Hangs up after playing first sound prompt
I am currently running a trial version of Voice Guide, but when I run an application on it, it keeps hanging my calls after playing the first prompt.
Here is my logs:
30023 5 tapie callstate OFFERING 65810 0 4
30033 5 tapie ring 1
30033 5 Answer the call
30033 5 lineAnswer(65810) => 65827
30043 5 tapie callstate ACCEPTED 65810 0 0
36943 5 tapi Reply 65827 0
36953 5 tapie callstate CONNECTED 65810,0,0
36953 5 WorkingModeTAPI=
36953 5 WorkingModeScript=
36953 5 TimeoutClear
36963 5 [Welcome] Playing
36963 5 [Welcome] Playing (C:\prompts\Welcome.wav)
37043 5 PlaySoundStart ok [C:\prompts\Welcome.wav]
37043 5 TimeoutClear
37053 5 RunModule PLAY end
37053 5 wa(19120,63696300)
56181 5 Play End line[5] (id=636963)
56191 5 LsPlayMsg EV_PLAY_FINISHED
56191 5 TimeoutSet 10 EV_TIMEOUT_HANGUP
56191 5 TimeoutSet 10 EV_TIMEOUT_GOTOMODULE
66115 5 Timer fired EV_TIMEOUT_GOTOMODULE
66125 5 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
66135 5 TimeoutClear
66135 5 [GetID] Number Input
66145 5 [GetID] Playing (C:\prompts\RingtoneMenu.wav)
66215 5 PlaySoundStart ok [C:\prompts\RingtoneMenu.wav]
66225 5 TimeoutClear
66235 5 wa(6008,66615500)
72264 5 Play End line[5] (id=666155)
72274 5 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
72284 5 TimeoutSet 10 EV_TIMEOUT_HANGUP
72284 5 TimeoutSet 6 EV_TIMEOUT_ENTERDATA
78203 5 Timer fired EV_TIMEOUT_ENTERDATA
78213 5 LsGetNbrsRxDigits EV_TIMEOUT_ENTERDATA
78223 5 Hanging up call...
78223 5 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
78233 5 PlaySoundStop ok
78243 5 fnHangupCall end
78493 5 tapie callstate DISCONNECTED 65810,1,0
78503 5 LsAwaitingCalls EV_REMOTEPARTY_DISCONNECT
78503 5 PlaySoundStop ok
78513 5 Hanging up call...
78523 5 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
78533 5 PlaySoundStop ok
78543 5 fnHangupCall end
78553 5 tapie callstate IDLE 65810 0 0
78563 5 WorkingMode@Idle=
78563 5 TimeoutClear
78613 5 TimeoutSet 1 EV_TIMEOUT_TIMETOREINITLINE
78613 5 tapi Reply 65963 0
78623 5 tapi Reply 65980 0
79525 5 Timer fired EV_TIMEOUT_TIMETOREINITLINE
79525 5 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
79535 5 Initialise telephony (due to IDLE)
79545 5 tapic lineDeallocateCall(MainCall:65810) 0
79845 5 Waiting for a call...
79855 5 hLine=65707
79855 5 TimeoutSet 5 EV_TIMOUT_ATERIDLE_ALLOWOUT
84872 5 Timer fired EV_TIMOUT_ATERIDLE_ALLOWOUT
Any help will be appreciated...
Thanks a million.
The trace shows that first "C:\prompts\Welcome.wav" was played, then after 10 seconds timeout "C:\prompts\RingtoneMenu.wav" was played and then the system timed out awaiting user input (6 second timeout) and the call was then hung up...
At no stage did the modem report any keytone presses from the caller....
10 seconds timeout between the two wav files is a long timeout time... perhaps that long silence leads caller to believe that the system has hung up, when actually the script just waits for 10 seconds...
