Zoltan Report post Posted 01/24/2006 05:17 PM Can I buy the Enterprise 4 line license for $449 without the Dialer and the Dialer 1 line for $129 and use them together in the same system? So in this case 4 lines can accept incoming calls and 1 of these lines can also dial out. When I buy the license, do you give a VG new software or I use the one that is free to download - with limitations according to the license? Share this post Link to post
SupportTeam Report post Posted 01/24/2006 08:53 PM No. The lower of the two line counts will be used in the combined license. The license registers your downloaded evaluation and enables according to the purchased license type. Share this post Link to post
Guest Guest Report post Posted 01/24/2006 09:18 PM So does that mean that only 2 line license purchase is required for the dialer, and 4 line license for VG? Share this post Link to post
SupportTeam Report post Posted 01/24/2006 09:45 PM The number of 'Dialer' lines must match. If you buy a 2 line Dialer to add to a 4 line VG license you will end up with a 2 line VG+Dialer license. Share this post Link to post
