Guest researcher Report post Posted 01/18/2006 04:25 PM Dear sir What does the following log mean? Please help 080727.51 0 ERROR 5.2.3018 dial DbFindDueCall [Circular reference caused by alias 'Expr1000' in query definition's SELECT list.] 080727.51 0 ERROR 5.2.3018 dial DbFindDueCall [Object variable or With block variable not set] 080728.51 0 ERROR 5.2.3018 dial DbFindDueCall [Circular reference caused by alias 'Expr1000' in query definition's SELECT list.] 080728.51 0 ERROR 5.2.3018 dial DbFindDueCall [Object variable or With block variable not set] 080729.51 0 ERROR 5.2.3018 dial DbFindDueCall [Circular reference caused by alias 'Expr1000' in query definition's SELECT list.] 080729.51 0 ERROR 5.2.3018 dial DbFindDueCall [Object variable or With block variable not set] 080730.51 0 ERROR 5.2.3018 dial DbFindDueCall [Circular reference caused by alias 'Expr1000' in query definition's SELECT list.] 080730.51 0 ERROR 5.2.3018 dial DbFindDueCall [Object variable or With block variable not set] 080731.53 0 ERROR 5.2.3018 dial DbFindDueCall [Circular reference caused by alias 'Expr1000' in query definition's SELECT list.] Regards Researcher Share this post Link to post
SupportTeam Report post Posted 01/18/2006 08:11 PM Haven't seen this one before... Please try stopping VG, deleteing the OutDialQue database and then restarting VG. How have you been loading new 'numbers to call' entries? Share this post Link to post
