CSI Report post Posted 12/28/2005 09:42 PM I have been unable to get dates to play properly using the Say Number module. In this example, I want "December 28th 2005." and I get "Twelfth, 2005." I looked at the VBScript generated and everything looks as though it should work, but it is not. '********************************************* 'Appended by the Say Number module '********************************************* Set vg = CreateObject("VoiceGuide.CommandLink") sWavList=DateMMDDYYYY("12/28/2005") vg.Play_Start 6, sWavList Set vg = Nothing '********************************************* vbs_6_SayNumber.vbs Share this post Link to post
CSI Report post Posted 12/28/2005 10:10 PM I thought this sounded like a familiar topic, and I found Topic where I had asked this question before. The problem is not that the script is wrong, it is calling DDMMYYYY instead of MMDDYYYY. When I modify the VBS's DDMMYYYY section to be identical to the MMDDYYYY, it works fine. In short, I have fixed the issue with a workaround but I would consider it a bug. Share this post Link to post
SupportTeam Report post Posted 12/28/2005 11:31 PM The issue that was noted in http://voiceguide.com/forums/index.php?showtopic=1970 was fixed in VG released soon after that post was made. Which version of VG are you using? It sounds like you are still using the old version of lib_num2wav.vbs. vbs_6_SayNumber.vbs shows that function DateMMDDYYYY is called, so I'm not sure why you needed to modify the DDMMYYYY function... Share this post Link to post
SupportTeam Report post Posted 12/28/2005 11:45 PM Here is the current latest lib_num2wav.vbs lib_num2wav.vbs Share this post Link to post
