Circular Reference Error
Dear sir
What does the following log mean? Please help
080727.51 0 ERROR 5.2.3018 dial DbFindDueCall [Circular reference caused by alias 'Expr1000' in query definition's SELECT list.]
080727.51 0 ERROR 5.2.3018 dial DbFindDueCall [Object variable or With block variable not set]
080728.51 0 ERROR 5.2.3018 dial DbFindDueCall [Circular reference caused by alias 'Expr1000' in query definition's SELECT list.]
080728.51 0 ERROR 5.2.3018 dial DbFindDueCall [Object variable or With block variable not set]
080729.51 0 ERROR 5.2.3018 dial DbFindDueCall [Circular reference caused by alias 'Expr1000' in query definition's SELECT list.]
080729.51 0 ERROR 5.2.3018 dial DbFindDueCall [Object variable or With block variable not set]
080730.51 0 ERROR 5.2.3018 dial DbFindDueCall [Circular reference caused by alias 'Expr1000' in query definition's SELECT list.]
080730.51 0 ERROR 5.2.3018 dial DbFindDueCall [Object variable or With block variable not set]
080731.53 0 ERROR 5.2.3018 dial DbFindDueCall [Circular reference caused by alias 'Expr1000' in query definition's SELECT list.]
Regards
Researcher
Haven't seen this one before...
Please try stopping VG, deleteing the OutDialQue database and then restarting VG.
How have you been loading new 'numbers to call' entries?
