Cumulative Effects In Vbscript
The following vbscript get a single character from ASCII but does not add to cumulative effect in the variable cumulativeid. Can you help me please? I want that the variable cumulativeid stores cumulative values made available through module Get Numbers for 20 cycles. Please help URGENTLY.
dim emaildig,cumulativeid
vg.RvSet $RV_LINEID, "emaildig", chr($RV[Get Numbers])
cumulativeid=cumulativeid&emaildig
Sounds like you want to append some data to an existing RV.
Try something like this:
sCumulativeStore = "$RV[CumulativeStore]"
sCumulativeStore = sCumulativeStore & chr($RV[Get Numbers])
vg.RvSet $RV_LINEID, "CumulativeStore ", sCumulativeStore)
Dear sir
thanks for the reply. The script helped to some extent.
But actually what I wanted the script to do is to create a string of characters from each entry of number made to the Get Numbers module. That means when the call starts the user enters a number say 65 then the same should be stored in Cumulativestore as character of that ASCII value, which in this case is "A". When the Get Numbers module runs again and if the caller enters 65 then the concatenated value of Cumulativestore will be AB and not B alone.
I am trying for such a cumulative addition.Any advice will be greatly appreciated.
thanks.
The VBScript as provided will do cumulative addition... have you tried using it?
Please post a script demonstrating your problem and a trace capturing a call made into the script. (.ZIPed)
Dear sir
I have tied your suggestions. Here is the log.
063635.12 0 tapi callstate start
063635.12 0 tapi callstate OFFERING 65604 0 4
063635.14 0 rv clear
063635.14 0 Answer the call at 1/1/2006 6:36:35 AM
063635.14 0 lineAnswer(65604) => 65587
063635.17 0 ring 1
063635.17 0 tapi callstate start
063635.19 0 tapi callstate ACCEPTED 65604 0 0
063635.22 0 tapi Reply (LineEvReply) ok 65587 0
063635.25 0 tapi callstate start
063635.25 0 tapi callstate CONNECTED 65604 0 0
063635.25 0 callstate CONNECTED 65604,0,0
063635.26 0 WorkingModeTAPI@Connected=
063635.26 0 WorkingModeScript@Connected=
063635.28 0 Inband detection not enabled
063635.28 0 StartLoadedVgs at 1/1/2006 6:36:35 AM, script interpretor VgMulti v5.2.5012 0
063635.28 0 rv ns add [scriptsPath]{D:\Program Files\VoiceGuide\Scripts\}
063635.28 0 rv ns add [scriptPath]{D:\Program Files\VoiceGuide\Scripts}
063635.30 0 rv lg add [$RV_STARTTIME]{1/1/2006 6:36:35 AM}
063635.30 0 rv lg add [$RV_DEVICEID]{0}
063635.31 0 rv lg add [$RV_CIDNAME]{}
063635.31 0 rv ns add [PathApp]{D:\Program Files\VoiceGuide\}
063635.31 0 rv lg add [$RV_CIDNUMBER]{}
063635.33 0 rv lg add [$RV_DNIS]{}
063635.33 0 rv lg add [DNIS]{}
063635.33 0 timer clear
063635.34 0 state [Get Numbers] Number Input
063635.34 0 state [Get Numbers] Playing (D:\Program Files\VoiceGuide\system\voice\VmbPinEnterNew.wav)
063635.34 0 play set playid=517921
063635.45 0 PlaySoundStart ok [D:\Program Files\VoiceGuide\system\voice\VmbPinEnterNew.wav]
063635.47 0 timer clear
063635.76 0 dial start any summary:|0:hc>0|
063637.73 0 play end current play (playid=517921)
063637.75 0 ScriptEventCode 8001 iLineState=1300
063637.75 0 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
063637.76 0 eng set timer EV_TIMEOUT_REPLAYMSG time=5
063637.76 0 timer set 5 EV_TIMEOUT_REPLAYMSG
063637.87 0 dtmf 6 (65604,54,2)
063637.89 0 ScriptEventCode 54 iLineState=1301
063637.89 0 LsGetNbrsRxDigits 6
063637.89 0 state [Get Numbers] Number Input 6
063637.90 0 path {6} not found
063637.90 0 timer set 6 EV_TIMEOUT_ENTERDATA
063638.51 0 dtmf 5 (65604,53,2)
063638.51 0 ScriptEventCode 53 iLineState=1301
063638.53 0 LsGetNbrsRxDigits 5
063638.53 0 state [Get Numbers] Number Input 65
063638.55 0 rv lg add [Get Numbers]{65}
063638.55 0 rv ns add [Get Numbers_PathTaken]{65}
063638.56 0 timer clear
063638.58 0 state [Run VB Script 1] Running VB Script...
063638.59 0 rv replace start: [set vg = CreateObject("VoiceGuide.CommandLink")
063638.59 0 rv ns [PathSysVoice]{}[PathApp]{D:\Program Files\VoiceGuide\}[PathDataVm]{D:\Program Files\VoiceGuide\data\}[PathVgSys]{D:\Program Files\VoiceGuide\system\}[scriptsPath]{D:\Program Files\VoiceGuide\Scripts\}[scriptPath]{D:\Program Files\VoiceGuide\Scripts}[$RV_STARTTIME]{1/1/2006 6:36:35 AM}[$RV_DEVICEID]{0}[$RV_CIDNAME]{}[PathApp]{D:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[$RV_DNIS]{}[DNIS]{}[Get Numbers]{65}[Get Numbers_PathTaken]{65}
063638.62 0 eng run vbs [wscript "D:\Program Files\VoiceGuide\temp\vbs_0_1_0101063638.vbs" //I] copy of script in: vbs_0_1_0101063638.vbs
063638.65 0 VBScript Run continuing...
063638.69 0 timer clear
063638.69 0 state [Get Numbers] Number Input
063638.70 0 state [Get Numbers] Playing (D:\Program Files\VoiceGuide\system\voice\VmbPinEnterNew.wav)
063638.72 0 play set playid=521296
063638.84 0 PlaySoundStart ok [D:\Program Files\VoiceGuide\system\voice\VmbPinEnterNew.wav]
063638.86 0 timer clear
063638.92 0 cl RvSet CumulativeStore , A
063638.94 0 rv lg add [CumulativeStore ]{A}
063641.11 0 play end current play (playid=521296)
063641.12 0 ScriptEventCode 8001 iLineState=1300
063641.14 0 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
063641.15 0 eng set timer EV_TIMEOUT_REPLAYMSG time=5
063641.15 0 timer set 5 EV_TIMEOUT_REPLAYMSG
063641.19 0 dtmf 6 (65604,54,2)
063641.19 0 ScriptEventCode 54 iLineState=1301
063641.20 0 LsGetNbrsRxDigits 6
063641.22 0 state [Get Numbers] Number Input 6
063641.23 0 path {6} not found
063641.25 0 timer set 6 EV_TIMEOUT_ENTERDATA
063641.58 0 dtmf 6 (65604,54,2)
063641.59 0 ScriptEventCode 54 iLineState=1301
063641.61 0 LsGetNbrsRxDigits 6
063641.61 0 state [Get Numbers] Number Input 66
063641.62 0 rv lg add [Get Numbers]{66}
063641.64 0 rv ns add [Get Numbers_PathTaken]{66}
063641.65 0 timer clear
063641.67 0 state [Run VB Script 1] Running VB Script...
063641.67 0 rv replace start: [set vg = CreateObject("VoiceGuide.CommandLink")
063641.69 0 rv ns [PathSysVoice]{}[PathApp]{D:\Program Files\VoiceGuide\}[PathDataVm]{D:\Program Files\VoiceGuide\data\}[PathVgSys]{D:\Program Files\VoiceGuide\system\}[scriptsPath]{D:\Program Files\VoiceGuide\Scripts\}[scriptPath]{D:\Program Files\VoiceGuide\Scripts}[$RV_STARTTIME]{1/1/2006 6:36:35 AM}[$RV_DEVICEID]{0}[$RV_CIDNAME]{}[PathApp]{D:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[$RV_DNIS]{}[DNIS]{}[Get Numbers]{65}[Get Numbers_PathTaken]{65}[CumulativeStore ]{A}[Get Numbers]{66}[Get Numbers_PathTaken]{66}
063641.70 0 eng run vbs [wscript "D:\Program Files\VoiceGuide\temp\vbs_0_2_0101063641.vbs" //I] copy of script in: vbs_0_2_0101063641.vbs
063641.75 0 VBScript Run continuing...
063641.76 0 timer clear
063641.78 0 state [Get Numbers] Number Input
063641.80 0 state [Get Numbers] Playing (D:\Program Files\VoiceGuide\system\voice\VmbPinEnterNew.wav)
063641.80 0 play set playid=524375
063641.94 0 PlaySoundStart ok [D:\Program Files\VoiceGuide\system\voice\VmbPinEnterNew.wav]
063641.95 0 timer clear
063642.01 0 cl RvSet CumulativeStore , B
063642.03 0 rv lg add [CumulativeStore ]{B}
063644.22 0 play end current play (playid=524375)
063644.22 0 ScriptEventCode 8001 iLineState=1300
063644.23 0 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
063644.25 0 eng set timer EV_TIMEOUT_REPLAYMSG time=5
063644.26 0 timer set 5 EV_TIMEOUT_REPLAYMSG
063644.30 0 dtmf 6 (65604,54,2)
063644.31 0 ScriptEventCode 54 iLineState=1301
063644.33 0 LsGetNbrsRxDigits 6
063644.33 0 state [Get Numbers] Number Input 6
063644.34 0 path {6} not found
063644.36 0 timer set 6 EV_TIMEOUT_ENTERDATA
063644.92 0 dtmf 7 (65604,55,2)
063644.94 0 ScriptEventCode 55 iLineState=1301
063644.95 0 LsGetNbrsRxDigits 7
063644.95 0 state [Get Numbers] Number Input 67
063644.97 0 rv lg add [Get Numbers]{67}
063644.98 0 rv ns add [Get Numbers_PathTaken]{67}
063644.00 0 timer clear
063645.01 0 state [Run VB Script 1] Running VB Script...
063645.01 0 rv replace start: [set vg = CreateObject("VoiceGuide.CommandLink")
063645.03 0 rv ns [PathSysVoice]{}[PathApp]{D:\Program Files\VoiceGuide\}[PathDataVm]{D:\Program Files\VoiceGuide\data\}[PathVgSys]{D:\Program Files\VoiceGuide\system\}[scriptsPath]{D:\Program Files\VoiceGuide\Scripts\}[scriptPath]{D:\Program Files\VoiceGuide\Scripts}[$RV_STARTTIME]{1/1/2006 6:36:35 AM}[$RV_DEVICEID]{0}[$RV_CIDNAME]{}[PathApp]{D:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[$RV_DNIS]{}[DNIS]{}[Get Numbers]{65}[Get Numbers_PathTaken]{65}[CumulativeStore ]{A}[Get Numbers]{66}[Get Numbers_PathTaken]{66}[CumulativeStore ]{B}[Get Numbers]{67}[Get Numbers_PathTaken]{67}
063645.05 0 eng run vbs [wscript "D:\Program Files\VoiceGuide\temp\vbs_0_3_0101063645.vbs" //I] copy of script in: vbs_0_3_0101063645.vbs
063645.09 0 VBScript Run continuing...
063645.11 0 timer clear
063645.12 0 state [Get Numbers] Number Input
063645.14 0 state [Get Numbers] Playing (D:\Program Files\VoiceGuide\system\voice\VmbPinEnterNew.wav)
063645.14 0 play set playid=527718
063645.28 0 PlaySoundStart ok [D:\Program Files\VoiceGuide\system\voice\VmbPinEnterNew.wav]
063645.30 0 timer clear
063645.36 0 cl RvSet CumulativeStore , C
063645.37 0 rv lg add [CumulativeStore ]{C}
063647.56 0 play end current play (playid=527718)
063647.58 0 ScriptEventCode 8001 iLineState=1300
063647.59 0 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
063647.59 0 eng set timer EV_TIMEOUT_REPLAYMSG time=5
063647.61 0 timer set 5 EV_TIMEOUT_REPLAYMSG
063647.62 0 dtmf 6 (65604,54,2)
063647.64 0 ScriptEventCode 54 iLineState=1301
063647.65 0 LsGetNbrsRxDigits 6
063647.67 0 state [Get Numbers] Number Input 6
063647.69 0 path {6} not found
063647.69 0 timer set 6 EV_TIMEOUT_ENTERDATA
063648.14 0 dtmf 8 (65604,56,2)
063648.15 0 ScriptEventCode 56 iLineState=1301
063648.17 0 LsGetNbrsRxDigits 8
063648.19 0 state [Get Numbers] Number Input 68
063648.20 0 rv lg add [Get Numbers]{68}
063648.20 0 rv ns add [Get Numbers_PathTaken]{68}
063648.22 0 timer clear
063648.23 0 state [Run VB Script 1] Running VB Script...
063648.25 0 rv replace start: [set vg = CreateObject("VoiceGuide.CommandLink")
063648.26 0 rv ns [PathSysVoice]{}[PathApp]{D:\Program Files\VoiceGuide\}[PathDataVm]{D:\Program Files\VoiceGuide\data\}[PathVgSys]{D:\Program Files\VoiceGuide\system\}[scriptsPath]{D:\Program Files\VoiceGuide\Scripts\}[scriptPath]{D:\Program Files\VoiceGuide\Scripts}[$RV_STARTTIME]{1/1/2006 6:36:35 AM}[$RV_DEVICEID]{0}[$RV_CIDNAME]{}[PathApp]{D:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[$RV_DNIS]{}[DNIS]{}[Get Numbers]{65}[Get Numbers_PathTaken]{65}[CumulativeStore ]{A}[Get Numbers]{66}[Get Numbers_PathTaken]{66}[CumulativeStore ]{B}[Get Numbers]{67}[Get Numbers_PathTaken]{67}[CumulativeStore ]{C}[Get Numbers]{68}[Get Numbers_PathTaken]{68}
063648.28 0 eng run vbs [wscript "D:\Program Files\VoiceGuide\temp\vbs_0_4_0101063648.vbs" //I] copy of script in: vbs_0_4_0101063648.vbs
063648.33 0 VBScript Run continuing...
063648.34 0 timer clear
063648.36 0 state [Get Numbers] Number Input
063648.37 0 state [Get Numbers] Playing (D:\Program Files\VoiceGuide\system\voice\VmbPinEnterNew.wav)
063648.37 0 play set playid=530953
063648.51 0 PlaySoundStart ok [D:\Program Files\VoiceGuide\system\voice\VmbPinEnterNew.wav]
063648.53 0 timer clear
063648.58 0 cl RvSet CumulativeStore , D
063648.59 0 rv lg add [CumulativeStore ]{D}
063650.80 0 play end current play (playid=530953)
063650.80 0 ScriptEventCode 8001 iLineState=1300
063650.81 0 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
063650.83 0 eng set timer EV_TIMEOUT_REPLAYMSG time=5
063650.84 0 timer set 5 EV_TIMEOUT_REPLAYMSG
063650.00 0 dtmf * (65604,42,2)
063650.00 0 ScriptEventCode 42 iLineState=1301
063651.01 0 LsGetNbrsRxDigits *
063651.03 0 rv lg add [Get Numbers]{}
063651.05 0 rv ns add [Get Numbers_PathTaken]{*}
063651.06 0 timer clear
063651.06 0 state [Play 1] Playing
063651.08 0 state [Play 1] Playing (D:\VoiceGuide\AmitabhaSoundFiles\THANKS.WAV)
063651.09 0 play set playid=533671
063651.22 0 PlaySoundStart ok [D:\VoiceGuide\AmitabhaSoundFiles\THANKS.WAV]
063651.23 0 timer clear
063651.23 0 RunModule PLAY end
063654.42 0 tapi callstate start
063654.44 0 tapi callstate DISCONNECTED 65604 1 0
063654.44 0 ScriptEventCode 9250 iLineState=1100
063654.45 0 LsPlayMsg EV_REMOTEPARTY_DISCONNECT
063654.47 0 rv lg add [Hangup Time]{1/1/2006 6:36:54 AM}
063654.48 0 state Hanging up call...
063654.50 0 RecSoundStop ok
063655.36 0 PlaySoundStop err=0
063655.37 0 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
063655.39 0 fnHangupCall end
063655.61 0 tapi callstate start
063655.62 0 tapi callstate IDLE 65604 0 0
063655.64 0 WorkingMode@Idle=
063655.64 0 timer clear
063655.67 0 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
063655.69 0 tapi Reply (LineEvReply) ok 65570 0
063656.69 0 timer fired EV_TIMEOUT_TIMETOREINITLINE
063656.69 0 ScriptEventCode 9008 iLineState=900
063656.70 0 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
063656.72 0 ReinitTelephony due to IDLE
063656.73 0 tapic lineDeallocateCall(MainCall:65604) 0
063657.20 0 lineOpen(0)=>
063657.20 0 state Waiting for a call...
063657.22 0 LineHandle=65553
063657.23 0 amchk set AMdet=False in Reinit@idle
063657.25 0 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
063657.58 0 dial start any summary:|0:rdy=0|
063700.55 0 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
063700.55 0 ScriptEventCode 9013 iLineState=900
063700.58 0 dial start any summary:|0:idx=0|
063717.76 0 sys cleanup Start
063717.78 0 sys cleanup End
I am not able to see that the variable cumulativestore is containing ABCD. Instead it seems to contain each one alphabet saperately.Please guide me on how to get the string ABCD stored in Cumulativestore and make it available by a result variable ahead.
Scripts.rar
Looks like there was a small typo in the script we provided. The script below should work:
vg.RvSet $RV_LINEID, "CumulativeStore", sCumulativeStore)
See how in the previous provided script there was a space between the end of CumulativeStore and the quote character. This resulted in the variable $RV[CumulativeStore ] being set (again note the space at end), which is different to $RV[CumulativeStore] which has no space at the end.
thanks. It works well. But when I used Cumulativesotore@rediffmail.com in the send email module it gave an error that mail not configured. Can I directly use the value as character string if ahead in some module I use Cumulativesotore? Please advice. Thanks for the help.
when I used @rediffmail.comin the send email module it gave an error that mail not configured.
Do you have a trace?
I suspect you should be using:
$RV[CumulativeStore]@rediffmail.com
Its working now.Thanks a lot again. But send email is failing. Actually its using correct email ID but is not queing up the emails in Micorsoft Outlook. I want it to be queued up so that all are sent in night. I have configured MSOutlook as my default mail client. What should be done now?
Please help me understand this log please. The database contains email ids such as yahoo.com, rediffmail.com and he email is not sent to this id.
63713.16 0 tapi callstate start
163713.16 0 tapi callstate OFFERING 65740 0 4
163713.16 0 rv clear
163713.17 0 Answer the call at 1/4/2006 4:37:13 PM
163713.19 0 lineAnswer(65740) => 65723
163713.19 0 ring 1
163713.20 0 tapi callstate start
163713.20 0 tapi callstate ACCEPTED 65740 0 0
163713.20 0 dial start any summary:|0:hc>0|
163713.25 0 tapi Reply (LineEvReply) ok 65723 0
163713.27 0 tapi callstate start
163713.27 0 tapi callstate CONNECTED 65740 0 0
163713.28 0 callstate CONNECTED 65740,0,0
163713.28 0 WorkingModeTAPI@Connected=
163713.28 0 WorkingModeScript@Connected=
163713.28 0 Inband detection not enabled
163713.30 0 StartLoadedVgs at 1/4/2006 4:37:13 PM, script interpretor VgMulti v5.2.5012 0
163713.30 0 rv ns add [scriptsPath]{D:\Program Files\VoiceGuide\Scripts\}
163713.30 0 rv ns add [scriptPath]{D:\Program Files\VoiceGuide\Scripts}
163713.31 0 rv lg add [$RV_STARTTIME]{1/4/2006 4:37:13 PM}
163713.31 0 rv lg add [$RV_DEVICEID]{0}
163713.31 0 rv lg add [$RV_CIDNAME]{}
163713.33 0 rv ns add [PathApp]{D:\Program Files\VoiceGuide\}
163713.33 0 rv lg add [$RV_CIDNUMBER]{}
163713.33 0 rv lg add [$RV_DNIS]{}
163713.33 0 rv lg add [DNIS]{}
163713.34 0 timer clear
163713.34 0 state [Get Numbers] Number Input
163713.36 0 state [Get Numbers] Playing (D:\Program Files\VoiceGuide\system\voice\VmbPinEnterNew.wav)
163713.36 0 play set playid=203921
163713.50 0 PlaySoundStart ok [D:\Program Files\VoiceGuide\system\voice\VmbPinEnterNew.wav]
163713.52 0 timer clear
163715.78 0 play end current play (playid=203921)
163715.80 0 ScriptEventCode 8001 iLineState=1300
163715.80 0 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
163715.81 0 eng set timer EV_TIMEOUT_REPLAYMSG time=5
163715.81 0 timer set 5 EV_TIMEOUT_REPLAYMSG
163715.95 0 dtmf 6 (65740,54,2)
163715.95 0 ScriptEventCode 54 iLineState=1301
163715.95 0 LsGetNbrsRxDigits 6
163715.95 0 state [Get Numbers] Number Input 6
163715.97 0 path {6} not found
163715.97 0 timer set 6 EV_TIMEOUT_ENTERDATA
163716.28 0 dtmf 5 (65740,53,2)
163716.28 0 ScriptEventCode 53 iLineState=1301
163716.28 0 LsGetNbrsRxDigits 5
163716.28 0 state [Get Numbers] Number Input 65
163716.31 0 rv lg add [Get Numbers]{65}
163716.31 0 rv ns add [Get Numbers_PathTaken]{65}
163716.33 0 timer clear
163716.34 0 state [Run VB Script 1] Running VB Script...
163716.36 0 rv replace start: [set vg = CreateObject("VoiceGuide.CommandLink")
163716.36 0 rv ns [PathSysVoice]{}[PathApp]{D:\Program Files\VoiceGuide\}[PathDataVm]{D:\Program Files\VoiceGuide\data\}[PathVgSys]{D:\Program Files\VoiceGuide\system\}[scriptsPath]{D:\Program Files\VoiceGuide\Scripts\}[scriptPath]{D:\Program Files\VoiceGuide\Scripts}[$RV_STARTTIME]{1/4/2006 4:37:13 PM}[$RV_DEVICEID]{0}[$RV_CIDNAME]{}[PathApp]{D:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[$RV_DNIS]{}[DNIS]{}[Get Numbers]{65}[Get Numbers_PathTaken]{65}
163716.41 0 eng run vbs [wscript "D:\Program Files\VoiceGuide\temp\vbs_0_1_0104163716.vbs" //I] copy of script in: vbs_0_1_0104163716.vbs
163716.89 0 VBScript Run continuing...
163716.91 0 timer clear
163716.91 0 state [Get Numbers] Number Input
163716.92 0 state [Get Numbers] Playing (D:\Program Files\VoiceGuide\system\voice\VmbPinEnterNew.wav)
163716.94 0 play set playid=207500
163717.09 0 PlaySoundStart ok [D:\Program Files\VoiceGuide\system\voice\VmbPinEnterNew.wav]
163717.09 0 timer clear
163717.19 0 cl RvSet CumulativeStore, A
163717.20 0 rv lg add [CumulativeStore]{A}
163719.36 0 play end current play (playid=207500)
163719.38 0 ScriptEventCode 8001 iLineState=1300
163719.39 0 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
163719.39 0 eng set timer EV_TIMEOUT_REPLAYMSG time=5
163719.41 0 timer set 5 EV_TIMEOUT_REPLAYMSG
163719.48 0 dtmf 6 (65740,54,2)
163719.48 0 ScriptEventCode 54 iLineState=1301
163719.50 0 LsGetNbrsRxDigits 6
163719.52 0 state [Get Numbers] Number Input 6
163719.53 0 path {6} not found
163719.55 0 timer set 6 EV_TIMEOUT_ENTERDATA
163719.94 0 dtmf 6 (65740,54,2)
163719.94 0 ScriptEventCode 54 iLineState=1301
163719.95 0 LsGetNbrsRxDigits 6
163719.97 0 state [Get Numbers] Number Input 66
163719.98 0 rv lg add [Get Numbers]{66}
163719.98 0 rv ns add [Get Numbers_PathTaken]{66}
163719.00 0 timer clear
163720.02 0 state [Run VB Script 1] Running VB Script...
163720.03 0 rv replace start: [set vg = CreateObject("VoiceGuide.CommandLink")
163720.05 0 rv ns [PathSysVoice]{}[PathApp]{D:\Program Files\VoiceGuide\}[PathDataVm]{D:\Program Files\VoiceGuide\data\}[PathVgSys]{D:\Program Files\VoiceGuide\system\}[scriptsPath]{D:\Program Files\VoiceGuide\Scripts\}[scriptPath]{D:\Program Files\VoiceGuide\Scripts}[$RV_STARTTIME]{1/4/2006 4:37:13 PM}[$RV_DEVICEID]{0}[$RV_CIDNAME]{}[PathApp]{D:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[$RV_DNIS]{}[DNIS]{}[Get Numbers]{65}[Get Numbers_PathTaken]{65}[CumulativeStore]{A}[Get Numbers]{66}[Get Numbers_PathTaken]{66}
163720.06 0 eng run vbs [wscript "D:\Program Files\VoiceGuide\temp\vbs_0_2_0104163720.vbs" //I] copy of script in: vbs_0_2_0104163720.vbs
163720.11 0 VBScript Run continuing...
163720.13 0 timer clear
163720.13 0 state [Get Numbers] Number Input
163720.14 0 state [Get Numbers] Playing (D:\Program Files\VoiceGuide\system\voice\VmbPinEnterNew.wav)
163720.16 0 play set playid=210718
163720.31 0 PlaySoundStart ok [D:\Program Files\VoiceGuide\system\voice\VmbPinEnterNew.wav]
163720.33 0 timer clear
163720.36 0 dtmf 6 (65740,54,2)
163720.38 0 ScriptEventCode 54 iLineState=1300
163720.39 0 LsGetNbrsPlayWelcMsg 6
163721.13 0 PlaySoundStop err=0
163721.13 0 state [Get Numbers] Number Input 6
163721.14 0 path {6} not found
163721.16 0 timer set 6 EV_TIMEOUT_ENTERDATA
163721.20 0 cl RvSet CumulativeStore, AB
163721.22 0 rv lg add [CumulativeStore]{AB}
163722.95 0 dtmf 6 (65740,54,2)
163722.97 0 ScriptEventCode 54 iLineState=1301
163722.97 0 LsGetNbrsRxDigits 6
163722.98 0 state [Get Numbers] Number Input 66
163722.00 0 rv lg add [Get Numbers]{66}
163723.02 0 rv ns add [Get Numbers_PathTaken]{66}
163723.03 0 timer clear
163723.03 0 state [Run VB Script 1] Running VB Script...
163723.05 0 rv replace start: [set vg = CreateObject("VoiceGuide.CommandLink")
163723.06 0 rv ns [PathSysVoice]{}[PathApp]{D:\Program Files\VoiceGuide\}[PathDataVm]{D:\Program Files\VoiceGuide\data\}[PathVgSys]{D:\Program Files\VoiceGuide\system\}[scriptsPath]{D:\Program Files\VoiceGuide\Scripts\}[scriptPath]{D:\Program Files\VoiceGuide\Scripts}[$RV_STARTTIME]{1/4/2006 4:37:13 PM}[$RV_DEVICEID]{0}[$RV_CIDNAME]{}[PathApp]{D:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[$RV_DNIS]{}[DNIS]{}[Get Numbers]{65}[Get Numbers_PathTaken]{65}[CumulativeStore]{A}[Get Numbers]{66}[Get Numbers_PathTaken]{66}[CumulativeStore]{AB}[Get Numbers]{66}[Get Numbers_PathTaken]{66}
163723.08 0 eng run vbs [wscript "D:\Program Files\VoiceGuide\temp\vbs_0_3_0104163723.vbs" //I] copy of script in: vbs_0_3_0104163723.vbs
163723.14 0 VBScript Run continuing...
163723.17 0 timer clear
163723.17 0 state [Get Numbers] Number Input
163723.19 0 state [Get Numbers] Playing (D:\Program Files\VoiceGuide\system\voice\VmbPinEnterNew.wav)
163723.20 0 play set playid=213765
163723.34 0 PlaySoundStart ok [D:\Program Files\VoiceGuide\system\voice\VmbPinEnterNew.wav]
163723.36 0 timer clear
163723.48 0 cl RvSet CumulativeStore, ABB
163723.50 0 rv lg add [CumulativeStore]{ABB}
163725.63 0 play end current play (playid=213765)
163725.64 0 ScriptEventCode 8001 iLineState=1300
163725.66 0 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
163725.67 0 eng set timer EV_TIMEOUT_REPLAYMSG time=5
163725.67 0 timer set 5 EV_TIMEOUT_REPLAYMSG
163726.89 0 dtmf 9 (65740,57,2)
163726.91 0 ScriptEventCode 57 iLineState=1301
163726.92 0 LsGetNbrsRxDigits 9
163726.94 0 state [Get Numbers] Number Input 9
163726.94 0 path {9} not found
163726.95 0 timer set 6 EV_TIMEOUT_ENTERDATA
163727.19 0 dtmf 9 (65740,57,2)
163727.20 0 ScriptEventCode 57 iLineState=1301
163727.22 0 LsGetNbrsRxDigits 9
163727.23 0 state [Get Numbers] Number Input 99
163727.23 0 rv lg add [Get Numbers]{99}
163727.25 0 rv ns add [Get Numbers_PathTaken]{99}
163727.27 0 timer clear
163727.28 0 state [Run VB Script 1] Running VB Script...
163727.30 0 rv replace start: [set vg = CreateObject("VoiceGuide.CommandLink")
163727.31 0 rv ns [PathSysVoice]{}[PathApp]{D:\Program Files\VoiceGuide\}[PathDataVm]{D:\Program Files\VoiceGuide\data\}[PathVgSys]{D:\Program Files\VoiceGuide\system\}[scriptsPath]{D:\Program Files\VoiceGuide\Scripts\}[scriptPath]{D:\Program Files\VoiceGuide\Scripts}[$RV_STARTTIME]{1/4/2006 4:37:13 PM}[$RV_DEVICEID]{0}[$RV_CIDNAME]{}[PathApp]{D:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[$RV_DNIS]{}[DNIS]{}[Get Numbers]{65}[Get Numbers_PathTaken]{65}[CumulativeStore]{A}[Get Numbers]{66}[Get Numbers_PathTaken]{66}[CumulativeStore]{AB}[Get Numbers]{66}[Get Numbers_PathTaken]{66}[CumulativeStore]{ABB}[Get Numbers]{99}[Get Numbers_PathTaken]{99}
163727.33 0 eng run vbs [wscript "D:\Program Files\VoiceGuide\temp\vbs_0_4_0104163727.vbs" //I] copy of script in: vbs_0_4_0104163727.vbs
163727.38 0 VBScript Run continuing...
163727.39 0 timer clear
163727.41 0 state [Get Numbers] Number Input
163727.41 0 state [Get Numbers] Playing (D:\Program Files\VoiceGuide\system\voice\VmbPinEnterNew.wav)
163727.42 0 play set playid=217984
163727.58 0 PlaySoundStart ok [D:\Program Files\VoiceGuide\system\voice\VmbPinEnterNew.wav]
163727.59 0 timer clear
163727.66 0 cl RvSet CumulativeStore, ABBc
163727.66 0 rv lg add [CumulativeStore]{ABBc}
163729.86 0 play end current play (playid=217984)
163729.86 0 ScriptEventCode 8001 iLineState=1300
163729.88 0 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
163729.89 0 eng set timer EV_TIMEOUT_REPLAYMSG time=5
163729.91 0 timer set 5 EV_TIMEOUT_REPLAYMSG
163730.31 0 dtmf 9 (65740,57,2)
163730.31 0 ScriptEventCode 57 iLineState=1301
163730.33 0 LsGetNbrsRxDigits 9
163730.33 0 state [Get Numbers] Number Input 9
163730.34 0 path {9} not found
163730.36 0 timer set 6 EV_TIMEOUT_ENTERDATA
163730.77 0 dtmf 5 (65740,53,2)
163730.77 0 ScriptEventCode 53 iLineState=1301
163730.78 0 LsGetNbrsRxDigits 5
163730.78 0 state [Get Numbers] Number Input 95
163730.80 0 rv lg add [Get Numbers]{95}
163730.81 0 rv ns add [Get Numbers_PathTaken]{95}
163730.83 0 timer clear
163730.83 0 state [Run VB Script 1] Running VB Script...
163730.84 0 rv replace start: [set vg = CreateObject("VoiceGuide.CommandLink")
163730.86 0 rv ns [PathSysVoice]{}[PathApp]{D:\Program Files\VoiceGuide\}[PathDataVm]{D:\Program Files\VoiceGuide\data\}[PathVgSys]{D:\Program Files\VoiceGuide\system\}[scriptsPath]{D:\Program Files\VoiceGuide\Scripts\}[scriptPath]{D:\Program Files\VoiceGuide\Scripts}[$RV_STARTTIME]{1/4/2006 4:37:13 PM}[$RV_DEVICEID]{0}[$RV_CIDNAME]{}[PathApp]{D:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[$RV_DNIS]{}[DNIS]{}[Get Numbers]{65}[Get Numbers_PathTaken]{65}[CumulativeStore]{A}[Get Numbers]{66}[Get Numbers_PathTaken]{66}[CumulativeStore]{AB}[Get Numbers]{66}[Get Numbers_PathTaken]{66}[CumulativeStore]{ABB}[Get Numbers]{99}[Get Numbers_PathTaken]{99}[CumulativeStore]{ABBc}[Get Numbers]{95}[Get Numbers_PathTaken]{95}
163730.88 0 eng run vbs [wscript "D:\Program Files\VoiceGuide\temp\vbs_0_5_0104163730.vbs" //I] copy of script in: vbs_0_5_0104163730.vbs
163730.92 0 VBScript Run continuing...
163730.94 0 timer clear
163730.95 0 state [Get Numbers] Number Input
163730.97 0 state [Get Numbers] Playing (D:\Program Files\VoiceGuide\system\voice\VmbPinEnterNew.wav)
163730.97 0 play set playid=221531
163731.02 0 PlaySoundStart ok [D:\Program Files\VoiceGuide\system\voice\VmbPinEnterNew.wav]
163731.03 0 timer clear
163731.09 0 cl RvSet CumulativeStore, ABBc_
163731.09 0 rv lg add [CumulativeStore]{ABBc_}
163733.30 0 play end current play (playid=221531)
163733.31 0 ScriptEventCode 8001 iLineState=1300
163733.33 0 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
163733.33 0 eng set timer EV_TIMEOUT_REPLAYMSG time=5
163733.34 0 timer set 5 EV_TIMEOUT_REPLAYMSG
163733.67 0 dtmf 1 (65740,49,2)
163733.67 0 ScriptEventCode 49 iLineState=1301
163733.69 0 LsGetNbrsRxDigits 1
163733.70 0 state [Get Numbers] Number Input 1
163733.72 0 path {1} not found
163733.72 0 timer set 6 EV_TIMEOUT_ENTERDATA
163734.23 0 dtmf 0 (65740,48,2)
163734.25 0 ScriptEventCode 48 iLineState=1301
163734.25 0 LsGetNbrsRxDigits 0
163734.27 0 state [Get Numbers] Number Input 10
163734.28 0 path {10} not found
163734.28 0 timer set 6 EV_TIMEOUT_ENTERDATA
163734.00 0 dtmf 6 (65740,54,2)
163735.02 0 ScriptEventCode 54 iLineState=1301
163735.02 0 LsGetNbrsRxDigits 6
163735.03 0 state [Get Numbers] Number Input 106
163735.05 0 rv lg add [Get Numbers]{106}
163735.06 0 rv ns add [Get Numbers_PathTaken]{106}
163735.06 0 timer clear
163735.08 0 state [Run VB Script 1] Running VB Script...
163735.09 0 rv replace start: [set vg = CreateObject("VoiceGuide.CommandLink")
163735.09 0 rv ns [PathSysVoice]{}[PathApp]{D:\Program Files\VoiceGuide\}[PathDataVm]{D:\Program Files\VoiceGuide\data\}[PathVgSys]{D:\Program Files\VoiceGuide\system\}[scriptsPath]{D:\Program Files\VoiceGuide\Scripts\}[scriptPath]{D:\Program Files\VoiceGuide\Scripts}[$RV_STARTTIME]{1/4/2006 4:37:13 PM}[$RV_DEVICEID]{0}[$RV_CIDNAME]{}[PathApp]{D:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[$RV_DNIS]{}[DNIS]{}[Get Numbers]{65}[Get Numbers_PathTaken]{65}[CumulativeStore]{A}[Get Numbers]{66}[Get Numbers_PathTaken]{66}[CumulativeStore]{AB}[Get Numbers]{66}[Get Numbers_PathTaken]{66}[CumulativeStore]{ABB}[Get Numbers]{99}[Get Numbers_PathTaken]{99}[CumulativeStore]{ABBc}[Get Numbers]{95}[Get Numbers_PathTaken]{95}[CumulativeStore]{ABBc_}[Get Numbers]{106}[Get Numbers_PathTaken]{106}
163735.11 0 eng run vbs [wscript "D:\Program Files\VoiceGuide\temp\vbs_0_6_0104163735.vbs" //I] copy of script in: vbs_0_6_0104163735.vbs
163735.16 0 VBScript Run continuing...
163735.17 0 timer clear
163735.19 0 state [Get Numbers] Number Input
163735.20 0 state [Get Numbers] Playing (D:\Program Files\VoiceGuide\system\voice\VmbPinEnterNew.wav)
163735.20 0 play set playid=225765
163735.25 0 PlaySoundStart ok [D:\Program Files\VoiceGuide\system\voice\VmbPinEnterNew.wav]
163735.27 0 timer clear
163735.33 0 cl RvSet CumulativeStore, ABBc_j
163735.33 0 rv lg add [CumulativeStore]{ABBc_j}
163737.55 0 play end current play (playid=225765)
163737.55 0 ScriptEventCode 8001 iLineState=1300
163737.56 0 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
163737.58 0 eng set timer EV_TIMEOUT_REPLAYMSG time=5
163737.58 0 timer set 5 EV_TIMEOUT_REPLAYMSG
163738.45 0 dtmf * (65740,42,2)
163738.45 0 ScriptEventCode 42 iLineState=1301
163738.47 0 LsGetNbrsRxDigits *
163738.47 0 rv lg add [Get Numbers]{}
163738.48 0 rv ns add [Get Numbers_PathTaken]{*}
163738.50 0 timer clear
163738.52 0 state [Get email Number] Number Input
163738.52 0 state [Get email Number] Playing (D:\Program Files\VoiceGuide\system\voice\thousand.wav)
163738.53 0 play set playid=229093
163738.59 0 PlaySoundStart ok [D:\Program Files\VoiceGuide\system\voice\thousand.wav]
163738.59 0 timer clear
163739.52 0 play end current play (playid=229093)
163739.53 0 ScriptEventCode 8001 iLineState=1300
163739.53 0 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
163739.55 0 eng set timer EV_TIMEOUT_REPLAYMSG time=5
163739.56 0 timer set 5 EV_TIMEOUT_REPLAYMSG
163740.22 0 dtmf 2 (65740,50,2)
163740.22 0 ScriptEventCode 50 iLineState=1301
163740.23 0 LsGetNbrsRxDigits 2
163740.23 0 state [Get email Number] Number Input 2
163740.25 0 path {2} not found
163740.27 0 timer set 6 EV_TIMEOUT_ENTERDATA
163740.28 0 timer clear
163740.28 0 rv lg add [Get email Number]{2}
163740.30 0 path {2} not found
163740.31 0 rv ns add [Get email Number_PathTaken]{success}
163740.31 0 timer clear
163740.33 0 state [Database Query] DB Query
163740.34 0 db Jet mode used (To use ODBC mode specify ODBC Connect string)
163740.50 0 rv replace start: [select emailid from table1 where accountnumber=$RV[Get email Number]]
163740.52 0 rv ns [PathSysVoice]{}[PathApp]{D:\Program Files\VoiceGuide\}[PathDataVm]{D:\Program Files\VoiceGuide\data\}[PathVgSys]{D:\Program Files\VoiceGuide\system\}[scriptsPath]{D:\Program Files\VoiceGuide\Scripts\}[scriptPath]{D:\Program Files\VoiceGuide\Scripts}[$RV_STARTTIME]{1/4/2006 4:37:13 PM}[$RV_DEVICEID]{0}[$RV_CIDNAME]{}[PathApp]{D:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[$RV_DNIS]{}[DNIS]{}[Get Numbers]{65}[Get Numbers_PathTaken]{65}[CumulativeStore]{A}[Get Numbers]{66}[Get Numbers_PathTaken]{66}[CumulativeStore]{AB}[Get Numbers]{66}[Get Numbers_PathTaken]{66}[CumulativeStore]{ABB}[Get Numbers]{99}[Get Numbers_PathTaken]{99}[CumulativeStore]{ABBc}[Get Numbers]{95}[Get Numbers_PathTaken]{95}[CumulativeStore]{ABBc_}[Get Numbers]{106}[Get Numbers_PathTaken]{106}[CumulativeStore]{ABBc_j}[Get Numbers]{}[Get Numbers_PathTaken]{*}[Get email Number]{2}[Get email Number_PathTaken]{success}
163740.52 0 rv replace end: [select emailid from table1 where accountnumber=2]
163740.55 0 db About to execute a Retrieve type operation [select emailid from table1 where accountnumber=2]
163740.56 0 db [Database Query] row count=1
163740.56 0 rv lg add [Database Query_RowCount]{1}
163740.58 0 db get RecordsetGetRowsMax
163740.59 0 db get 999 records. (row count=1)
163740.61 0 db update RVs start
163740.61 0 db update RVs cols=1 rows=1
163740.63 0 db test vRetData(0, 0)=yahoo.com
163740.64 0 db test CStr(vRetData(0, 0))=yahoo.com
163740.64 0 db about to close dbDbqDatabase
163740.66 0 db going down path [True]
163740.67 0 timer clear
163740.69 0 state [Record] Recording
163740.69 0 play set playid=231250
163740.77 0 PlaySoundStart ok [D:\Program Files\VoiceGuide\system\voice\beep1.wav]
163740.77 0 timer clear
163741.13 0 play end current play (playid=231250)
163741.13 0 ScriptEventCode 8001 iLineState=1200
163741.14 0 LsRecPlayBeep EV_PLAY_FINISHED
163741.16 0 rv lg add [Record]{D:\Program Files\VoiceGuide\Scripts\voice}
163741.20 0 RecSoundStart file[D:\Program Files\VoiceGuide\Scripts\voice] ok
163741.22 0 eng RecSoundStart after beep [D:\Program Files\VoiceGuide\Scripts\voice]
163741.22 0 timer set 180 EV_TIMEOUT_GOTOMODULE
163745.73 0 sys cleanup Start
163745.78 0 sys cleanup End
163751.39 0 dtmf # (65740,35,2)
163751.39 0 ScriptEventCode 35 iLineState=1201
163751.41 0 LsRecRecording #
163751.42 0 RecSoundStopTruncBytes ok
163751.44 0 rec length RV: Record_RecLen100ms = 101
163751.44 0 rv lg add [Record_RecLen100ms]{101}
163751.45 0 rv lg add [Record_EndRecCause]{#}
163751.47 0 ScriptEventCode 8003 iLineState=5900
163751.48 0 timer clear
163751.48 0 state [send Email 1] Send Email
163751.50 0 rv replace start: [$RV[CumulativeStore]@$RV[Database Query]]
163751.52 0 rv ns [PathSysVoice]{}[PathApp]{D:\Program Files\VoiceGuide\}[PathDataVm]{D:\Program Files\VoiceGuide\data\}[PathVgSys]{D:\Program Files\VoiceGuide\system\}[scriptsPath]{D:\Program Files\VoiceGuide\Scripts\}[scriptPath]{D:\Program Files\VoiceGuide\Scripts}[$RV_STARTTIME]{1/4/2006 4:37:13 PM}[$RV_DEVICEID]{0}[$RV_CIDNAME]{}[PathApp]{D:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[$RV_DNIS]{}[DNIS]{}[Get Numbers]{65}[Get Numbers_PathTaken]{65}[CumulativeStore]{A}[Get Numbers]{66}[Get Numbers_PathTaken]{66}[CumulativeStore]{AB}[Get Numbers]{66}[Get Numbers_PathTaken]{66}[CumulativeStore]{ABB}[Get Numbers]{99}[Get Numbers_PathTaken]{99}[CumulativeStore]{ABBc}[Get Numbers]{95}[Get Numbers_PathTaken]{95}[CumulativeStore]{ABBc_}[Get Numbers]{106}[Get Numbers_PathTaken]{106}[CumulativeStore]{ABBc_j}[Get Numbers]{}[Get Numbers_PathTaken]{*}[Get email Number]{2}[Get email Number_PathTaken]{success}[Database Query_RowCount]{1}[Database Query_1_1]{yahoo.com}[Record]{D:\Program Files\VoiceGuide\Scripts\voice}[Record_RecLen100ms]{101}[Record_EndRecCause]{#}
163751.53 0 rv replace end: [ABBc_j@]
163751.55 0 rv replace start: [$RV[Record]]
163751.55 0 rv ns [PathSysVoice]{}[PathApp]{D:\Program Files\VoiceGuide\}[PathDataVm]{D:\Program Files\VoiceGuide\data\}[PathVgSys]{D:\Program Files\VoiceGuide\system\}[scriptsPath]{D:\Program Files\VoiceGuide\Scripts\}[scriptPath]{D:\Program Files\VoiceGuide\Scripts}[$RV_STARTTIME]{1/4/2006 4:37:13 PM}[$RV_DEVICEID]{0}[$RV_CIDNAME]{}[PathApp]{D:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[$RV_DNIS]{}[DNIS]{}[Get Numbers]{65}[Get Numbers_PathTaken]{65}[CumulativeStore]{A}[Get Numbers]{66}[Get Numbers_PathTaken]{66}[CumulativeStore]{AB}[Get Numbers]{66}[Get Numbers_PathTaken]{66}[CumulativeStore]{ABB}[Get Numbers]{99}[Get Numbers_PathTaken]{99}[CumulativeStore]{ABBc}[Get Numbers]{95}[Get Numbers_PathTaken]{95}[CumulativeStore]{ABBc_}[Get Numbers]{106}[Get Numbers_PathTaken]{106}[CumulativeStore]{ABBc_j}[Get Numbers]{}[Get Numbers_PathTaken]{*}[Get email Number]{2}[Get email Number_PathTaken]{success}[Database Query_RowCount]{1}[Database Query_1_1]{yahoo.com}[Record]{D:\Program Files\VoiceGuide\Scripts\voice}[Record_RecLen100ms]{101}[Record_EndRecCause]{#}
163751.56 0 rv replace end: [D:\Program Files\VoiceGuide\Scripts\voice]
163751.58 0 rv lg add [send Email 1]{ABBc_j@}
163751.59 0 rv lg add [send Email 1_Subject]{jaibhim}
163751.59 0 rv lg add [send Email 1_Message]{self test}
163751.61 0 rv lg add [send Email 1_Attachment]{D:\Program Files\VoiceGuide\Scripts\voice}
163751.63 0 rv lg add [send Email 1_Cc]{}
163751.64 0 rv lg add [send Email 1_Bcc]{}
163751.64 0 email que to: ABBc_j@
163751.67 0 sql INSERT INTO MsgQue (ToAddress, ToName, ReturnAddress, ReturnName, CcAddress, CcName, BccAddress, BccName, ReplyAddress, MsgSubject, MsgMessage, MsgAttachment, MsgAttachmentDeleteAfterSend, gw1_SmtpServ, gw1_UseAuthentication, gw1_UsePopAuthentication, gw1_AuthUserName, gw1_AuthUserPassword, gw1_POP3Host, gw1_SMTPPort, gw2_SmtpServ, gw2_UseAuthentication, gw2_UsePopAuthentication, gw2_AuthUserName, gw2_AuthUserPassword, gw2_POP3Host, gw2_SMTPPort, SendTime, SendRetriesLeft, SendDelayBetweenRetries) VALUES ('ABBc_j@', 'ABBc_j@', '', '', '', '', '', '', '', 'jaibhim', 'self test', 'D:\Program Files\VoiceGuide\Scripts\voice', 0, 'MAPI', 0, 0, '', '', '', 25, 'smma.sancharnet.in', 1, 0, 'civil567', 'amitabha', '', 25, 0, 3, 10)
163751.72 0 rv lg add [send Email 1_SendResult]{OK}
163752.06 0 timer clear
163752.06 0 rv lg add [Hangup Time]{1/4/2006 4:37:52 PM}
163752.08 0 state Hanging up call... [Hangup Module]
163752.09 0 RecSoundStop ok
163752.11 0 PlaySoundStop err=0
163752.11 0 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
163752.14 0 fnHangupCall end
163752.36 0 tapi callstate start
163752.38 0 tapi callstate DISCONNECTED 65740 1 0
163752.39 0 ScriptEventCode 9250 iLineState=900
163752.39 0 LsAwaitingCalls EV_REMOTEPARTY_DISCONNECT
163752.41 0 rv lg add [Hangup Time]{1/4/2006 4:37:52 PM}
163752.42 0 state Hanging up call...
163752.42 0 RecSoundStop ok
163752.44 0 PlaySoundStop err=0
163752.45 0 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
163752.47 0 fnHangupCall end
163752.47 0 tapi callstate start
163752.48 0 tapi callstate IDLE 65740 0 0
163752.52 0 WorkingMode@Idle=
163752.53 0 timer clear
163752.61 0 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
163752.63 0 tapi Reply (LineEvReply) ok 65706 0
163752.64 0 tapi Reply (LineEvReply) ok 65689 0
163753.64 0 timer fired EV_TIMEOUT_TIMETOREINITLINE
163753.64 0 ScriptEventCode 9008 iLineState=900
163753.66 0 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
163753.67 0 ReinitTelephony due to IDLE
163753.69 0 tapic lineDeallocateCall(MainCall:65740) 0
163753.92 0 lineOpen(0)=>
163753.94 0 state Waiting for a call...
163754.09 0 LineHandle=65672
163754.11 0 amchk set AMdet=False in Reinit@idle
163754.13 0 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
163754.14 0 dial start any summary:|0:rdy=0|
163757.44 0 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
163757.44 0 ScriptEventCode 9013 iLineState=900
163758.14 0 dial start any summary:|0:idx=0|
kindly help me. please
bye
Scripts.rar
This trace shows emails are inserted to the email database to be emailed.
If they do not get emailed then you should look at the MMDDes.txt log
BTW. Please do not quote your logs in posts - .ZIP them up and include them as attachments.
Dear sir
please find the attachemnts of log and script belo. The Say Number module after saying number should transfer control to Record module as I have provided both the succes and fail path from Say Number to Record module. Besides is the send email module correctly written? Thanking you in anticipation.
log.rar
The Say Number module expects a DTMF response for caller - just like a 'Play' module. It does not evaluate anything so 'Success' and 'Fail' paths are no used in this module (just like they are not used in a 'Play' module)
If you want to move onto another module immediately after the playing of sound files is finished then use the 'Timeout 0' path.
Also - this question is not related to topic "Cumulative Effects In Vbscript" - so it should really be in a separate thread.... as should your email related question...
Also, please .ZIP up attachments, not .RAR/.ARJ/etc them.
Thanks. I am new to forum. I will take care of proper ways to post threads and .zips. Thanks again. Bye
