ktruk Report post Posted 01/25/2006 03:19 PM After setting up a simple recording script, as soon as the recording module is run, I get an error: 151511.83 15 RecSoundStart err[6] And the call goes to "Hangup" mode. What is err[6] please? 151511.75 15 timer clear 151511.76 15 state [Record 1] Recording 151511.77 15 play set playid=213358 151511.78 15 PlaySoundStart ok [C:\Program Files\VoiceGuide\system\voice\beep1.wav] 151511.78 15 timer clear 151511.80 15 play end current play (playid=213358) 151511.80 15 ScriptEventCode 8001 iLineState=1200 151511.81 15 LsRecPlayBeep EV_PLAY_FINISHED 151511.82 15 rv lg add [Record 1]{C:\Program Files\VoiceGuide\Scripts\ktr\testrec1.wav} 151511.83 15 RecSoundStart err[6] 151511.84 15 rv lg add [Hangup Time]{25/01/2006 15:15:11} 151511.85 15 state Hanging up call... 151511.86 15 RecSoundStop ok 151511.87 15 PlaySoundStop err=0 151511.88 15 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 151511.89 15 fnHangupCall end 151511.89 15 eng RecSoundStart after beep [C:\Program Files\VoiceGuide\Scripts\ktr\testrec1.wav] 151511.90 15 timer set 30 EV_TIMEOUT_GOTOMODULE 151521.21 15 tapi callstate start 151521.22 15 tapi callstate DISCONNECTED 66486 1 0 151521.23 15 ScriptEventCode 9250 iLineState=1201 151521.24 15 LsRecRecording EV_REMOTEPARTY_DISCONNECT 151521.25 15 RecSoundStopTruncBytes ok 151521.26 15 rec length RV: Record 1_RecLen100ms = 94 151521.27 15 rv lg add [Record 1_RecLen100ms]{94} 151521.27 15 rv lg add [Record 1_EndRecCause]{disconnect} 151521.28 15 rv lg add [Hangup Time]{25/01/2006 15:15:21} 151521.29 15 state Hanging up call... [During LsRecRecording] 151521.30 15 RecSoundStop ok 151521.31 15 PlaySoundStop err=0 151521.32 15 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 151521.33 15 fnHangupCall end 151521.35 15 tapi callstate start 151521.35 15 tapi callstate IDLE 66486 0 0 151521.36 15 WorkingMode@Idle= (I am using v5.2.5015, and an Eicon wave driver/hardware) Share this post Link to post
SupportTeam Report post Posted 01/25/2006 09:46 PM We'll need to see the tw trace to see what is happening on the driver level. Share this post Link to post
ktruk Report post Posted 01/25/2006 10:28 PM Just reran the app and zipped up the files. Really appreciate any insight on this issue. Thx. 125vglogs.zip Share this post Link to post
SupportTeam Report post Posted 01/25/2006 11:05 PM The wave driver returned an error when VoiceGuide tried to start recording. We can see in tw trace: 222307.559 fn rec waveInOpen failed. You should contact the manufacturer of the driver to see why it had failed... Trace shows that you are using 4 BRI lines for a total of 8 voice channels.. You'd be better off just getting an E1/T1 ISDN line instead and using a Dialogic card... Share this post Link to post
ktruk Report post Posted 01/31/2006 08:20 PM Actually, it looks like VG returned the error... based on these lines, looks like the ocx does the call recording setup. 222307.519 wavec waveOutUnprepareHeader(0x39f4eb0, 0x39f40f0, 0x20) call non-unimodem 222307.519 wavec waveOutUnprepareHeader(0x39f4eb0, 0x39f40f0, 0x20) => 0 (MMSYSERR_OK) non-unimodem 222307.519 fn OnFirePlayPlayWdogClearEvent start 222307.519 ocxev PlayWdogClear(dwLineId=21, dwPlayId=0xd6f2f4) 222307.519 ocxev PlayEnd(dwLineId=21, dwPlayId=0x22645) 222307.549 ocxfn SilenceDetectSet(sLineId=21, sTimeLen=30, sVolumeLevel=10) 222307.559 ocxfn RecStart(sLineId:21, strFile:C:\Program Files\VoiceGuide\Scripts\ktr\testrec1.wav)222307.559 wavec waveOutReset(0x39f4eb0) call, caller: RecSoundStart 222307.559 wavec waveOutReset(0x39f4eb0) => 0 (MMSYSERR_OK), caller: RecSoundStart 222307.559 wavec waveOutClose(0x39f4eb0) call, caller: RecSoundStart 222307.559 wavec waveOutClose(0x39f4eb0) => 0 (MMSYSERR_OK), caller: RecSoundStart 222307.559 fn rec waveInOpen failed. 222307.579 ocxfn RecStop(sLineId:21) 222307.579 wavec waveInReset(0x0) => 5 222307.579 linec lineMonitorTones(0x10104, 0x0, 1) => 0x80000049 (disabling monitoring for silence/tones) 222307.589 ocxfn PlayStop(sLineId=21) 222307.589 fn PlaySoundStop start 222307.589 fn PlaySoundStop line not playing a sound file. 0x0 222307.609 ocxfn LineDrop(sLineId=21, sOpt=0) 222307.609 tapic lineDrop(0x10104, , 0) call in ocxfn_LineDrop 222307.609 tapic lineDrop(0x10104, , 0) => async:65847 (65847) 222308.120 tapie LINE_REPLY(21, 0x0, 0x10137, 0x0) Earlier in the tapi traces, you can see that VG queries the wave/driver capabilities as part of the device initialization and setup. (see attached log zip higher up in thread) and appears to return the requested information. Then VG asks the ocx to setup for recording (by setting silence detection) and next thing I get is an error when recording starts. Looking closely at the events logged, there appears to be some wave driver initialisation done out of sequence, the correct sequence should be something like: waveOutReset(x,x,x) waveOutUnprepareHeader(x,x,x) waveOutClose(x) But these events seem out of sequence. (I'm guessing here, but if the driver is not closed off after playing, it can't be turned around for recording). Can you please ask the developers to check the proper block-mode wave setup and what the error code actually means? I am pretty sure it is not a waveError message from the wave Driver. Also, in addition to the above (or an alternative)can we describe the device capabilities that VG requires in order to do recording? Without this information, I cannot give the Eicon people anything to go on. Perhaps this information is available in the logs already? But having the exact description of what VG is asking the wave driver to do is the only way I am likely to get this problem fixed by Eicon (if it is their problem)! Share this post Link to post
SupportTeam Report post Posted 01/31/2006 09:59 PM You can check for correct Wave driver operation by seeing VG run with other hardware - voice modems and Dialoigc cards (in TAPI mode). This does appear to be an Eicon issue. Share this post Link to post
ktruk Report post Posted 02/01/2006 02:36 PM Okay - its an eicon issue, but they can't look into it without knowing what calls (and parameters) you are making to the driver. So I will ask again, can you tell me what error 6 means as returned by your OCX? Or what capabilities are required by the wave driver for VG to be able to use it? Share this post Link to post
SupportTeam Report post Posted 02/01/2006 10:13 PM The error code 5 is returned by Eicon drivers in response to VG's waveInReset call to the Eicon drivers. Share this post Link to post
