Clear Call Log
Is it possible to clear call log file in VG Ent Ver. 5.2.5003?
Thank you,
tom
I am referring to the one that you can access from the Call Log Button in the main program. It keeps track of all in-coming calls.
The script related log files can be turned off.
In VG.INI section [Log] set:
Scripts=off
On my system the call log button brings up the file named YourScriptName.vgl.
I guess you could delete that file. It is located in the same directory as you script.
If the file does not exist VG I beleive will recreate it.
Why would you want to clear or delete this log?
The ability to sort the list from oldest to newest and newest to oldest would be nice. Maybe this will be added in the future.
Currently mine list the calls oldest to newest which means you have to do a lot of scrolling if you want to look at a recent call.
If that is your problem or concern maybe you could request the ability to sort the calls. I wouldn't think it would be much to ask for.
You are correct about deleting the VGL file in the folder where the script is located. VG creates a new one upon receiving a call in the script. Yes, I agree that there should be a sort so that you can see newest to oldest. Perhaps a filter would be good too. I often need to look to see how many calls had been placed by a certain number. Admin monitors all posts, so they know already that this would be some good features. Thanks for your sugestion about deleting the VGL file.
You might want to open the YourScriptName.csv file located in the same directory as your script.
You can open it with MS Excel. With Excel you can do whatever you want with the data.
