0,,, 154138.54 1 path {EV_TIMEOUT_READYTOBEGINTRANSFER} not found 154138.57 1 timeout on transfer attempt set by VG.INI [PBX] AnnouncedTransfersMaxWaitTime (30 sec) 154138.60 1 timer set 30 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG 154138.64 1 state [Operator] Blind Hookflash Transfer to 1,,2,6,0,, 154138.93 1 tw PlayEnd 1 0 154138.95 1 play end id=0, (current ID) 154138.00 1 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1902 154139.02 1 LsXfer_2_OnEndHook1PlayDestNbr 8001,EV_PLAY_FINISHED,0,0,0,,, 154139.05 1 tw DialogicEvent 132,TDX_DIAL,0,0,0,,, 154139.08 1 event ScriptEventCode TDX_DIAL, code=132, state=1902 154139.10 1 LsXfer_2_OnEndHook1PlayDestNbr 132,TDX_DIAL,0,0,0,,, 154139.13 1 VG.INI [PBX] Transfer_Prefix_PauseAfter = 2 sec 154139.16 1 timer set 2 EV_TIMEOUT_Transfer_Prefix_PauseAfter 154141.17 1 timer fired EV_TIMEOUT_Transfer_Prefix_PauseAfter 154141.20 1 event ScriptEventCode EV_TIMEOUT_Transfer_Prefix_PauseAfter, code=9030, state=1902 154141.23 1 LsXfer_2_OnEndHook1PlayDestNbr 9030,EV_TIMEOUT_Transfer_Prefix_PauseAfter,0,0,0,,, 154141.26 1 Dial(1,,2,6,0,,cp off) call 154141.29 1 Dial(1,,2,6,0,,) ok 154141.32 1 timer set 30 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG 154147.90 1 tw PlayEnd 1 0 154147.92 1 play end id=0, (current ID) 154147.95 1 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1903 154147.97 1 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 8001,EV_PLAY_FINISHED,0,0,0,,, 154148.00 1 tw DialogicEvent 132,TDX_DIAL,0,0,0,,, 154148.03 1 event ScriptEventCode TDX_DIAL, code=132, state=1903 154148.06 1 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 132,TDX_DIAL,0,0,0,,, 154148.08 1 LsXfer_3 TDX_DIAL on a XT_HOOK_BLIND 154148.12 1 rv add [Hangup Time]{12/23/2005 3:41:48 PM} 154148.16 1 state Hanging up call... [LsXfer_3] 154148.19 1 HangupCall_Common hCall=1 154148.22 1 rec RecSoundStop ok 154148.25 1 play PlaySoundStop ok 154148.27 1 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 154148.30 1 fnHangupCall end 154148.42 1 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,, 154148.45 1 event ScriptEventCode TDX_SETHOOK, code=135, state=900 154148.48 1 LsAwaitingCalls EV_UNKNOWN_135 154148.51 1 event callstate IDLE 1 1,0,0 154148.54 1 WorkingMode@Idle= 154148.56 1 timer clear 154148.60 1 rec RecSoundStop ok 154148.64 1 play PlaySoundStop ok 154148.66 1 rv add [CallEndTime]{12/23/2005 3:41:48 PM} 154148.74 1 timer set 1 EV_TIMEOUT_TIMETOREINITLINE 154149.67 1 timer fired EV_TIMEOUT_TIMETOREINITLINE 154149.70 1 event ScriptEventCode EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=900 154149.73 1 init atidle reinit : start 154149.76 1 init atidle reinit iConferenceOtherLegLid=-1 154149.78 1 init atidle reinit : reset all LineState variables 154149.81 1 timer set 0.3 EV_TIMEOUT_ATERIDLE_ALLOWOUT 154149.84 1 state Waiting for a call... 154150.19 1 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT 154150.21 1 event ScriptEventCode EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=900 154159.45 0 sys cleanup Start 154159.51 0 sys cleanup End Share this post Link to post
SupportTeam Report post Posted 12/23/2005 10:38 PM Quote tried 1,356 and it beeps 1, quickly followed by 356, If the caller can hear the DTMF tones being played than it sounds like the hookflash length is too short. Have you read this: http://www.voiceguide.com/vghelp/html/Dial...llTransfers.htm Share this post Link to post
Guest Happy Programmer Report post Posted 12/26/2005 09:04 PM That does it, thanks very much for your support. Share this post Link to post
