Guest Zoltan Gregor Report post Posted 01/20/2006 09:43 AM Recommendation for improvement In any module, we can choose the success, fail, timeout etc. path. It is easy to use when we select a module in the same script. For example, if I change a module name, it is automatically updated in the path references. However, when I refer to another script in a path, I have to enter everything by typing or copying and there is no automatic path name update. The Goto text box in the path tab of any module should consist of two parts. One for selecting the script name and the other for selecting a module in the chosen script. And of course, changes in the script name or module name should be reflected automatically. Also, the | sign should be selectable in a check box. Share this post Link to post
SupportTeam Report post Posted 01/20/2006 10:00 AM when I refer to another script in a path, I have to enter everything by typing or copying and there is no automatic path name update. Correct. The destination script does not keep any reference as to what other scripts are currently branching to it... so there is no way for it to know what scripts to update with a new name. Share this post Link to post
