Guest Tomcatt Report post Posted 01/21/2006 01:03 AM I tried setting the record length under global tab and then reset all boxes button but the voice message shows 1:27 record length but ends after about a minute. I have tried the changes shown on this forum but it still cuts the caller off. I am using VM for apartment ads and many of the callers numbers are not on the recording because the recording stops. Any suggestions? This is a partial of the trace log (I started it just after choosing to leave a message) 184013.63 0 dtmf 0 (65672,48,2) 184013.63 0 ScriptEventCode 48 iLineState=1100 184013.63 0 LsPlayMsg 0 184013.63 0 voicemail used: builtin (vgp) 184013.64 0 script load C:\Program Files\VoiceGuide\system\vm\VmLm.vgp 184013.92 0 Loaded C:\Program Files\VoiceGuide\system\vm\VmLm.vgp into:2 184013.92 0 stack idx=1 184013.92 0 rv lg add [scriptStart_Time]{1/20/2006 6:40:13 PM} 184013.94 0 rv lg add [scriptStart_CalledFrom_Script]{C:\Data\RealEstate\Adams\taylor4.vgs} 184013.94 0 rv lg add [scriptStart_CalledFrom_Module]{Taylor upper} 184013.94 0 LoadedVgs_Find C:\Program Files\VoiceGuide\system\vm\VmLm.vgp at idx=2 184013.94 0 rv ns add [scriptsPath]{C:\Program Files\VoiceGuide\system\vm\} 184013.94 0 rv lg add [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\} 184013.94 0 rv lg add [PathDataVm]{C:\Program Files\VoiceGuide\data\} 184013.94 0 rv lg add [PathVgSys]{C:\Program Files\VoiceGuide\system\} 184013.94 0 rv lg add [vmbId]{0003} 184014.44 0 PlaySoundStop err=0 184014.45 0 rv lg add [Taylor upper]{0} 184014.45 0 timer clear 184014.45 0 state [VmLmStart] Running vb script:[VmLmHangup.vgs] 184246.83 0 script load C:\Program Files\VoiceGuide\system\vm\VmLmHangup.vgs 184246.83 0 Loaded VbsAtHangup into:3 184246.84 0 tapi Reply (LineEvReply) ok 65638 0 184246.84 0 timer clear 184246.84 0 state [VmLmHangup_ForwardLastMsg] Running VB Script... 184246.84 0 rv replace start (strlen>500) 184246.84 0 rv ns [PathSysVoice]{}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\Data\RealEstate\Adams\}[scriptPath]{C:\Data\RealEstate\Adams}[$RV_STARTTIME]{1/20/2006 6:39:59 PM}[$RV_DEVICEID]{0}[$RV_CIDNAME]{CHRISTENSEN T J}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{6127897346}[$RV_DNIS]{}[DNIS]{}[Welcome]{2}[2br]{2}[scriptStart_Time]{1/20/2006 6:40:13 PM}[scriptStart_CalledFrom_Script]{C:\Data\RealEstate\Adams\taylor4.vgs}[scriptStart_CalledFrom_Module]{Taylor upper}[scriptsPath]{C:\Program Files\VoiceGuide\system\vm\}[PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[vmbId]{0003}[Taylor upper]{0}[Key_VmLmStopRecAndPlay]{1}[Key_VmLmDelRecRecAgain]{2}[Key_VmLmSaveAndP ayGreeting]{3}[Key_VmLmDeleteGoGroupPrevious]{4}[Key_VmLmDeleteAndPlayGreeting]{ }[Key_VmLmDeleteGoGroupNext]{6}[Key_VmLmSaveGoVmLogin]{8}[Key_VmLmSaveVmExit]{0} Key_VmLmSaveGoLmRecMsgMenu]{#}[RecMessage]{}[VmbWelcMsg]{C:\Program Files\VoiceGuide\system\voice\VmbWelcomeMsgDefault.wav}[VmLmWelc]{timeout}[VmLmRecFilename]{0003_01201840 7_1_0_6127897346_.wav}[MsgLenMax]{400}[VmLmRec]{C:\Program Files\VoiceGuide\data\VmSave\0003_0120184017_1_0_6127897346_.wav}[VmLmRec_RecLen100ms]{1273}[VmLmRec_End ecCause]{silence}[Hangup Time]{1/20/2006 6:42:46 PM} 184246.88 0 eng run vbs [wscript "C:\Program Files\VoiceGuide\temp\vbs_0_3_0120184246.vbs" //I] copy of script in: vbs_0_3_0120184246.vbs 184246.95 0 Run Script waiting. iRunWait=1 (shellid=3684, process=1196) 184246.95 0 timer set 1 EV_TIMEOUT_CHECKONSTATE 184247.06 0 cl Vm_VmbConfig_Get 0003, MsgLenMin 184247.08 0 vm RecLen100ms=1273, MinLength for VMB0003=0 184247.08 0 cl Vm_Event 0, FORWARD, 0003, C:\Program Files\VoiceGuide\data\VmSave\0003_0120184017_1_0_6127897346_.wav, , 184247.08 0 vm frwrd vmb 0003 184247.08 0 rv lg add [VoicemailMessage0003]{C:\Program Files\VoiceGuide\data\VmSave\0003_0120184017_1_0_6127897346_.wav} 184247.09 0 rv ns add [VoicemailMessage]{C:\Program Files\VoiceGuide\data\VmSave\0003_0120184017_1_0_6127897346_.wav} 184247.09 0 vm frwrd vmb 0003 end 184247.09 0 cl Vm_Event 0, MSG_NEW, 0003, , , 184247.09 0 vm MsgLamp control set to [DISABLE] 184247.09 0 cl Run_ResultReturn >>success<< 184247.11 0 rv lg add [VmLmHangup_ForwardLastMsg_ResultReturn]{success} 184247.11 0 path {success} not found 184247.11 0 cl module's runwait=1, WavPlayHasNowFinished=0 184247.11 0 rv lg add [Hangup Time]{1/20/2006 6:42:47 PM} 184247.11 0 state Hanging up call... [Run_ResultReturn - no path match (same vgm)] 184247.11 0 HangupCall_Common Mode=AfterHangupRun 184247.13 0 ReinitTelephony due to IDLE 184247.13 0 tapic lineDeallocateCall(MainCall:65672) 0 184247.20 0 lineOpen(0)=> 184247.22 0 state Waiting for a call... 184247.22 0 LineHandle=65621 184247.22 0 amchk set AMdet=False in Reinit@idle 184247.22 0 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT 184247.69 0 dial start any summary:|0:rdy=0| 184250.39 0 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT 184250.39 0 ScriptEventCode 9013 iLineState=900 184250.69 0 dial start any summary:|0:idx=0| 185903.80 0 vm loading VMB data begin 185903.81 0 vm loading VMB data - about to delete old entries 185903.81 0 vm sort start on 8 entries. 185903.81 0 vm sort end. 185903.81 0 vm loading VMB data end 185903.81 0 Loaded new voicemail configuration file (XML) Share this post Link to post
SupportTeam Report post Posted 01/21/2006 01:46 AM Please .zip up and post C:\Program Files\VoiceGuide\data\VmSave\0003_0120184017_1_0_6127897346_.wav Also, please .zip up any traces in future instead of quoting them in the post. Share this post Link to post
